Help identify mystery Romic frame.
I found this mystery Romic frame on the street, dumped on a trash pile that looks like it was an abandoned fixed gear conversion as the gear hanger has been chopped off. I could just make out the remains of a decal with "....ic" and a google search of brands led me to Romic, which matches the decal exactly.
It had a Campy headset (no holes so not record), a Campy Strada crank (just the 39 tooth gear), 3TTT stem, campy bottom bracket and a few other sundry parts that look non-standard. The head lug is (I think) BMC brand and the rear drop-outs Shimano SF.
The top tube is about 54 but the seat tube is much longer at 59 c-top.
This looks like it makes it a Model 75 Racing but the cable guides on the bottom bracket are "on top", not under.
So, my question is, what model is it?
And what is the frame material? (Reynolds 351? Tange?) or how can I tell?
There's site called velocals which sells re po decals which should bring it back to new. I'll re-paint it as it is rusting away so what colors are original? It looks like it was a burgundy red originally. I will paint with a rattle can and coat with SprayMax 2 pack clear coat which I've used before and looks great.
thanks for any help!
Stop reading my posts!
Quoted: 1440 Post(s)
Liked 1,057 Times
pics are too blurry for me to tell whether it's an "exact match" to that decal or not...but if it's as you say then
A, What a shame it's been treated like that, drewed and badly rattle-canned !
B, Ray G. used Reynolds 531 almost exclusively, so I'd bet that's what this is built with. (Edit, Just looked at the CR site and it says he used Tange #2 and even "hi-ten" tubing which the writer says was plain gauge 4130, I've only seen his frames with 531 stickers)
C, the headlugs might be Bocama (as you say) which is abbreviated BCM, not BMC (British Motor Corp? )
The headlugs are bocama (BCM), not BMC as I originally wrote. Although I can't positively identify which Romic it is, I've read that Ray customized his frames somewhat according to customer demand so it may be a one-of.
That said, I am going to paint it and want to put the original tubing decals on it so does anyone know how to identify the tubing on a frame so I can put on the original tube decal? It could be Reynolds 351, Champion or Tange according to Romic lore.
It weighs 2100 grams completely stripped and the dimensions match the Model 75 size 23.5. The fork is also unknown with unmarked lugs.
Liked 1,057 Times
if you're lucky you might find the tiny stampings in the tubing itself that says "reynolds 531 DB" but it's tiny and faint, usually near the butted ends. The other clues can be fork: any marks on the steerer, usually a Tange fork is so marked and would be strong clue toward the entire frame being Tange, but not always. If it has old "Imperial" blade dimensions (cross section at top) it also might be more likely 531 blades.
There are no frame stamping anywhere and I've now stripped all the paint off for painting so I would have seen any. The fork steerer has stamp on it "3G" in a semi ellipse. I googled this and found no matches. Anyone know what it means?
Keener splendor
The decal you show on the downtube is unmistakably Romic. Free in a trash pile is pretty good for a handmade frame, provided it's straight or pretty close.
Romic made several models at any given time from touring to racing. I don't know what yours is or what the tubing is. There likely would be a faint 531 on the steerer tube on the fork some place. The other option is to chase that serial number.
Bikes: A few ;)
Yes, absolutely a Romic decal, but the serial number is odd. Either way, nice find! The Velocals Romic decals are gorgeous and perfect, I used some for my restoration.
Quoted: 789 Post(s)
Liked 1,739 Times
Very nice frame shame about the current condition seeing a frame this nice in this kind of condition just makes me sad . As for the tubing seatpost diameter, BB details and better photo's of the frame details would be a big help.
I finally finished painting this and built it into a nice single speed with lay-about parts and gave it to a friend about a year ago. The paint came out OK using rustoleum and Spray Max 2 pack clear coat and it has held up pretty well.
Quoted: 243 Post(s)
Liked 172 Times
I am looking for info about the Romic bikes and found this thread.
The serial number of your bike is the 97233076.
Coming from the end should be two digits for the year (76), two for the day(30) and two for the month (23 ????). And the first digits for the number of the bike(97).
Where am I wrong?
Or maybe 76 - year, 30 - day, 3 - month and 972 the number of the bike?
Who can help me?
I am trying to understand the s.n. : 1403412187
thanks
Where am I wrong?
Who can help me?
thanks
1992 Torelli Nitro Express; 1972 Claud Butler.
Bikes: '76 ROMIC Touring Pro 100
Quoted: 16 Post(s)
It is a Romic...Just a bit older than mine.....it is frame number 972 ...built march 30 1976....97233076......
Bikes: 65 Frejus Tour de France 68 Frejus corsa 72 Legnano 75 Frejus Professional 74 Paramount 74 Super Mondia Special 77 Raleigh Grand Prix 83 Vicini 87 Nishki International 74 campania pro 71 schwinn sports tourer 75 Romic 100 81 Miyata 900 74 Miyata Eddy
Quoted: 12 Post(s)
Liked 13 Times
https://www.google.com/url?sa=t&rct=...V0qywGgdaa-Xuc
its march 30, 1976 and only the 972 bike ever made
riusx
10
04-12-16 09:45 PM
jmaurer
6
02-12-16 06:54 PM
ferkovacska
Classic & Vintage
10
02-07-16 11:35 AM
stevek1ng
10
03-23-13 11:37 AM
