Hills: Mash or Spin?
Bikes: 1980 Trek 510 owned since '81 BLINGED; 20?? Speicialized Secteur; 201? Trek Excalibre Bafung coverted; 20?? Surly Cross-Check
Quoted: 7 Post(s)
I'm 67; I am a non-racer, have been a tourer, commuter, and now exclusively recreational rider. I've got 50% or so lung capacity due to 40+ years of Bad Life Choices(TM). I gave up electronics when the power meter wouldn't stop lauging.
But I still ride 20+ miles 3-5 times a week.
Lately, I've been riding my version of hills, +- 1500 ft in 20 miles. It's not easy, because I go into COPD hypoxia if I push too hard, hard being spin too much or mash too hard. Either way, I'm climbing at 5 or 6 mph up not too steep (5-10% [?]) grades.
It seems to me that mashing (39/30+ at really low cadence) is easier than spinning (30/30+ at a less-low cadence). High-cadence being maybe 70+ rpm, which I can do pretty easily (53/20+) on the flats at 12-14 mph. I am now no longer afraid of these 20 mile 1500 ft rides.
I would like to go on longer rides (30+ miles).
What do you think? Is mash or spin the better "training" strategy?
Both, if it's a long Hill, I will alternate between sitting in the saddle and spinning, and getting out of the saddle, putting it in a bigger gear and cranking.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Quoted: 43 Post(s)
Liked 31 Times
I'm 69 and have a heart condition. Doc tells me to keep my heart rate under 140 and I do exactly that. I spin mostly, sometimes mash, and sometimes stand and mash but my heart rate dictates everything. If I get down to 3mph with a high heart rate, I'm walking .
Seems to me a combination of spinning and mashing might work best. Mashing could build up leg muscles to make climbing more efficient, and spinning lets your legs "rest" while working your cardio system.
Either way, pay attention to your doc and your body and keep riding. I'm impressed with your dedication to riding despite your medical issue. The real experts will be here any minute . . .
Likes For justslow:
The downside of mashing is the potential for knee problems:
https://www.roadbikerider.com/will-b...l-my-knees-d3/
Likes For Greenhil:
Quoted: 1743 Post(s)
Liked 1,280 Times
I start with a cadence that is comfortable. I will go up or down the cogs based on terrain and what my legs are telling me.
Likes For bruce19:
Quoted: 822 Post(s)
Liked 1,955 Times
Technically, if I have to "mash" I am not pedaling correctly. It is more about engaging the glutes out of the saddle and letting gravity work for me.
Bikes: Voodoo Hoodoo, Linus Libertine
Quoted: 106 Post(s)
Liked 15 Times
Whatever is comfortable. The most important is that the pedals turn with low effort. How fast they turn doesn't matter.
Power = torque x rpm
Keep rpm low to keep power low and conserve energy to last longer.
Higher power = higher rate calories of burned = more carbs burned = lasts shorter.
Third World Layabout
Bikes: Cannondale F900 and Tandem
Quoted: 397 Post(s)
Liked 32 Times
I do both. If the hill is long, I like to sit and granny up it, but if it is short, I tend to just stand up and power over it, knowing I can recover on the other side.
just another gosling
Quoted: 3885 Post(s)
Liked 1,938 Times
Spin. The cadence range you give is appropriate for us duffers. A good rule for short rides is power up the short hills, whatever is fastest and spin the big hills. On long rides, spin all the hills. On long climbs, I stand for a bit every 10 minutes.
Results matter
Results matter
Likes For Carbonfiberboy:
feros ferio
Quoted: 1390 Post(s)
Liked 1,322 Times
A lot of it depends on your gearing. Bottom gear on most of my road bikes is around 43-45 gear-inches (45/28, 42/26, or 38/23)); on the mountain bike, the middle ring gets me down to 37 gear-inches (40/28). I lean toward spinning (90-120 RPM) most of the time, but end up mashing when the grade gets too steep or when I have to slow down and have run out of gears. The only downside I can see to using a low gear is that I can start to lift the front wheel if I gear too low on a steep climb.
Quoted: 3221 Post(s)
Liked 2,048 Times
Not sure if it was Sean Yates or Stephen Roche who was asked his secret to climbing well, stating “I put it in the big ring and spin”, or words to that effect.
I spin till I’m dead then I mash.
Quoted: 892 Post(s)
Liked 2,052 Times
There's some rule of thumb that says if your legs burn downshift (more spinny), if your lungs burn upshift (more mashy). Like all rules of thumb, take it with a grain of salt.
On the other hand, walking gives your butt a break.
Is mash the same as grind? Or is it a word for being out of the saddle?
I've always used rhythm when cycling, 1,2,1,2 left/right leg at a certain tempo if the tempo speeds up I go up the gears if it slows down I go down. Never had a computer on the bike so have no idea how what my wattage is I just think it would take me away from enjoying the spin.
