Rear Rack for Univega Sportour
Training Wheels
I am looking to mount a rear rack onto a 1981 Univega Sportour and am looking for recommendations. The wheels are 27", there are non-threaded eyelets on the dropouts, but no braze-ons on the rear seat stays (I plan to use P-Clamps or get a rack that has an arm to mount onto the caliper brakes). My major issue in finding a rack is that the rear dropouts are only about 5.25" apart. Most of the racks have legs that are 6" apart (like the Topeak Explorer) and while you can compress the legs to fit, I worry that it is a pretty substantial narrowing of the rack. The Racktime Eco Tour 2.0 that I was looking at recommends only going down to 5.6" wide (max of 6.8) in their tech drawings. The other criteria I have are: $50 or less, has an all flat portion on at least one end (so the Axiom Journey doesn't work), and at least ~4-5" wide (so the Axiom Streamliner doesn't work). Any suggestions given these constraints? Thanks.
Quoted: 809 Post(s)
Liked 1,022 Times
I like vintage Blackburn racks. Period correct too. That is my opinion.
Here is an example in black anodize:
Blackburn rack
Make sure you get all the small brackets and hardware that comes with the rack.
For flat end, I am not sure what you mean? Do you want a flat platform?
Blackburn rack
Likes For Velo Mule:
Training Wheels
Not as desirable for me because I want to be able to place slightly larger things on the top of the rack if I want to. If it curves up on one end, that is ok.
Thanks for the Blackburn suggestion.
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 345 Post(s)
Liked 175 Times
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
You could also use a Jaand Disc Brake Adapter. That will give you more space for the rack.
I would also suggest Ortlieb clamps over P-clips. They are easier to use and more robust.
That’s not original. They didn't come with a rack.
Stuart Black
Stuart Black
Quoted: 1627 Post(s)
Liked 630 Times
I don’t think I’ve ever installed a rack that didn’t have to be spread or compressed at least 3/8” on either side. I wouldn’t worry about that aspect of it. I mean, you're not even bending the aluminum (although you could get away with that, bending it a little bit, only once), you're just flexing it a little.
I had a vintage Jim Blackburn on my '81 SportTour, which I eventually handed down to an employee of mine.
Quoted: 809 Post(s)
Liked 1,022 Times
Go to C&V Sales here on BikeForums. Force has a number of racks that would work and be appropriate.
https://www.bikeforums.net/classic-v...ndale-etc.html
Training Wheels
Some racks curve up at both ends. An example is the Axiom Journey https://www.axiomgear.com/products/ra...racks/journey/. I'd prefer one that stayed flat all the way on at least one end so that I can rest something completely flat along most of the length.
Training Wheels
Aluminum racks aren’t going to compress very well. You might consider a steel one like a Tubus. It’s more expensive than the Racktime but they are steel and can be probably be taken past that 5.9” limit without having to worry about losing stength. A Tubus Cargo Evo goes down to 5.5” and would fit your other requirements well.
Good point. I will look into these as options. Thanks.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3884 Post(s)
Liked 6,478 Times
I'd look for an unfinished/unpainted vintage Blackburn with the fixed rear caliper bolt arm and hope it's scratched to hell so no one wants it. I'd spend fifteen minutes with some 80 grit and make it look brand new. I'd search craigs first. Look the low-level donor with bent fork, frozen seatpost, and the perfect rear rack for $40 obo.
Training Wheels
