More rod brakes: A rough 1957 Triumph Princess
www.theheadbadge.com
Quoted: 2425 Post(s)
Liked 4,410 Times
A local friend rolled this one over after not a single LBS would take it on (the usual). This is what appears to be a UK-spec, 1957 (by Sturmey AG), Triumph Princess, a rough equivalent to the Raleigh Dawn Superbe Tourist: Rod brakes, green paint with an AG, and a chaincase. Seems as if the "Prince" line got the cable brakes according to this catalog scan: https://onlinebicyclemuseum.co.uk/19...953-catalogue/
And yes, it is rough, but not enough for an OA bath not to fix. However, I am throwing up the "HELP!" flag right now for a pair of rims. Someone obviously rode this Triumph frequently enough for the pads to wear out the chrome on the braking surface of the rims, leaving the bare spots to rust over the years. These are EA3 32/40 Westwoods. I don't mind if the replacement rims are a later era, we just need something that'll make the bike ridable. If you've got something, send a PM.
(P.S.:, Oh wise scribe of C&V secrets, @nlerner...got any by chance?)
While this is a Raleigh-built, homogenized Triumph, it still carries all the Superbe goodies - green finish, filter switch unit, AG hub, and the mid-1950's variation of Sturmey-Archer lighting that differs from both the earlier round sphere front / pill-shaped rear light combo of the 1950's, and the later chromed 1960s/70s variants.
"57 / 3"
I'm used to seeing the no-frills sphere shaped front lights and pill-shaped rears of the late-1940s and early 1950's; this one is a bit more space-age.
Anyone recognize the grips? The goo doesn't remind me offhand of anything, though it looks thick enough to have been a John Bull Super Club - but too short.
Lycett saddle has held up fairly well over the years:
Slightly fancier crown stamping than in later years. @Ged117, I don't recall - is this the same on your Triumph?
"57 / 3"
Likes For cudak888:
Liked 4,410 Times
Tires seem a bit worse for wear
As I said, I can't make these rims work. Interesting that the secondary brand to Raleigh didn't get Raleigh's patented (at the time) stainless spokes.
Should be interesting getting this one ridable again. Will probably be the first victim for the VAR cotter press currently on the way from @Mad Honk.
Incidentally, any good deals on EA3 tires as of recent? Blackwall, non-directional tread pattern preferable. This is one of two bikes I'm doing (yes, everyone will get to see the other one too), so I'm also open to any sources where combined shipping works for multiple tires ordered.
-Kurt
-Kurt
Likes For cudak888:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,057 Times
Slightly fancier crown stamping than in later years. @clubman, I don't recall - is this the same on your Triumph?
I'll look for rims later today but they wouldn't be westwoods, maybe used westricks with some life left in them?
Likes For clubman:
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 360 Post(s)
Liked 473 Times
Likes For Ged117:
Likes For Chuck Naill:
Phyllo-buster
Liked 2,057 Times
Quoted: 360 Post(s)
Liked 473 Times
Liked 4,410 Times
I know some of the folks on the Facebook Raleigh Roadsters group might have the Westwoods ones, but there hasn't been any activity approved to that group in ages. The admin, Rowan De Bonaire, has also fallen off the face of the earth.
I actually meant to tag you about this bike, but crossed my wires with @clubman. The interesting thing I noted between your later Triumph and this one is that the crown itself is slightly more ornate on the '57, but other than the additional details, it is the same exact casting used on secondary brand Raleighs into the 1970's.
-Kurt
Phyllo-buster
Liked 2,057 Times
I don't think I can make you happy Kurt. I've got two sets of 50's Westrick wheels, neither with stainless centres and both sets have serious corrosion. Not as bad as yours mind you but not worth unlacing and shipping across the border.
I do have a rather clean 32 hole rim with some speckling but it's likely 60's/70's. Rim only, no spokes. I can get a price for you if you'd like. If you reference some charts, I may have correct chrome or galvanized spokes with plated brass nipples should you want them. Some are 14, others are 15 gauge.