Liked 1,938 Times
To give a concrete example of what might work for the average person, I try to climb at about 78 rpm, somewhere in there, depending on if the exact gear matches the exact slope, so a few beats on either side of that are acceptable for me. Say 75-85. In my mid-50s, my lowest gear was 32 g.i. In my mid 70s, my lowest gear is 23 g.i. Yeah, we get slower as we age.
That gearing has enabled me to do 3000' climbs at a steady pace and to do 250 mile day rides with 15,000'. It's not a slow pace, just slower than really strong folks, about in the top 10% of my age group. Too many people gear too high and think a big cassette means you're weak.
It's too bad that triples have gone out of fashion. It seems that the more money one spends on a bike, the higher are the standard gears that it comes with. Seems like it ought to be the other way 'round, since the older we get, the more disposable income most of us have.
Results matter
Results matter
Quoted: 8261 Post(s)
Liked 8,996 Times
Liked 8,996 Times
I do have a 28x46 on my mountain bike and it's a one-by.
I like to spin but my main bike has 34x29 low and I'm 200 pounds so I end up doing some grinding.
Liked 2,048 Times
Modern compact doubles can be set up with 34x34 low gear. Campagnolo even has a 32x34 in the Chorus group, that's lower than anything I ever had on a triple.
Liked 8,996 Times
My C-Dale gravel bike came with a 46/30 crank and 11-34 11 spd cassette. That’s a 22 gear inch low which is almost as low as my touring triple. I could go lower as well with an 11-40 cassette. My triple 24/36/46 with a 9 spd. 11-34 has about 14 non repeating gears, the 2X has 15.
Some people on the forum think triples are coming back.
Quoted: 4559 Post(s)
Liked 2,802 Times
Last year I switched from spinning around 90-100 rpm to a more old school cadence of 60-75 rpm.
I no longer have the cardio for spinning to be efficient. I'm not racing consecutive days for three weeks. I'm not taking EPO, or blood doping. All the stuff that makes spinning more efficient for younger athletes in peak condition.
Slower cadence works for me. My heart rate stays lower. My legs are stronger. No injuries -- I stay within a reasonable effort. I'm not trying to grind a 52/13 gear up a climb. Depending on the bike my easiest climbing gear may be 42/28 or 39/28. Usually I'm in the 24 or 25 rear cog, even if I'm tired. But the 28 is nice to have after long, hot rides.
See this 2019 article .
Ideal cycling cadence: new evidence why amateurs shouldn’t pedal like Chris Froome
Scientists reveal more evidence of how pedalling a low gear at a high cadence could waste a cyclist's energy
"New experiments from the UK-Japan research collaboration have revealed one of the factors which makes that kind of pedalling wasteful.
“When the cyclists pedalled close to the ‘ventilatory threshold’ at 90rpm we were able to see the oxygen level in the thigh muscles had fallen, compared with lower cadences at the same exercise intensity,” says Formenti. “Participants’ heart rates increased by 15 per cent, yet their exercise efficiency actually decreased.”
Quoted: 800 Post(s)
Liked 218 Times
FWIW, I have posted about riding on the moderate hills of Metro Boston.
My above schedule is partly based on the need to incorporate intervals in training.
My hills are of a suitable length for those intense intervals,As @crtreedude mentioned above, I consider my ability to recover quickly as an informal indicator of fitness (along with intensity (speed) of the effort, and resting heart rate).
I pedal hard and fast on the downhill preceding an uphill grade to conserve my downhill momentum as I go uphill. One useful tip I garnered from Bike Forums is to jump two gear levels up when rising to stand on the pedals and mash.
A caveat about hillls though:
I had posted about my last mountainous road ride in Pennsylvania in 2015:
.Either way, I'm climbing at 5 or 6 mph up not too steep (5-10% [?]) grades.
"Cadence"
I’m a 40+ year long cyclist and I ride mainly for fitness. My training tool is the Relative Perceived Exertion (RPE) Scale, and I use cadence to chose gears to maintain my desired exertion..
This year though, I decided to go for speed (intensity), and I use the semi-quantitative, standardized, but personally relavant system of (Borg’s) Relative Perceived Exertion (RPE) (link).
My basic training is to ride at my RPE of 50% for six miles to warm up, then cruise at an RPE of 60%, and do intervals (on hills) at 70%. I try to change gears to maintain a cadence of about 85-90 rpm on flats and rolling hills, and about 60 to 80 rpm on harder hills, to maintain my RPE.
Shift up to higher gears as the cadence rises, and shift down as the RPE increases.
The RPE scale ranges from 6 to 17, with descriptions of the intensity. Multiply the RPE by 10 is the approximate heart rate. Jim's scale is the equivalent on a 0 to 100 scale, easier to think about:
RPE = 7, very, very light... Jim's scale = 20 to 30
RPE = 9, very light... Jim's scale = 30 to 40
11, fairly light...50 (my usual happy-go-lucky pace without thinking about it)
13, somewhat hard...60 (I have to focus to maintain)
15, hard...70 (I start breathing hard at about 30 seconds)
17, very hard (lactate threshold; breakpoint between hard but steady breathing and labored with gasping)...
