You cant judge a tire widrh by its picture?
Old 01-17-20, 04:29 PM
UsedToBeFaster
Quoted: 125 Post(s)
Liked 18 Times in 14 Posts
One of these ties is 40 mil the other 32 mil you tell me which one the one on the left or the one on the right
UsedToBeFaster is offline
Old 01-17-20, 04:31 PM
Bah Humbug
serious cyclist
Bah Humbug's Avatar
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times in 2,026 Posts
It would be harder if you didn't leave one of the sizes clearly showing in the picture.
Bah Humbug is offline
Likes For Bah Humbug:
Old 01-17-20, 05:09 PM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3646 Post(s)
Liked 5,377 Times in 2,729 Posts
shelbyfv is offline
Old 01-17-20, 10:18 PM
TheDudeIsHere
Registered User
Quoted: 188 Post(s)
Liked 276 Times in 161 Posts
The closer one is the 32.
By the way the tire has 3 lanes of tread across it, the slightly narrower look of the tire to the eye, the way the tire has wore in the center vs the overall width, because a highly trained eye can tell the difference between tire widths, I chose the closer tire.
........AND, it says 32 on it!
TheDudeIsHere is offline
Old 01-17-20, 11:03 PM
CliffordK
CliffordK's Avatar
Quoted: 18347 Post(s)
Liked 4,497 Times in 3,344 Posts
The corollary, of course, is that you can't judge a tire's width by the manufacture's markings.
The one in back does appear to have a deeper sidwall. And, they may also look different if you had a top-down view.
CliffordK is offline
Old 01-18-20, 08:24 AM
UsedToBeFaster
Quoted: 125 Post(s)
And for my next trick. Pull my finger ...
That was a flop wasn't it.
But it's interesting that the 32mm tire actually blows up to be *taller* than the 40mm tire. This is significant to me, as tire height (for cushioning of road noise) is more important than width.
Do manufacturers assume that width is a surrogate for height? Unless your riding off road, then width is not that an interesting measure of a tire.
Old 01-18-20, 08:40 AM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10943 Post(s)
Liked 7,469 Times in 4,179 Posts
Tire depth 'cushions' road noise independent of width?
mstateglfr is offline
Old 01-18-20, 10:52 AM
CliffordK
CliffordK's Avatar
Most bicycle tires have a generally round casing profile. Thus when you're turning it presents a fairly uniform surface to the road.
Cars tires get a flat profile by using fixed length circumferential belts around the tire. Thus, the tires are also marked with a width to height aspect ratio.
I hadn't realized those flat profile tires were being used on bikes. I'm trying to imagine the cost/benefit of that.