Likes For clubman:
Liked 4,410 Times
All things considered, I would rather not have to respoke unless it's for period Westricks. No point in adding all the cost of spokes if it winds up in a less-than-original combination.
I've looked at some of the modern Westwood repops available on eBay right now, but it's about $120 USD for a pair of bright steel hoops. Overpriced in my book, but they might brake nicer than used originals full of flat spots.
-Kurt
Liked 4,410 Times
Tore this one down today for its brightwork and "whatever-fit-in-the-bin" OA bath.
Had a chance to put Mad Honk's VAR cotter press to work for the very first time:
The left hand cotter had lost its nut long ago and the threads were slightly damaged, so I didn't attempt to install a nut on it to avoid rounding out the threads.
This turned out to be a worry that was completely unnecessary. Apparently, with the VAR press, you don't really need to worry too much about that. Just put the tool on, pull the lever , and "POP!" - out comes the cotter. It's just as satisfying as it sounds.
"POP!"
Found evidence of the double box lining under the clamps too. This Triumph is literally a Raleigh Superbe Dawn Tourist with a different badge on it.
Gradually filling up the OA bath:
What may be original Dunlop No. 4 brake pads:
Completely stripped:
Out of curiosity, I hung it next to the frameset of my previously OA-bathed, rusted-from-the-Florida-Keys 195x Raleigh Superbe Tourist that I run away from and come back to every now and then. Pretty much the same color. I expect the Triumph to come out a bit better than the much more abused Superbe Tourist.
-Kurt
"POP!"
-Kurt
Likes For cudak888:
Quoted: 230 Post(s)
Liked 18 Times
What of Triumph bikes' advertising/catalogues survives from this period? I haven't found much. Most of the 3-speed triumphs I come across these days are 70s traffic masters, sometimes with the AG dynohub, sometimes not.
Liked 4,410 Times
For instance: https://onlinebicyclemuseum.co.uk/19...953-catalogue/
-Kurt
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 186 Post(s)
Liked 208 Times
My Rudge with cable/caliper brakes came with a 40h Westwood (yikes!) so I will dig it out and start the ATF/acetone juice after I move the snowblower out of the way.
Sorry- with a 1960 AW hub I forgot it is a 36h (in great shape rim) and I need to relace a with a Dunlop 36h I was gifted.
Last new bike 1991
Last new bike 1991
Likes For dmark:
Liked 4,410 Times
I haven't OA'ed the frame yet (ran out of it too, time to reorder the stuff), but the fork has...which means it's polish time once again.
End result isn't great, but certainly not bad considering what it started out as:
The rust spiderwebbing is definitely still here, but it should be kept at bay for a while now. The polish and wax should help fill in some of the porosity.
Of course it's bent. I wouldn't have it any other way.
-Kurt
-Kurt
Liked 4,410 Times
Made a lot of progress on this over the last few weeks. First off, chrome bits fresh out of the OA bath - photographed on one of my filthy benches, especially for whoever in the Annoyances thread complained about messy workbenches.
Frame, chaincase, and fenders into the OA bath:
Out of the bath and fogged up, but surface rust is by no means as bad. This is after a few days of letting it dry off. I sometimes give frames a light spray of WD40 to help repel water out of the pores of the paint, depending on how they react; this one got it.
Frame's bent...
... and not anymore.
When you see a dent like that in one of these frames, chances are the entire rear triangle is tweaked. It was.
It was also a pain in the butt to get it centered where it was supposed to be, but it is straight as an arrow now.
Polish time.
Beginning reassembly. Rods had to be straightened out; they had more bends in them than some pastas.
More in next post.
Frame's bent...
Polish time.
More in next post.
Likes For cudak888:
Liked 4,410 Times
Not everything polishes up that well, but this picture shows one of the best spots. Definitely an improvement over what it looked like before.