18, 80 (my predicted max HR)
19, very, very hard...90 to 100.
...I'm fortunate to be a daily year-round cycling commuter early in the morning, with a pleasant, minimal one-way distance of 14 miles, easily lengthened during the nice weather. My commute is really my only chance to train.
I had long rejected the idea of intervals because getting on the Road early is a challenge itself, and I didn't want to lose my enthusiasm by punishing myself too much. That fairly simple regimen described above seemed tolerable, and for the first two days so far was tolerable and somewhat enjoyable....
Intervals on the road during a defined commute are more variable than what one can do on a trainer. I have quickly learned that I must watch out for traffic and not pay too much attention to the stopwatch on my cycle computer. Sometimes the stopwatch times out during an interval and I have to reset. Often the terrain is out of synch with the interval, e.g. downhills on the intensity interval, uphill on the rest interval, with stoplights interspersed.
As mentioned above I just use “Rating of Perceived Exertion” (RPE) as my monitor...I consider my usual happy-go-lucky pace is at an RPE of 50 (out of 100), and previously sometimes tried to ride most of the commute at a steady 60. So I ride about 6-8 miles at my usual pace (exertion) to totally warm up, then I estimate my RPE during the intense one-minute intervals to be about about 70-80. I then revert to my usual RPE of 50 for the remaining 2-3 miles
"Riding versus Training"
One other thing I learned during my trial phase of this training program is not to underestimate hills when doing intervals. I once was riding up a hill in too high a gear, barely pedaling to stay upright, and my chain fell off the front cog and got wedged between the seat tube and pedal crank.
I had to pull so hard to remove it that I bent a link, causing the chain to skip with each rotation.
…Compared to the hills of Metro Boston, I consider that I rode over two mountains, shorter perhaps, but with grades as challenging as I had encountered in Colorado (but that was 35 years ago) .
There were also some steep backroad hills,
and I occasionally got stuck in too high a gear, saying to BD, “I gotta learn to respect these hills.”
Last edited by Jim from Boston; 06-21-20 at 02:23 PM. Reason: added new link to Borg's scale of RPE
Quoted: 800 Post(s)
Liked 218 Times
Speaking of recovery after cresting a hill, I posted to this thread. “Oh No! i just realized that i coast too much”
Coasting is not allowed among those who believe rides should be "sufferfests."
I often think the same thing when I find myself coasting, and as also posted above, using a cadence meter is a good motivator to keep pedaling. Furthermore if you track your average speed for a ride, pedaling downhill is an easy way to bump up the average.
As far as feeling "guilty" about coasting, I think to myself that I did have to pedal up the hill to be able to coast down, and maybe the respite is good for recovery.
A saying of Ronald Reagan from the 1980 presidential campaign strangely comes to mind as I coast. RR said, "I paid for this microphone, Mr. Breen."
I paid for this hill.
Version 7.0
Bikes: Too Many
Quoted: 1338 Post(s)
Liked 2,474 Times
I think you are doing great.
IMO, the mash / spin discussion is a fools errand to an extent. I think it is more about muscle composition, genetics, goals and health versus which is better.
I can spin up a climb or mash up a climb. Most of my riding is on the same routes and climbs day after day. So I try various methods. My legs like mashing up hills and I get some of my better times and average power. If I do a hill climb race, I will spin slower versus faster but I may vary the cadence as the grade changes.
The downside of mashing for me is muscle strain. So if I am on a bike tour, riding every day, too much mashing is not great. I will tend to gear down and spin more.
With respect to training, I do low cadence work where I will keep the cadence between 55 - 60 rpm. I do that for climbing and flat terrain. I will ride 54/11 on my time trial bike on flat terrain at 55 rpm to build strength in the time trial position.
My suggestion is to try both. There is one proviso and that is one must train to spin faster (one will not have immediate success) but one can always self select to spin slower.
Broom Wagon Fodder
Bikes: Fuji Supreme; Kona Wo; Nashbar road frame custom build; Schwinn Varsity; Nishiki International; Schwinn Premis, Falcon Merckx, American Flyer muscle bike, Motobecane Mulekick
Quoted: 52 Post(s)
Liked 64 Times
I do both depending on how I feel. When I mash I do it out of the saddle and it feels good to stretch. I usually do this on shallower climbs where I am moving pretty quickly. If it's really steep or I'm tired I spin. For years I was riding a road bike with a low gear of 34x26. That was enough to get me up the steepest hills round these parts. When I got a gravel bike with a low gear of 42x42 I never thought I could possibly use that. As it turns out I've found a couple of hills that I use it on. I could walk up that hill faster but I feel a lot better when I get to the top!
I usually mash a little bit at the start of a hill and then downshift a bit to keep my cadence where i like it. As the hill gets steeper then downshift again till I'm in my lowest gear and grind from there. I try not to waste too much energy in the beginning by mashing therefore shifting to lower gears earlier on. Pulling up on my pedals helps a bit also. Trying not to use all your energy on the hill but save it for the flats where you can go faster for longer periods of time is my motto...
