Tube patch vulcanizing fluid glue is flammable, might not be allowed on flights
#51
Quoted: 18373 Post(s)
Liked 4,508 Times
I have commented before that I will start taking a thread locker on tours, have met too many people in campsites that were missing rack bolts, etc.
https://www.truevalue.com/catalog/pr...thread-locker/
I have no clue if it is flammable. It will be in my bag of tools, thus will be checked.
Mainly my goal in determining what to have in my carry on is the stuff I will need when the airline decides that I might enjoy sleeping in an airport overnight without access to my checked bag(s). Tooth brush, toothpaste, spare shirt, etc. Fortunately every time that has happened so far has only been for one night.
As far as I can tell, at least some of the loctite products will burn under certain conditions, but aren't considered "flammable", and thus shouldn't be restricted for flammability (other than not having enough to make a bomb).
#52
Jedi Master
Agreed, TSA is "security theater." I don't know how many times I've checked luggage with everything from rubber cement to aftershave in it with nary a squeak. (Also, never an incident in flight, FWIW.) Then last week they alertly caught me carrying an apple through the checkpoint.
The last hard data I recall was that the same people who can find every damn sealed water bottle were only able to detect 80-95% of the actual weapons going through the checkpoint.
Likes For kingston:
#53
Quoted: 3459 Post(s)
Liked 1,465 Times
I have some bad news for you about that mayo: Say what? Mayonnaise is a combustible liquid? | BFL CANADA
I think the next tour I take will be on Amtrak.
#54
Clark W. Griswold
Quoted: 4349 Post(s)
Liked 3,986 Times
This is one of the many reasons I hate flying. Seriously we are having to argue over a tiny bottle of vulcanizing glue! Thanks to the U.S. government bowing to other foreign terrorists and taking away freedom, this is our lives. Having to lose any sense of privacy and being harassed over the silliest of things to go places more quickly is so silly. Foreign terrorists don't need to waste their time hijacking planes and blowing stuff up over here they ruined everyones life who has to or chooses to fly anywhere from the U.S. or to the U.S. probably for the next 100+ years.
Though I will say my last flight the TSA checkpoint while extremely degrading and fascistic didn't take as long as I thought it might take and on the way back they didn't bother me about my partially full water bottle. Still absolutely ridiculous and everything said above still applies but I did think it would be much worse.
Back in the day we would have just complained about airline fees, dagnabit.
Likes For veganbikes:
#55
Quoted: 350 Post(s)
Liked 122 Times
Food items depends on whether there are regulations on invasive species. The couple of times I traveled to Australia and New Zealand, I saw a lot of people fined several hundred dollars for carrying nuts and fruits. They were warned before boarding the flight and during the flight but chose to try sneaking them through.
I think banning of anything labeled flammable makes sense for safely because a small amount of fuel can potentially start a large fire. It doesn't matter if the risk is low or incidents are infrequent. Incidents do happen, whether from damage from improper baggage handling, chemical reactions to other material from other baggage, or being near a heat source in the plane. The point is to not put the other passengers at risk for self convenience.
I remember seeing articles and videos in the past about how designers of the baggage containers that the larger airplanes use tried to fireproof the containers in case the baggage ignite. The containers could not always keep the fire from spreading.
#56
One person is. (Not you, in case you take it that way)
#57
Liked 4,508 Times
Electronics in the suitcase with the glue?
One of the issues is concentrations. One must look at LEL and UEL (Lower Explosive Limit, and Upper Explosive Limit).
Ok, so looking at the REMA Vulcanizing Fluid MSDS (as an example, each fluid could be different).
https://www.rematiptop.com/assets/tec...0071515AOM.pdf
The volatile component is Trichloroethylene.
Now looking at the LEL/UEL
https://www.mathesongas.com/pdfs/pro...ve-Limits-.pdf
Trichloroethylene is moderately less "explosive" than other solvents.
Out of your suitcase, It doesn't seem likely to reach 12% concentration. Although, there would be a slight risk of reaching high concentrations inside of the suitcase, and very close to the source.
Spontaneous combustion is typically an issue with certain organics, and not an issue here.
So, that leaves us needing an ignition source. Electronics inside of the luggage?
#58
Liked 4,508 Times
Electronics, in fact, would seem to be a bigger risk than your patch glue.
https://www.faa.gov/news/fact_sheets...m?newsId=23054
I've actually had issues with accidental activation of certain bicycle headlights. One brand I have used would turn itself on to high beam, and would drain the battery quickly, and get fairly warm, especially if enclosed.
Most bike lights are difficult to remove the batteries.
I do like the CREE style bike lgihts with external 8.4V battery packs, but even those aren't without issues.
It isn't the tiny vulcanizing fluid tubes that will bring down the next plane.
Possibly an accidental battery burn. But, I could imagine a small device specifically designed to activate itself and spit flames.
Devices containing lithium metal batteries or lithium ion batteries, including – but not limited to – smartphones, tablets, cameras and laptops, should be kept in carry-on baggage. If these devices are packed in checked baggage, they should be turned completely off, protected from accidental activation and packed so they are protected from damage.
#59
Quoted: 350 Post(s)
Liked 122 Times
Parktool vp-1 is naphtha, heptane, and octane. They have very low LEL.
Ignition source can be various things. It doesn't have to be only the things in your own baggage. It could be from the baggage from other passengers who decide to bring hazardous materials, or if your stuff gets opened and mixed with other baggage, or sources from the plane itself. A fire could also start nearby and spread to your baggage.
Why bring the risk of flammable materials onto the plane anyway if there are alternatives that are easily available?
It's also written on the FAA website that flammable adhesives are not allowed for passengers to carry onboard.
