Water trapped in wheels after washing bike
Quoted: 1461 Post(s)
Liked 1,485 Times
New bike - washed it the other day after a dirt/gravel ride and then parked it in the basement for a few days without touching it.
I took the wheels off last night to swap out different tires and noticed the front wheel made a slight sloshing noise in my hand. After I deflated and removed the tire, the rim bed was wet. I turned the wheel so that the valve hole was down (6 o'clock) and a small amount of water spilled out... maybe a tablespoon or two. Same story with the rear wheel.
These are stock Cannondale "CX 1.0" aluminum wheels that are tubeless ready, with rim tape installed. How/where is water getting in and is this something I should be concerned about? The bike hasn't been ridden in the rain, so it definitely got in when I washed it. I just used a garden hose & sponge, not a pressure washer or anything. Is it getting in through the valve stem somehow?
Any thoughts on this?
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Must be getting in past the spoke nipples.
Quoted: 20810 Post(s)
Liked 9,456 Times
Yeah, I would guess spoke nipples, too.
I *think* that I've had similar water infiltration but with tubeless tires. I say "think" because what should have been sealant with a half & half like texture was instead thin, watery and slightly foul-smelling. I assume that water got in and diluted whatever sealant was left, because I don't think that even old sealant would separate in to liquids and solids like a past-due milk. Ick.
Anyway, my experience was only with riding in foul weather - not with washing with a hose, or anything.
Quoted: 8280 Post(s)
Liked 9,046 Times
It's normal to happen and you need to dry it out. Don't wash your bike, just clean it with Pledge or some other cleaner.
Quoted: 1067 Post(s)
Liked 259 Times
There is usually a small drain hole in the rim.
It obviously won't work if you park the bike without it being at the bottom.
Also the water will drain out of it if you take it for a ride.
Quoted: 850 Post(s)
Liked 344 Times
I’d actually say valve stem hole before spoke nipples. The seal between the nipples and rim is almost airtight in some cases. Some people have exploded rims on TL setups when their tape fails and air doesn’t escape the rim.
Try sealing the valve hole with a rubber ring of some sort - after drying out the rim.
Liked 1,485 Times
I had a lot of dirt/mud stuck in the treads after my last ride, so I sprayed a lot of water at the tires to blast it out. I'll probably be a little more mindful of that next time, and also pay attention to see if the water comes on it's own when riding.
Maybe I just need to take the bike for a quick spin around the block after washing?
I get this after rain rides. It sloshes inside the double-wall cavity for weeks, but it doesn't bother me, and it's not going to cause any issues.
Liked 1,485 Times
It doesn't make sense to me that water is getting into the area where the inner tube is currently, but the system can somehow be air-tight when sealant is added. I guess the sealant will seal up whatever holes are allowing water in? Or maybe the rim tape is not 100% sealed on or something?
This is a stock wheelset on a new CX race bike and I intend to ride it in wet/muddy conditions. I am planning on running these wheels with tubeless tires for training and racing, so taking the tires off to let the rims dry out after every wet ride isn't going to be practical (and is also a huge pain in the butt, even with tubes). I also don't love the thought of my wheels filling up with water whenever it's wet out. I've never noticed this problem with other wheels and I've been racing CX in rain/mud for years.
Quoted: 18415 Post(s)
Liked 15,553 Times
When I crossed Middleburry Gap in VT they were doing roadwork. Had to ride through a stretch of what I think was water mixed with some limestone. Our bikes got coated. The stuff our our frames dried during the descent, leaving white residue. After we got home from the trip we could hear noise inside our rims. Removed the tires and tube to find that water had gotten inside the rims and left tiny grains of limestone inside once the water dried.
Dave
Likes For bonsai171:
Zircon Encrusted Tweezers
Quoted: 261 Post(s)
Liked 132 Times
I try to wash my bikes on a sunny day when possible. After washing, I put the bike out in the full sun for an hour or two. That seems to dry up all of the nooks and crannies. If any water got in the frame, I like to think that helps bake the water out of there too.
Are you absolutely sure sure it's in the tire area, and not just in the hollow 'double wall' area?
Liked 1,485 Times
I'm concerned that the rim tape job (supposedly tubeless ready) may not be totally sealed up, so water is getting from the "double wall" area of the wheel into the tire area. I'm planning to try setting up the tires as tubeless in the next few weeks, so I guess I'll find out?
