Disc singing to me
Disc singing to me
Just got the bike back from the LBS, rides like a champ. Shifting is smooth, brakes (BB5) feel solid, but the rear is singing to me the whole ride. Things look fine, but I am real new at this ( too obvious? ) I have done a few searches but have not seen a solution. Will most likely bring it back to the LBS on Tue, but if it is most likely something minor I would like to see if I can do it. Driving me nuts.
Quoted: 114 Post(s)
Liked 119 Times
From a safety standpoint, it's nothing to worry about. Mine do too (at times). I think a slight warping of the rotor causes it to rub against the pads and the rubbing causes mine to "ting". Sometime, I'll pull the levers and release real quick (snapping action), it'll go away. If you want to try a few cheap easy things, make sure the rotor screws are tight (and evenly torqued), and clean the rotor with rubbing alcohol. If you have adjustable pads, perhaps dial them out a tad.
Bicyclist
Bikes: The two wheeled variety.
My guess is a bent rotor or the caliper is not alligned properly.
The reason that MudPie suggested this is because if rotors get oily or contaminated they can howl when you apply the brakes. Cleaning with alcohol helps but if your pad are also contaminated the howling will continue. Incidently they will still work when contaminated so if you can live with the noise great
surly old man
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 46 Post(s)
Liked 42 Times
If it is singing when the brakes are not engaged, then that means you are getting contact between pads and rotor when you should not.
Try a couple of things:
-clean and lube the setup. A little friction can make the return spring hang up a bit and the pads end up dragging lightly on the rotors.
-add a little more spring tension to the system. I know my BB7's have a spring adjustment screw on them. If so, then just give it a turn. If not, then maybe you could pop the pads and spring out and flex the spring out a bit to give it more tension.
jim
jim
Cross Check Nexus7, IRO Mark V, Trek 620 Nexus7, Karate Monkey half fat, IRO Model 19 fixed, Amp Research B3, Surly 1x1 half fat fixed, and more...
SB forever
SB forever
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Bikes: Co-Motion Speedster Co-Pilot
It may be a simple alignment issue. I used to experience squealing brakes until I learned to re-align the calipers to the rotors. I now make this adjustment regularly. It is not hard to do.
The directions can be found here.....
Avid BB5 User Manual
In brief, the steps are......
ALIGN THE CALI PER
A. Use your fingers or a Torx® wrench to turn the inboard pad adjustment knob
clockwise until the rotor is centered in the caliper. This positions the pads for
the next step in the installation.
B. Make sure the CPS bolts are loose enough for the caliper to move freely.
C. Squeeze the brake lever to compress the brake pads firmly on the rotor.
D. While still holding the brake lever, tighten the CPS bolts. Once they are tight you can
let go of the lever.
ADJUST THE PADS
Back the adjustment knob off (counterclockwise) until the rotor spins freely.
Now you can dial the pad in or out until you find the brake action you prefer
(make sure, of course, that there’s no drag on the rotor). If you can’t seem to
get the feel you like, or the rotor is dragging, repeat step 5.
ALIGN THE CALI PER
ADJUST THE PADS
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
Try backing off one or both barrel adjusters and/or tightening the caliper mounting bolts.
