Tire size for potential wet/muddy gravel race?
I don’t live in Tampa
Bikes: 2014 Jamis Ventura Race, 2014 Cervelo P2, 2017 Raleigh Tamland 1, 2015 Jamis Trail X
Quoted: 151 Post(s)
Liked 42 Times
I have panaracer gravel king 35mm and 40mm tires. Currently have the 35mm installed. I have an upcoming gravel even that may end up being very wet/muddy. Will there be much difference going to a 40mm? I haven't been caught in the rain yet out gravel biking so not really sure.
It depends!
In my home area, the roads are hard packed so rain just results in a thin layer of sliminess on top. 35mm would be fine as long as there is enough tread to shed that slime. YMMV
Bikes: 2003 Raleigh M40, 2015 Raleigh RX 2.0, 2017 Kinesis Tripster A/T
Quoted: 26 Post(s)
Liked 6 Times
I just did muddy/gravel ride over weekend. I came to conclusion that using my riddlers 45c with mud was bad choice. I will be purchasing a second wheelset dedicated for mud. Looking for suggestion on good mud clearing tire 36-40mm size.
going to a larger tire will also reduce your mud clearance between the frame, so pick your poison I’ve run a 40mm tire in mud before and have had it stop from spinning because of the mud buildup between tire and frame.
Quoted: 151 Post(s)
Liked 42 Times
challenging. I definitely needed at least the 40mm tire. It was a very hilly course. Almost 7000 ft of climbing in 63 miles. The first half was better suited to a mountain bike. Very rocky both on ascent and descent. Next year I may put on size 43 tires as I have clearance.
Quoted: 151 Post(s)
Liked 42 Times
yep. Cutthroat would have worked well. I’ll definitely have larger tires next year which hopefully will help. My bike being steel is a bit heavy.
bobin
22
04-16-19 10:45 AM
mack_turtle
23
01-28-18 10:16 AM
biketampa
14
03-17-17 08:45 PM
ksdog
27
07-19-15 11:49 PM
FlashBazbo
5
05-18-15 06:21 PM
