The give and take (mostly give) world of C&V weight weenie.....
Quoted: 1645 Post(s)
Liked 838 Times
It's been raining non stop here in the bay area lately, so, I decided to do a weigh in update on my Vitus Carbone weight weenie "living" project yesterday.
Dang!,..........I thought I got it down to the low 16 pound range, but I guess the Roval aero wheelset is not that light after all, at least, compared to my GEL280/Campy Record wheelset that was on the bike last year. I thought that the lighter Ti Flite saddle was going to compensate. But the bike is pretty much where I had it weight-wise when I had the GEL280 wheelset and Turbo SLG saddle on it last year,..... so no weenie progress....... at 16.73 pounds....from a previous weight of 16.75 pounds.
Well, I guess, at least, the bike looks better with the Rovals and Ti Flite....plus a bit more "Tout French" with the wheelset.....
Only thing I can think of adding to this project is a Stronglight Ti BB, if I can ever find one, but breaking into the 15 pound weenie zone is not looking promising.....well maybe if I use my lighter, spare Stronglight 106 crankset, find a Regina America Suoerleggera chain, a JPR headset and a CF bottle cage added into the recipe, it might still happen??
A C&V weenie project is just never done!
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,444 Times
That is a beautiful build! What brand are the tires?
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
That's a swell bike, but the other reason my bikes have ladies' names is because you don't ask a woman about her weight.
Liked 838 Times
Tires are Schwalbe Milano tubulars (discontinued). Used to be my favorite tires, as they are very light, despite not having latex tubes.
My current favorite is the Vittoria Corsa G tubulars. More expensive but the ride on them are like 10 times better And much faster.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,057 Times
You need to trim those cable ends. 0.3 grams off that front brake at least.
Neat bike. I liked those a lot more than the dural version. It made me think BITD that maybe this carbon stuff had a future...
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
Gorgeous bike! If you really, really want it to weigh less than 15 lbs., lose the front derailleur and associated components. With careful cog choices it can have almost all the gears you'll actually use. Or put a carbon fork on it. I'd just call it close enough the way it hangs!
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
I see fluting on that seatpost... unless the seatpost also needs to be vintage-correct, you might save a few ounces with a Kalloy Uno seatpost, trimmed to length: https://www.amazon.com/Kalloy-Uno-Se.../dp/B00VSDKYZE
Liked 838 Times
Maybe I could have the shaft milled down internally, but I don't think that there's that much material left to mill down, because of it's small OD.
Liked 2,571 Times
Thanks for the suggestion, but, actually, I'm stuck with the Rubis branded, original to the bike, seatpost because of its diameter at 23mm and the proprietary milled flat at the back of the seatpost shaft, that interfaces with the seat lug, bearing tipped grub screw.
Seek the omni racer bottom bracket. That will get you under. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F223212120459
Quoted: 18398 Post(s)
Liked 4,522 Times
These have been floundering on E-Bay for quite some time.
https://www.ebay.com/itm/Campagnolo-...e/273663058018
I thought they were carbon rims, but I guess they're carbon spokes.
Liked 838 Times
Seems like they were just produced for a show bike. But surprisingly, there is some brake pad wear evident on those rims, so they are/were "rideable".......but, do I have the 400+ bucks for those cool wheels at this time,...... unfortunately, or maybe, fortunately, no.....
Quoted: 350 Post(s)
Liked 276 Times
Remove a couple chain links, drillium the chainrings, millium the stem, shorten the seatpost, swap to Benotto tape.
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
Was there ever a French alloy cluster?
Liked 838 Times
I guess, per some suggestions, I could go "Stage 3" weenie and do customizing work like drillium and "shaving down" components But that might take the bike into the unridable "dark zone"?? And drillium is so subjective and highly dependent on the taste, skill and talent of the one, actually doing it. I doubt if my plasticky Dremel drill press us even close to being up to the task..... but who knows, maybe with some prodding and a small investment in equipment and time, I might eventually try it.
"Darkest" stuff I currently have on the bike are the CLB "Dural" (aluminuim) brake cable casings. At least the front brake still stops the bike ok, but the rear is so mushy because of casing compression, that it is only marginal at best.
Liked 838 Times
Do you mean freewheel?
Definitely,..... Malliard's full "Dural" freewheel. All cogs and freewheel body.
Thst's what I have on the bike and it was one of the most weenie components I installed so far. I think it was also standard on the PY10FC.
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,483 Times
Beautiful bike! I love the French components. The black and silver theme really works! Even if it doesn't lose another gram it's much lighter than any of my bikes will ever be.
Brent
Brent
Phyllo-buster
Liked 2,057 Times
It appears you have the CLB pro calipers? Super light IIRC. Just a beautiful bike.
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,026 Times
