Pannier/bag questions
I have 3 pannier/bag questions.
1) I bought a set of Schwinn Voyageur rear panniers on Craigslist. Here's a photo of them mounted on a motorcycle (not mine) https://www.advrider.com/forums/showt...156429&page=67 (scroll halfway down)
The attachment system doesn't seem that great: 2 hooks at the top and a bottom hook on a bungee that seems flimsy and doesn't create much tension One forum poster mentioned that these bags tend to fall off if you hit a bump. How can I make sure the panniers are securely attached? Normally, is the weight of the panniers enough to keep them in place?
2) I don't fully understand the need for front panniers, especially in the summer. I backpack so my equipment is relatively light and compact. My tent, sleeping bag, and mattress fit in one rear pannier. That leaves the other pannier, trunk and front bag for the rest. I probably wouldn't carry a stove. Do most people use front panniers these days?
3) Given the variety of handlebars and stems these days, how can you tell if a front bag will fit your handlebar if you order online? I have an upright, swept-back bar, like the Nitto North Road and an adjustable threadless stem. My current bag doesn't fit the angle of the stem (unless I bend the mounting bracket, which I will try).
Thanks!
Thanks!
You will find that if/when you lay the bike down on its side and pick it up one hook may come unhooked if you are not careful. Not generally a problem, just something to watch for.
Quoted: 137 Post(s)
Liked 81 Times
Thanks!
Thanks!
Quoted: 659 Post(s)
Liked 7 Times
The mounting system on those looks adequate, but should be supplemented a bit. Many touring cyclists carry some of their bulky items on top of the rear rack/panniers. If there's a tent and/or sleeping bag strapped down firmly across the top of the rack and panniers then that should be sufficient to keep the panniers from coming loose. When I don't have anything on top of the rack I still loop a bungie cord around the top of the rack and over the pannier hooks for extra security.
Most touring cyclists I see do have front and rear panniers. But I've only been using the rear ones except when on the tandem. All my gear fits inside the two panniers leaving the top of the rack free for any temporary items (food, firewood, etc.) that might be picked up shortly before reaching camp.
Is this type of pannier---side panniers connected to top bag---available in the U.S.? https://www.yopi.de/Kettler_Dreifach_...et_Travel_Tour
I used this type of pannier to tour Europe and it worked very well. No chance of falling off the bike. Very handy for sprinting from train to train with your bike on one shoulder and the pannier on the other. I saw these all over Germany but not in the U.S.
Bikes: Cervelo Soloist, Giant TCR Advanced, Co-Motion Americano Co-Pilot
I think the argument for front and rear panniers is about load distribution and the effect that has on how the bike handles. Some people seem to be religious about having front panniers and others do not. I personally believe that distributing your load front and back does have a positive affect on handling, but I have no proof. I want to be careful how I say this as the topic has proven to be incendiary in the past. That's it...over and out.
mosquito rancher
GetUpnGo--those combo panniers look interesting. In the USA, I've seen trunk bags that have small zip-out panniers, but nothing where the panniers are so big and well-integrated.
Adam Rice
Adam Rice
