More relaxe/upright riding on track bikes like Kilo TT?
Old 04-27-13, 06:23 PM
Leo_Rides
Leo_Rides's Avatar
Hey Y'all,
I'm a n00b here (and to biking). Going to get a bike for myself and my lady to cruise around the city on warm sundays. Maybe use it for the odd commute too. Thinking about a Kilo TT due to it being available for 350ish and also it looks beautiful.
I know these bikes are typically made for a somewhat agressive posture but is it possible to set them up for a more relaxed & upright ride? I see a lot of hipster types riding around pretty upright on gorgeous FG/SS bikes... is it as simple as getting a frame that's a bit bigger/smaller than the 'ideal' fit and then rising the bars a touch?
Thanks all!
--Leo
Leo_Rides is offline
Old 04-27-13, 06:39 PM
Huffandstuff
Huffandstuff's Avatar
Quoted: 16 Post(s)
Get a bike that has the top tube you need(cant link fit calc on my phone) then either turn the stem up and keep a healthy amount of spacers and you should be fine.
Huffandstuff is offline
Old 04-27-13, 06:43 PM
GMJ
Would you just look at it
GMJ's Avatar
Bikes: good ones.
Quoted: 21 Post(s)
Liked 5 Times in 2 Posts
Get some mustache bars.
For ultra-upright, rotate stem 180*.
GMJ is offline
Old 04-28-13, 03:27 PM
Bikeforumuser0017
Goofy Goober
Bikeforumuser0017's Avatar
Stingray handlebars anyone?
Bikeforumuser0017 is offline
Old 04-28-13, 03:34 PM
hairnet
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 352 Post(s)
Liked 27 Times in 18 Posts
You can but why not get something actually made for more upright posture? It's no fun sitting upright and riding on hard 23mm tires. At least something like the Kilo WT lets you use big tires.
hairnet is offline
Old 04-28-13, 05:56 PM
FakeFuji
FakeFuji's Avatar
A conversion sounds perfect here, relaxed geometry and usually quite a bit of clearance
FakeFuji is offline
Old 04-28-13, 07:22 PM
SSbalt
SSbalt's Avatar
I ride 25c on my townie and find the ride pretty comfortable , but to each their own.
SSbalt is offline
Old 04-28-13, 07:41 PM
gregjones
gregjones's Avatar
Bikes: K2 Mod 5.0 Roadie, Fuji Commuter
Quoted: 23 Post(s)
Just to run to the store and back I had 28s then went to the 25s that I am running now. As soon as they start showing wear it's back to 28s.
I swear that the backside "sees" a bigger difference than the little bit that the eyes do.
I'm thinking about going ahead with a 28 on the rear. That's where most of the weight is. The rear does most of the work and that is where I seem to feel the biggest difference in the tires. The front tire doesn't do much more than keep the fork legs from digging into the pavement, until you turn.
gregjones is offline
Old 04-28-13, 09:19 PM
Philasteve
Philasteve's Avatar
Bikes: Surly CreamRoller. 98 Giant Rincon. SE UVT
Quoted: 5 Post(s)
Liked 12 Times in 9 Posts
I ride a Surly Steamroller, I just flipped the stem and put on 1 1/2" riser bars. Super comfortable but if you don't want risers you can get townie mustache bars or something similar.
Philasteve is offline
Old 04-28-13, 09:45 PM
calv
Painfully average.
calv's Avatar
Bikes: Caad10 / All-City SP
Liked 4 Times in 2 Posts
Agreed. But there's no denying that a bigger tire usually feels much better.
calv is offline
Old 05-01-13, 12:34 PM
Leo_Rides
Leo_Rides's Avatar
Thanks for all the responses so far!
I don't particularly like moustache bars aesthetically and heard they're a bit cruddy on the wrists, so would like to avoid if possible.
I'm gonna try and get to my LBS this weekend to try out a couple of track/FG/SS style bikes to see what frame size feels right. I used the Competitive Cyclist Fit Calculator which was recommending me a 61cm (C-T) frame for the 'French fit'. Seems a little high to me (I'm 6ft / 183cm tall with an 34.6"/88cm inseam)... I'm guessing maybe a 58 would be a good balance... we shall see!
