Skipping Chain? Scheisse!
Hey guys,
Just bought a new bike (Specialized Hardrock 26 Disc) and it now has nearly 20km on the odometer.
I've discovered that I can't stand up and pump without (what I'm assuming is) chain-skipping.
At first I assumed that it's because I'm heavier than the standard bike rider (150kg), but I just thought I'd get a second opinion in case something is wrong mechanically.
So is this happening because I'm heavy or is something wrong?
Thanks
Thanks
Quoted: 94 Post(s)
Liked 151 Times
The bicycle should not do that. Given that it is a new bike bring it back to the shop you bought it from and have them fix it. Probably just a minor adjustment of the rear derailleur.
Agree with ARider. You could try turning the barrel adjuster on the rear derailleur counterclockwise to increase tension to see if that works. But given that you have so few miles on it I would bring it in to your LBS and have them adjust it.
Tractorlegs
Bikes: Schwinn Meridian Single-Speed Tricycle
Quoted: 119 Post(s)
Liked 60 Times
I agree with goldfinch and Arider2, the bike needs to go back to the lbs.
Trikeman
Trikeman
Bikes: Volagi, daVinci Joint Venture
With new components what you're experiencing is very often a mis-adjusted rear derailleur. The chain isn't really skipping on the cog, it's catching on an adjacent cog momentarily. Take it back to the LBS; they can adjust it in 10 minutes. Pay attention, ask questions and you'll soon be able to make these minor adjustments yourself.
Just Plain Slow
Bikes: Lynskey R230
Quoted: 297 Post(s)
Liked 5 Times
Cables stretch a little when they're new, which changes shifting behavior. LBS should have told you to bring it back in a month or so for an adjustment anyway.
Bikes: Shopping for a new bike.
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
Yeah, very easy.
Tunr the barrel adjuster till the chain starts to hit the next biggest cog (will start making a rattle noise). Then back it off about 1/4 turn. That should put you right in the ballpark. Then make small turns till it runs quiet, Bam, you're done!
WHATEVER YOU DO, DON'T TURN ANYTHING WITH A SCREW DRIVER!!!! The limit screws etc.should be set when you bought the bike. They don't (shouldn't) change so don't "screw" with them.
I won't be surprised if you turn the barrel adjuster 1/2 turn and it simmers down.
You should have the rear end of the bike up off the ground (maybe someone holding it up or rope it through your rafters or something) so you can easily spin the pedals and run through the gears as you adjust the barrel adjuster. Shift to the large chainring in front and the smallest cog in the back. Use your ears and listen. Turn barrel adjuster counter clockwise until you hear rattling. Then back off a quarter of a turn. If it doesn't rattle you are good. If it still does, back off some more by turning clockwise. Go up through the gears, listening and adjusting.
Park Tool has good instructions on its site, look for Indexing adjustment for the rear derailleur.
Eh, I guess I said what Beanz said. Missed his post. He is right. Don't mess with the screws!
Bikes: Rans V-Rex
And if that doesn't do it, grease the cables where they pass under the bottom bracket...tip from Sheldon Brown's website, works if it's autoshifting to smaller cogs when you stand up.
Bikes: Firefly custom Road, Ira Ryan custom road bike, Ira Ryan custom fixed gear
Quoted: 9 Post(s)
...make sure the wheel is fully in the dropouts. To do this, open the skewer with the bike on the ground, push down, center the rim between the brake padds and tighten again. Tighten so it needs some effort to close, but doesn't leave a mark on your hand.
If you wheel is in crooked, that can cause the chain to skip.
Hey guys,
Thanks
Thanks
good luck!
