Proper technique for spinning?
Old 07-21-11, 12:23 PM
EssEllSee
Kilo TT
EssEllSee's Avatar
So, I just finished my new bike and switched down to gear inches in the low 70's. My other bike was in the higher 70's, so I have been trying to work on spinning. Now there are a few hills here that totally destroy me, but I am working on it. When you guys start spinning fast, is your rear completely off the saddle with all your weight on the pedals? I notice if I spin really fast while seated, my body gets kinda bucked around. This question may seem stupid, but I'm new to spinning at faster RPM's and I wanna learn efficiency
EssEllSee is offline
Old 07-21-11, 12:28 PM
carleton
Elitist
carleton's Avatar
Quoted: 1324 Post(s)
Liked 43 Times in 37 Posts
The bucked around feeling is normal. You have to learn how to smooth it out. Instead of mashing down, try mashing down and back towards the rear wheel.
There are several pedal strokes. Like 5 or 6.
carleton is offline
Old 07-21-11, 12:30 PM
EssEllSee
Kilo TT
EssEllSee's Avatar
Ya, I kinda feel like my body is moving around all willy nilly - definitely not smooth. I can feel control coming as I spin more, but I want to be able to spin at 110 RPM and be smooth as silk. I'll keep in mind pushing down and back on my ride today.
Steev
Steev's Avatar
Check your saddle height. If it's too high your hips need to dip at the bottom of pedal stroke.
If your saddle height is good, the rest is technique.
People can usually spin much faster sitting.
Steev is offline
Old 07-21-11, 12:40 PM
carleton
Elitist
carleton's Avatar
+1
If you are bouncing before 110RPM, then something is definitely wrong with your saddle height. Most people usually start butt-hopping at 120RPM. There is a weird resonance at the frequency. It smooths out at 130 and higher.
Rollers help because you can focus on your pedal stroke without having to apply much force. You can also put your bike in a trainer and not attach the resistance unit. However, rollers are better because you need some small amount of resistance to get it right.
After you get the saddle height sorted, it simply comes down to practice, practice, practice.
carleton is offline
Old 07-21-11, 12:49 PM
boxerboxer
+1
I'm by no means a great spinner, but this makes a huge difference for me in smoothness at high RPM.
boxerboxer is offline
Old 07-21-11, 12:52 PM
EssEllSee
Kilo TT
EssEllSee's Avatar
+1
Saddle is fine, the bumping doesn't happen until very steep hills when I spin faster then I'm used to.
Old 07-21-11, 01:11 PM
carleton
Elitist
carleton's Avatar
Are you trying to go faster down these hills or keep up with your pedals?
If you are trying to keep up with your pedals as gravity pulls you faster, try to simply relax your legs completely.
carleton is offline
Old 07-21-11, 03:05 PM
dsh
Oh, you know...
dsh's Avatar
Bikes: '74 Schwinn Sports Tourer (Polo), S-Works E5 Team Festina (Chorus 11), Trek 2200 Bonded Carbon (Fixed), Trek 920 (7 speed IGH), Chesini Olimpiade SL (1x7)
Funny thing is, I concentrate almost entirely on the kick forward with my top leg while spinning.
True story.
dsh is offline
Old 07-21-11, 06:23 PM
TheBikeRollsOn
TheBikeRollsOn's Avatar
True story.
Interesting, I find that to be the weakest part of my pedal stroke.
TheBikeRollsOn is offline
Old 07-21-11, 08:10 PM
hwdxbassist
hwdxbassist's Avatar
Bikes: Affinity Lo Pro-madison(RIP)-specialzed bmx-
Good advice all around. Good job BF members.
How does one know if their saddle is to high?
hwdxbassist is offline
Old 07-21-11, 08:13 PM
Squirrelli
GONE~
Squirrelli is offline
Old 07-22-11, 08:15 AM
dsh
Oh, you know...
dsh's Avatar
I think that's probably why it helps the most to concentrate on it while spinning high cadences. I feel like it's the last thing most people worry about.
If you rode bikes as a kid, you know how to mash down. It's natural.
If you've climbed a hill as an adult, you know how to pull up. You do it unconsciously.
If you've done any kind of training to increase your power, you know how to scrape the bottom.
Those things always happen naturally by this point, so the last thing to concentrate on is the kick.
dsh is offline
Old 07-22-11, 08:36 AM
TheBikeRollsOn
Nail on the head. I need to work on my spinning technique, there aren't any big hills around and I never go fast enough.
Old 07-22-11, 08:43 AM
Steev
Steev's Avatar
You should have a slight bend in the knee at the bottom of the pedal stroke.
Get someone to ride behind you or watch you from behind on a trainer to see if your hips are rocking as you pedal.
Steev is offline
Old 07-23-11, 02:53 PM
cbresciani
cbresciani's Avatar
Bikes: Colnago C40 HP, De Rosa-Primato, Titus Ti FCR, MOOTS YBB-SL, Pogliaghi Pista
A really good thing that helps me to visualize a correct pedal stroke is to try and pedal in circles not squares, meaning you should feel the complete pedal stroke all the way around, not just at the top and bottom of the stroke.
cbresciani is offline
nicmos
Fitting Your Bike
7
04-14-15 01:54 PM
DaveLeeNC
General Cycling Discussion
11
05-24-14 03:10 PM
jyl
Fitting Your Bike
6
11-12-13 03:59 PM
FatBottomedGirl
Advocacy & Safety
22
11-19-12 12:14 AM
RiPHRaPH
Road Cycling
4
02-21-10 04:32 PM
