A stupid question about fat tire bikes, please?
Senior Curmudgeon
Bikes: Varies by day
Quoted: 5 Post(s)
The cruiser I have came from the factory with 26x3.5" tires. The darned things rubbed against the chain and the chain guard unless I cocked the rear wheel slightly left of the bike's center line.
I decided to solve that particular problem by purchasing a pair of 26x3" tires. In theory, this should have provided me with an additional 0.25" clearance on both sides of the tire. No such luck! These tires seem to have the same width as the previous ones, and they still rub against the chain & chain guard unless cocked slightly left.
Initially, I thought of putting a couple of washers on the outside of the axle, inboard of the frame, but that won't make a bit of difference - the rear cog is still the same distance from the center of the hub (and will still rub against the tire).
Other than PRECISELY positioning the wheel such that it has but microscopic clearance between the outside of the tire and the chain, (which is a monumental PITA), how can I do away with this issue? Does anyone make rims wider than those used on 2.125 tires but narrower than the tractor rims used on the beach cruisers? Does anyone make a 26x2.75" tire?
Thanks - FarHorizon
Thanks - FarHorizon
Nishiki road bike, Raleigh road bike, Electra Cruiser Lux 7d, Electra Townie 3i, Electra Townie 1, Whatever I find today!
The Left Coast, USA
Schwinn cruiser rear wheels? Sta-Tru 26x1.5/75 QR Rear Fw Alloy 36H Wheel Bikewagon
Quoted: 380 Post(s)
Liked 106 Times
You didn't change the width of the wheels rim is why you are still having the problem. You need a narrower rim to move the tire away from the chain. Any tire of those sizes will be almost as wide as the rim it is on. Roger
Thanks - FarHorizon
Thanks - FarHorizon
Senior Curmudgeon
Quoted: 5 Post(s)
If there's no other solution, then a new wheel set it is. Who makes a good coaster-brake wheel set?
It sounds like Vee Rubber may have a 26x2.8 version of their Speedster road tire coming out soon.
2016 Vee ({(Plusbike Tire Line Up!)**)! |
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
To add a 1/4 inch clearance on the drive side, why not dish the wheel a little off center, if you have enough room to spare on the non drive side?
Quoted: 90 Post(s)
Liked 18 Times
what brand of bike? is it a one or three piece crank? maybe describe how it hits both the tire and the chain guard and how hard it's up against them.
maybe space the front sprocket out a little (i've also heard of offset rear sprockets but have no experience with them), but not knowing the particulars mentioned above i can't say it would work. maybe work out clearance for the tire, then bend the chainguard a bit to clear in whatever way it needs to, but again i don't know how it hitting.
Calamari Marionette Ph.D
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Some fat bikes - I'm not saying this is one - have standard 135-width rear dropouts offset to the right, and the wheel is supposed to be dished to the left.
Genesis 49:16-17
Genesis 49:16-17
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
I doubt that with 3 inch wide tires, shifting the wheel a little off center is going to be terribly noticeable.
On racing bikes, with tubular wheels I have ridden improperly dished wheels as well, dished for 5 gears on 126mm spreads with no tragic results, and fat sixes on bikes spread at 130. But heck, it was just an idea, maybe not a good one. Just seemed like an easy solution to me.
Cheers, Eric
PS I was assuming he couldn't just bend out the chain guard, which would be even simpler.
Last edited by Last ride 76; 09-29-15 at 06:52 AM. Reason: spelling and grammar...
Quoted: 4234 Post(s)
Liked 2,949 Times
Can't you just redish the wheels slightly to the nondrive side?
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
Coaster hubs usually take a standard 3-spline cog. Maybe a dished cog would give you enough extra clearance?
Senior Curmudgeon
Quoted: 5 Post(s)
Problem solved - This one is going to CraigsList. I don't need the wider tires (or the irritation).
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
Stick with a US made 26x1.75" to 1.95-2" rim and don't stray beyond 2.00" MTB or 2.125 "balloon". Fat Franks look cool but if you are larger or heavier go to a 29".
Remember that these bikes were originally marketed for 'big kids'.
Prior to around 1933 adult bikes had 28" wheels. 26" in various forms was next including the 'balloon' tire of 26x2.125"
Common sizes for juvenile bikes up included 12, 16, 20, 22 and 24" IIRC. Girls large bikes were 24".
Until mountain bikes became popular that was how it went. I do not see what a 3" tire is for when you just cruise Main Street, it's a fad.
Now if that is YOU in the avatar I am guessing you are between 5'6" and 6'1" and not overly heavy. A sturdy 26" cruiser or MTB would be just fine, as long as it fits your stroke. Don't settle for gimmicks, find a solid bike, new or vintage and find tires that work well with the bike. I don't care about 'offset', dishing or other things that go WHOOSH over my head.
Like anything I get, it has to WORK or I can fix it. Rocket science is for Marvin the Martian.