The chaincase did not fare so well. Paint lifted off the front, but the rest is fine. Can't explain this one, but it just goes to show that paint can be a finicky thing to deal with.
Where it is at the moment. Time to enter into the "how much money do you really want to pour into this thing?" discussion of rims, tires, grips, pedals, and rear reflector.
And a replacement chaincase, ideally; the loss of paint drags down everything that was achieved polishing the rest.
-Kurt
-Kurt
Likes For cudak888:
Liked 4,410 Times
Finally, some progress. We wound up getting the current repop Westwood rims that are on eBay. While they look decent, they are downright impossible to true. One side might be decent; the other side is a bent wobbly mess.
I'd throw them out and start again if I had a choice, but that's obviously not in the cards; I'm already overbudget.
A repop reflector replaced what was left of the original:
Opened up the AG and found it basically brand new inside - and dry as a bone. At worse, some surface rust on the planet cage.
Back together and slathered in 00 grease.
The rebuilt rear wheel - only two spokes had to be replaced, but that didn't stop the new Westwood from fighting me every step of the way.
Chain cleaned up and installed:
Buttoned up. I believe I still need to dig up another period-correct left-hand washer for the rear axle. And another cotter nut.
-Kurt
-Kurt
Likes For cudak888:
Freewheel Medic
Quoted: 1458 Post(s)
Liked 2,206 Times
@cudak888 wrote: "...I still need to dig up another period-correct left-hand washer for the rear axle."
Because the C&V washer police might issue a warrant?
Bob
Bob
Likes For pastorbobnlnh:
Liked 4,410 Times
-Kurt
Liked 4,410 Times
Progress (finally). I've had the frame back together for a while now, but hadn't been happy with the work on the fork. For some reason, I set it to 90mm OLN instead of 80mm, and also noted that one blade was still about 3mm ahead of the other. Not really eager to struggle with a loose-bearing headset again, I procrastinated for three weeks. Admittedly, this gave me a moment to re-dish the front wheel after realizing the truing stand was out of whack; I finally got my fingers on a Unior alignment tool to sort that out.
Whatever the case, I tore everything apart again today, perfected the alignment, checked it, reassembled it, realized the blades appeared to be kinked forward too much, tore it all apart again, brought the blades back to the headtube centerline, verified it, and buttoned it all back together. Then a friend came by with a 1960's Bianchi with the integrated Campagnolo headset, and I wound up dealing with no less than 56loose bearings in a single headset. Oy vey.
There's still a slight bit of play in the headset that I can't seem to nail down, but I'm pleased with what I've got so far. If I have to take it all apart to knurl the crown race sea- well, never mind for now!
No pictures of the pain, just the pleasure of the results:
Also - if anyone can help - I'm still looking for that early Sturmey rear axle washer for the rear wheel. Also a period Raleigh seatpost binder bolt, Raleigh Industries kickstand, and perhaps a spare aftermarket SA shifter cable if anyone can spare it - the last one at the LBS went on my Moulton and I don't get why an el-cheapo cable kit should cost $20 on Amazon - when all I want is the inner cable and nothing else.
-Kurt
-Kurt
Likes For cudak888:
Liked 4,410 Times
The aftermarket 3-speed cable on my Moulton snapped at the trigger shifter yesterday, which made me realize there's no reason I shouldn't be soldering my own ends for both sides on my Sturmey cables. So I did, using some of my trusty brass tubing:
And here's the result, complete with that ridiculously overpriced Yokozuna cable housing.
For those curious as to what the ends look like, here's what the one on my Moulton looks like before I solder it:
-Kurt
-Kurt
Likes For cudak888:
Count Orlok Member
Likes For gna:
Liked 4,410 Times
The paste tacks it down, then I feed a really thin roll of silver bearing solder in one end. I'll check to see what it is; it's a roll that was given to me at work by one of the IT techs; it was used for basic PCB repairs.
-Kurt
Likes For cudak888:
