Did I kill my motor?
Old 10-28-07, 02:34 PM
lookingelectric
I have a cyclone motor that I usually run with a couple of 28V batteries in parallel. The person who had it before me ran it at 56V, so I tried moving some of the batteries into a series configuration so that I could produce more power. I took this on a steep hill and the motor went off partway up the hill.
I put the system back into the 28V configuration, gave it an hour to cool down and tried it again. The motor gave a little jerk and then stopped.
Did I kill my motor? Or is it something else?
lookingelectric is offline
Old 10-28-07, 03:00 PM
Marrock
Marrock's Avatar
Sounds like it's nice and crispy now.
Marrock is offline
Old 10-28-07, 06:34 PM
bikingbrit
You probably killed it! If you double the voltage the motor will suck twice the amps. This means FOUR times the power/heat. Most motors will not tolerate this for long.
To be sure, bypass the controller (i.e. connect the motor directly to the battery). If the motor now spins, the controller is probably fried. If still dead it's the motor. Of course you have already checked for blown fuses, right?
bikingbrit is offline
Old 10-28-07, 06:45 PM
cerewa
put our Heads Together
cerewa's Avatar
Bikes: a mountain bike with a cargo box on the back and aero bars on the front. an old well-worn dahon folding bike
To look on the bright side, this could be a great opportunity to rebuild an electric motor from its component parts.
Assuming the motor is broken, which isn't a sure thing if you haven't eliminated controller/fuse possibilities.
cerewa is offline
Old 10-29-07, 12:18 AM
pengyou
If worse comes to worse you can always drill some holes in it and use it as a coaster for your coffee table
pengyou is offline
Old 10-29-07, 12:30 AM
JeanCoutu
ǝıd ǝʌol ʎllɐǝɹ I
JeanCoutu's Avatar
Well, on power-assist people have been discussing external controllers on these things, apparently the built-in one can pop...
JeanCoutu is offline