Thanks again!
--Leo
Old 05-01-13, 12:56 PM
seanifred
seanifred's Avatar
make sure you did the fit correctly.
seanifred is offline
Old 05-04-13, 05:44 PM
Leo_Rides
Leo_Rides's Avatar
Visited my LBS today. I know my size is definitely in the 58cm region now...
Tried about 5 bikes out. Three things I remember the most:
- Most comfortable ride was Linus Roadster Classic although the moustache handlebars + lack of hand brakes kinda suck. Also, probably not the best quality I could get for $450 though, right? I *think* I tried a Gaston too although felt a little unstable in terms of steering (weight on hands + moustache bars)...
- A 2nd hand road bike (with gears + dropped bars etc). I remember this because I liked how lightweight it was but all my weight was on my hands which was v. uncomfortable and not cool for a chilled out ride in the sun!
- Biria SS bike which looked super sexy. It was whisper quiet and felt the right balance of solid + agile: https://www.biria.com/bicycle/single-speed/fixed-gear (looks 10x better in person). Unfortunately, they only had this in a 55 frame which definitely felt too small. The stock grips were like pine cones and also I felt like too much weight was on my hands.
So where my thought process is netting out is....a little confusion! I've tried googling (and looking on these forums) but I'm not sure on the process and expense of trying to make something like the Kilo TT a more upright ride (which apparently has an aggressive geo). Spacers/Risers? Flipping the bars? Getting a shorter stem? + a different type of handlebars?
On the one hand, I understand that I'm trying to kinda fit the square peg into the round hole... but I'm drawn to the fact that getting a TT for $400 from BD means getting a higher quality bike than spending $400 or $700 on something like a Linus at my LBS.
Advice, my good Lords and Ladies?
Old 05-05-13, 12:11 PM
LeosLeader
Has Brakes
I think your looking for more of a road geo. The Dawes SST Steel has a relaxed road geo from what i can see. (Also Chromoly Steel)
The Biria is high tensile steel, which is meh. Not comparable to the Kilo TT.
The Linus just says steel, not really looking into it much but not sure if its Chromoly or not. I have seen a few Linus bikes at a LBS and noticed rust. And they are sitting inside....
LeosLeader is offline
Old 05-05-13, 06:51 PM
Leo_Rides
Leo_Rides's Avatar
Hey man, thanks for the advice. The SST gets slammed in this thread: https://www.bikeforums.net/showthread...awes-SST-Steel
- the Windsor bikes are recommended instead. Do you think that's accurate or that as a n00b, it's not going to matter a lot to me and that I should think of it as $250 being a good price for a CroMo frame and the savings can go towards upgrades?
Linus Roadster Classic definitely was the most comfortable position to ride in (the bars were pretty high)... but yeah, I don't wanna get a $500-$700 Linus that's going to need handlebars swapping out anyway (to non moustache) and isn't a CroMo frame....
So, with any of these track kind of bikes, I'm likely going to want to get a shorter stem (and or angled upwards?) plus swap out the handlebars (what kind?) and brakes (what kind?) and maybe raise them somehow too - although the guy at my LBS said it'd be threadless and thus tricky to raise... any advice here would be very much appreciated too!
Old 05-15-13, 12:23 PM
Leo_Rides
Leo_Rides's Avatar
Ok, I think I've found the solution..... a bike that I can't find anything about online, anywhere :/
Dawes Streetfighter (available via BD)
https://www.bikesdirect.com/products/...eetfighter.htm
Is this an SST Steel but with riser bars? If so, this is the right bike to get.....right? I'm a n00b, I don't want to spend a ton, I want a SS that has the sleek aesthetic of a Track bike but is a nice relaxed ride for lazy Sundays with the girlfriend.... I'm guessing most of the $$ go towards the frame and eventually all the crappy components, tires etc will wear out and I can replace bit by bit with better stuff...
Good idea or bad idea?
Campag4life
Triathlon
14
03-20-13 05:32 PM
Oakenlols
Singlespeed & Fixed Gear
9
08-12-11 03:08 PM
Steezie
27
04-18-11 09:22 PM
patthepunk
4
06-18-10 01:32 PM
Noir Lethal
88
04-08-10 05:12 AM
