Change Crank, Cassette or Both?
Bikes: Kestrel Talon SL, Surly Steamroller, Equipe SS/FG Beater
Quoted: 10 Post(s)
My bike is not set up for the hills where I live. I built the bike with a 53/34 crank and a 11/23 cassette. I'm thinking of changing to a 50/39 compact crank or a 12/29 cassette or both. Obviously if one or the other does the trick it would be cheaper but am willing to change both if necessary. Any opinions?
Throw the stick!!!!
My bike is not set up for the hills where I live. I built the bike with a 53/39 crank and a 11/23 cassette. I'm thinking of changing to a 50/39 compact crank or a 12/29 cassette or both. Obviously if one or the other does the trick it would be cheaper but am willing to change both if necessary. Any opinions?
How much trouble are you having with the climbs? A cassette may take care of your problem.
I may be fat but I'm slow enough to make up for it.
King Hoternot
Bikes: 2015 Cannondale Evo Hi mod
Quoted: 127 Post(s)
If you're really concerned, I would do a mid compact 52/36 with a 12-27 or 12-28.
Super Moderator
Quoted: 1173 Post(s)
Liked 931 Times
If you already have a 34 small ring (compact), why would you switch to 39 (which is not compact) ?
Or the hills are too easy and your gears are currently too low ?
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
A 12-29 will be cheaper than switching to a 50/34 (you really must have a 53/39 right now) and may be adequate. However, be sure to check if your rear derailleur can handle it.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
It seems to depend on how much you like the smaller gear jumps, or if you don't care about it. Some people have a groove for their cadence, and don't mind shifting more front and back, and so would prefer a compact. If you're happy with bigger jumps, with more range in your cadence, the cassette makes more sense.
Something to keep in mind, changes in the back have bigger effect than changes in the front. For example changing the cassette to 29 (with the existing 53 on front) would be equivalent to changing the crank to a 42 tooth (with the existing 23 cog)
2 Fat 2 Furious
Bikes: 2009 Specialized Rockhopper Comp Disc, 2009 Specialized Tricross Sport RIP
Swapping out your cassette would also give you lower gearing and assuming your RD could cope with the wider range would be quicker and easier - you'd need a few extra chainlinks (or maybe just get a new chain and not faff around with it). If your RD can cope with it you could go to something like 11-32 or 11-34 - you'll get some much lower gearing but the price you'll pay is bigger steps between gears.
If you need much lower gearing you could go all-out and put MTB gearing on it - maybe a 42/27 or 36/24 at the front paired with 11-34 at the back. Going from a 39/23 granny gear to 24/34 would make a huge difference, although you'd trade your 53-12 top gear for 36-11 which would mean you'd have to really thrash the pedals to get up to speed.
You can get an idea of the relative gains by simply dividing the chainring size by the sprocket size.
At present your granny gear is 39/23 = 1.696
A 50/34 would give you a low of 34/23 = 1.478
A 12-29 cassette would give you 39/29 = 1.345
Replacing both would give you 34/29 = 1.172
The silly MTB extreme would give 24/34 = 0.706
The lower the number, the easier it will be to pedal if everything else is equal.
"For a list of ways technology has failed to improve quality of life, press three"
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
There's no way he has a 53/34 now; I can't imagine anything handling a 19t differential. He must have just mixed up the standard and compact gearing. If he has that sort of gearing there are bigger problems here than climbing.
Quoted: 10 Post(s)
Sorry for the mistake. That's what I get for not re-reading the post before submitting. Yes I have a 53/39 and thinking of going to a 50/34 compact. I think a 12/27 or a 12/29 is offered in a Record cassette. I like the speed of the gearing I have now but have to compromise somewhat for the hills. Maybe changing the cassette first is the answer.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Super Moderator
Liked 931 Times
I would only spend the money for a Record cassette if I were hoping to set a record on an uphill time trial. Otherwise go for one of the lower models.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Oh, yes, right, get the Chorus cassette (there's no Athena cassette). No sense in wearing out soft Ti cogs to save a few ounces.
Quoted: 10 Post(s)
This. Get the cassette and see if that plus a dose of HTFU gets you through what you need. If it doesn't, THEN think about changing the crank, which is much more expensive. Are you able to get over the hills and just want it somewhat easier, or are they completely too big for you?
Quoted: 10 Post(s)
Yes, I built the bike with Record gear but it would be sensible to switch to a more inexpensive model. My riding doesn't warrant top shelf stuff.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
The 29t bottom cog will be over 26% easier than your current 23t. The 12-27 will be over 17% easier. Frankly, the 27t would probably be fine, especially if you keep riding and get fitter. Take your pick, but I'd keep the crankset.
Quoted: 10 Post(s)
Thanks, if that works it would be the best(cheapest) case scenario. What's the advantage of the 27 over the 29 since that cog would only be used on the steepest hills? If 29 is too tall you can always shift down.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
12,13,14,15,16,17,19,21,23,25,27
The 12-29 goes:
12,13,14,15,16,17,19,21,23,26,29
The only difference is on the 12-27, the last two cogs are 2-tooth jumps instead of 3-tooth. That means they'll involve a less-severe change in cadence. How much that matters is up to you; I thought the 12-27 might add an 18t cog in the middle, but apparently not.
cerealkilla
Road Cycling
50
04-13-14 03:33 AM
AK404
Road Cycling
39
11-05-12 10:52 PM