#60
Liked 4,508 Times
https://www.parktool.com/assets/doc/...t/VP-1_SDS.pdf
Parktool vp-1 is naptha, heptane, and octane. They have very low LEL.
Also, if there is a fire severe enough to burn through your suitcase coveringt, and all your clothes to get to that tiny tube, then there are issues larger than a small poof of flames when they reach the tube.
#61
Quoted: 350 Post(s)
Liked 122 Times
I can't recall what exactly happened on the UPS cargo plane crash, but I was under the impression that a fire started somewhere inside the plane and spread to the batteries that someone falsely declared as something else. I could be wrong about this detail though. The smoke was what eventually incapacitated the pilots and lead to the crash. I think one of the pilots passed out early in the emergency, and the second pilot either ran out of oxygen or forgot to open the valve, or he could no longer see the instrument panel or see outside the window.
#62
Quoted: 18410 Post(s)
Liked 15,530 Times
I flew from Bismarck, ND, to Philly the day after the attempted shoe bombing. It was the first day all liquids and gels were banned. Heard about it on the news the night before and decided, for the hell of it, to pick up a couple of packs of mayo with my grocery store sandwich I bought for the flight. Sure enough, the TSA confiscated my sealed, branded mayo packs. At least they let me keep the cheese.
#63
Liked 4,508 Times
The GCAA released its final investigation report in July 2013. The report indicated that the fire was caused by the autoignition of the contents of a cargo pallet, which contained more than 81,000 lithium batteries and other combustible materials. The shutdown of air conditioning pack 1 for unknown reasons lead to smoke entering the cockpit.
The investigation also revealed that the cargo liner failed when the fire started and this contributed to the severity of the damage.
#64
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
That's something that has been documented to happen more than once, as opposed to freaking patch glue.
#65
Liked 1,465 Times
I worked for several years at a Federal Agency doing fire protection research, from that I can say that a lot of the discussion on this thread is a bit tooooooo paranoid. I remember once at one of our monthly safety meetings, we needed to practice using portable fire extinguishers. It was a cool day, they had a lot of trouble lighting the pan of fuel for us to practice. It is hard to practice putting out a fire when you have trouble getting one lit.
#66
Clark W. Griswold
Liked 3,986 Times
I know we aren't actually really arguing but the fact we need to discuss it because TSA believes it is the next weapon! Allezu Akbar or Going is the greatest or the Specialized aluminum (or if you are old school steel) road bike is the greatest.
#67
Liked 4,508 Times
At one of our monthly safety meetings, we needed to practice using portable fire extinguishers. It was a cool day, they had a lot of trouble lighting the pan of fuel for us to practice. It is hard to practice putting out a fire when you have trouble getting one lit.
Yet, one gets far too many runaway house fires.
You were trying to light a fuel? Diesel? I could imagine it would be a pain to light a tub of it. Yet, dip a rag in diesel, and you can easily light it.
Gasoline on the other hand... WHOOF!!! practice with care!!!
And, I think that is the problem. The vapors from glue would be bad, if you had enough of them. But, I'm not convinced that you would have enough of them, unless you smashed the tube into a laptop that had an active short. Even so, ,most solid state electronics don't spark (other than the famous flaming batteries).
#68
The % of people flying with a teeny tiny tube of patch glue is probably in the .00000 something percentage of flyers.
In any case, if security rules deem that you can't bring x or y on plane, I'll just follow the rules.
#69
Clark W. Griswold
Liked 3,986 Times
That's fair enough to discuss stuff, but I don't believe that "the tsa believes it is the next weapon!"
As Ammon Hennacy said "Oh judge! Your damn laws! The good people don't need them, and the bad people don't obey them." Terrorists aren't going to look at the list and say "hey James, looks like we can't bring our tiki torches and bucket of gravy" "Well darn, Timothy we could have terrorized that plane" and normal passengers aren't like "I can use these ski poles and snow globes to attack the pilot" The whole TSA is really just a theatre with really bad actors that accomplishes nothing. If a terrorist wants to take down a plane they can easily do it without 4oz of liquid and nail clippers. I don't feel safe while being violated for attempting to go from one place to another with some speed while in the sky. I have not done wrong yet am treated as if I have done wrong.
Anywho this is getting off topic and for that I apologize. Though I do need to find my spare Tip-Top fluids so I can build out all of my saddle bags and EDC stuff.
#70
TSA? lol How the hell have people forgotten the Decades where you could take all of the tubes glue you wanted onto a plane and it never magically started the plane on fire? It’s sad how easily... Never-mind. It’s a bike forum. Just take your tire glue and don’t worry about it. If they find it, they’ll throw it away. No big deal beyond the general frustration of the whole pile of BS. I’ve had one thing confiscated by TSA. A lighter, which is blatantly on the OK list. Upon politely questioning her, the lady Immediately jumped to not letting me fly if I questioned her again. A friend of mine forgot his camp knife (~5” fixed blade) in his camping backpack which he used for a carry-on. He flew with no problems and only realized when he was unpacking at his destination. It’s all a ruse. Just take your glue and maybe you’ll have to buy more if a grumpy agent is having a bad day that day. You would have had to buy some anyway if you didn’t take it.
I wish I were surprised. The TSA isn’t there to find weapons and drugs. They’re there to make money and maintain an illusion based on fear.
Just ignore the man behind the curtain...
The Department of Homeland Security Inspector General carries out “Red Team” tests periodically to check the competence of the TSA’s ability to detect and stop fake weapons from getting through airport security. The results of the tests in 2017 showed that the TSA screeners FAILED to detect weapons, drugs, and explosives 80% the time. The same test in 2015 revealed a 95% failure rate. The TSA no longer releases test results to the public.
