View Poll Results: Good Idea
Yes
5
27.78%
No
13
72.22%
Voters: 18. You may not vote on this poll
Non crosschaining cassette concept
Quoted: 8 Post(s)
What do you guys think of this telescoping cassette concept I came up with?
It would eliminate cross chaining, and thereby:
1. Improve efficiency
2. Allow for more gears on the cassette then is possible with a derailleur
3. And theoretically offer smoother shifting
Is this worth pursuing or just too out there?
Thanks for checking this out
Paul
Paul
Paul
A big part of why derailleurs are so popular is that considerations like chain angle turn out to not actually matter that much. Especially with modern laterally-flexy chains.
Likes For HTupolev:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
There’s a patent for a sliding chain ring too
Quoted: 8 Post(s)
The problem is that it dramatically increases mechanical complexity.
But when you factor in that the rear derailleur is eliminated as well as the entire front shift gear, it comes out at least wash in parts count and weight, could be better in favor on the telescoping approach
Expired Member
Quoted: 3657 Post(s)
Liked 5,394 Times
Sell your idea to highest bidder! Shimano, Campy, SRAM. Retire and ride lots more
Call when the functional prototype has 10,000 flawless miles on it and all of your patents have been approved.
Otherwise: It's a combination of Hot Air and yet another answer to a question that no one asked.
-Bandera
-Bandera
Likes For Bandera:
Quoted: 641 Post(s)
Liked 1,517 Times
no rear derailleur? Don't quite see how that would work from the video. I see the smaller cogs fitting into the larger ones but you still need something to move the chain unless the chain is stationary and in that case, you need bits to keep the chain from moving and that would be more parts and plenty of friction.
Liked 2,946 Times
I like to be a xchain rebel. Sometimes little little determines if the terrain is ridden on or walked on.
-Oh Hey!
-Oh Hey!
Obviously this doesn't eliminate the rear derailleur, though. It makes it far more complex! You still need the pivoting cage to tension the chain and keep it flowing onto the cogs, and the simple parallelogram joint has been replaced by a complex sliding/telescoping mechanism within the cassette.
Good idea, and as already pointed out, one that has seen prime-time and drifted into history. Working out the details will be the key to success. There are a lot of new comers to the shifting market with hydraulic der. and knock-off shifters, but changing the way the whole thing operates is an interesting idea. If used with already available shifting mechs will be a bonus, because it will simply involve a hub design and not a shifter design. If all it takes is a couple of fixed jockey wheels and a hub with gear cluster, it could be a viable alternative. With that said, develop a working prototype and concept model, put a bunch of miles on it, accurately estimate tooling costs, and manufacturing costs, then sell it to one of the big 3.
No way would I take it to market myself.
The way I see it, the most problematic aspect with this concept is that the cogs would slide along where the actual torque transfer happens, which would make it quite tricky to make it work well and last long. It would most probably need some clutch mechanism of sorts, making it quite sophisticated and costly.
Advanced Slacker
Quoted: 2761 Post(s)
Liked 2,534 Times
https://youtu.be/aZaK-7sMiTQ
Paul
Paul
Also in the form shown, the cassette is going to take up just as much room on the hub as it does now. So I don’t see how this is going to allow more gears.
And why would this lead to smoother shifting?
Advanced Slacker
Liked 2,534 Times
I think what we are seeing here is all of the weight and complexity of an IGH, but without any of the benefits.
How is this an improvement over an IGH?
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
That seems a lot of engineering complexity to get rid of the very minor problem of cross chaining.
I think you would have to change the name of the non-cog part from derailleur to railleur, or maybe just rail.
Quoted: 8 Post(s)
Quoted: 8 Post(s)
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
That video illustration is physically impossible with current or near future engineering.
If the small cassette is small enough to slide into the big cassette, there will be a massive jump between the biggest cog on the small cassette and the smallest cog on the big cassette.
Quoted: 8 Post(s)
Disco Infiltrator
Liked 2,102 Times
I had an idea a while back for a 1x front ring that would somehow yaw to stay in line with each cog... like with maybe a CV joint. I could see how to control the yaw with a swashplate controlled by a second cable from the rear shifter, but was trying to figure out how to make it automatic. That's how I found and know about the patent for the sliding front chain ring.
This was before I had much time on a 1x system. Now that I do... it's fine, really. Not something that needs to be fixed. Especially if using a steel ring, like NX. The real problem with cross chaining has to do with rubbing on the FD, and ghost front shifting due to skate in small/small gears with short chain stays, and both are better on 11 than 10 speed because they moved the rings further apart and the chain is narrower.
Genesis 49:16-17
Genesis 49:16-17
Quoted: 8 Post(s)
The complexity is going to be immense. The part about telescoping the cassette is only half of the equation. The other part is going to be adjusting the position of the upper jockey wheel as you change gears ( though this may become easier with electric shifting)
It allows for more gears because there is only so much of a cross chain angle possible before the chain will chatter at the exit point of the cassette sprocket of fall off the crank sprocket. Also removing the derailleur gains about an inch of side clearance
It could have smoother shifting because without cross chaining cogs could be ground down much more to create easy transition shift points
Liked 2,011 Times
Suppose the big cog on the small cassette is the 21t and the small cog on the big cassette is 24t. Look at a 21 tooth cog and look at a 24 tooth cog. Can the 21t cog even fit within the outline of the 24t cog?
Quoted: 8 Post(s)
Typical mountain bike cassette, let's say 11-42: 11-13-15-17-19-21-24-28-32-37-42.
The image attached is a 21t with internal clearance for an 18t
Quoted: 8 Post(s)
