Thoughts on the All-New Cannondale SuperSix EVO Disc Ultegra groupset
Love 2 Ride
Hi everybody,
Today I saw the All-New Cannondale SuperSix EVO Disc with Ultegra groupset and I must say that it blew my mind. The frame geometry, craftsmanship, carbon wheels, groupset and Golden color truly amazed me.
Any opinion on this bike from users or people acquainted with this model? Pros? Cons? Any other brand/model similar to the All-New SuperSix EVO that I should consider?
I think value for money it's a good deal, considering the groupset, wheelset, brand reputation and novelty.
Thanks,
Rafa
Thanks,
Rafa
Link and photo assist.
I dig the color, the pressfit BB and TA front with QR rear are a con (I like them both the same). Tire clearance up to 28mm.
Quoted: 1218 Post(s)
Liked 298 Times
Hi everybody,
Thanks,
Rafa
Thanks,
Rafa
Anyways I am riding the 2017 himod di2. with the Hollowgrams. The only reason for Di2 is because it was less expensive to go that route than it was to buy the mech Ultegra and pick up a set of wheels. Well about same price, so I chose di2 over mech.
On 28c, It makes the chip seal roads smooth!
Quoted: 451 Post(s)
Liked 364 Times
Some other options in this general price range:
Canyon Ultimate CF SL Disc 8.0, full Ultegra R8000-series gruppo, DT Swiss P1800 Spline db wheelset, 7.6 kg--$2799
Orbea Orca M30 Team D, full R105 7-series gruppo, DTSwiss E1850 Spline DB23 TLR CL wheelset--$2999
Orbea Orca M20 TeamD, full Ultegra R8-series gruppo, same wheelset as above--$3299
BMC SLR02 Disc Four, full 105 R7-series gruppo, Shimano RS170 wheelset--$3199
Bianchi Aria Disc 105, full 105 R-7 series gruppo, Fulcrum Racing 618 Disc wheelset--$2900
and if you don't have to have disc brakes, you can into a Cervelo R2 with 105 R7-series gruppo for a mere $2400.
And the list goes on... There are tons of good options at or around the $3000 mark right now. I would recommend that you do a little research at this price-point and see if there is something else you like more. That Cannondale is, I'm sure, a great bike. But it does have older groupset components on it and at that price, again, there are some just killer alternatives. Just my take and your mileage obviously could vary. Good luck, whatever you do.
Liked 298 Times
just a correction here, Katsup totally posted the wrong link and bike picture.
The wheels will be a $1,000-$1,600 carbon CL Disc wheelset at 1446 gram stans tubeless compatible. DT swiss internals DT aerolite bladed spokes
So not the same wheels as the Orca M20 ($3,299 + wheelset put him back into the "all-new" supersix ballpark)
good list though.
Try this link https://www.cannondale.com/en/USA/Bi...ntid=undefined
and this Picture of the "ALL-NEW" supersix.
Likes For Metieval:
Quoted: 2112 Post(s)
Liked 663 Times
The confusion is the “all-new” Supersix Evo doesn’t come in “gold.”
Maybe, because Cannondale and all their color-ways, and who knows what color-ways they sell in different geographies.
Anyhow, the thing about the “Ultegra” drivetrain is it has an SI crank, FSA chainrings, and 105 cassette. If this bothers you, why?
(Full disclosure, my brand new frankendale “all-old” Supersix Evo has a Shimano Ultegra drivetrain, sort of, because Shimano can’t decide if the HG-800 cassette is Ultegra or not. If this bothers you, why?)
-mr. bill
-mr. bill
All major brand bikes are really good these days, you can't really go wrong. Also, the pricing is generally the same between brands when you compare like for like. The only concern I have the Cannondales is the PF30a BB. It may be just anecdotal, but Cannondales are a bit infamous for the dreaded BB creak. IMO, PF30 is down there among the worst BB "standards".
Liked 663 Times
-mr. bill
Lack of rear TA is pretty lame in this day and age. Pressfit BB really is bad. And both are features you will never be able to change.
Bikes: Canyon Endurace
Quoted: 1041 Post(s)
Liked 922 Times
I prefer my "groupset" to be complete. Nothing worse that seeing a Ultegra level bike being advertised at a certain price and then when you look closely there is an alternate crankset.
Expired Member
Quoted: 3649 Post(s)
Liked 5,382 Times
FWIW, it appears the bike actually has thru axles of a sort, front and rear. Something Cannondale calls Speed Release.
Liked 663 Times
And to continue with the confusion the "All-Old" SuperSix EVO DISC had a quick release rear skewer and thru-axle front. The "All-New" SuperSix EVO DISC has the Speed Release thru-axle.
-mr. bill
Liked 298 Times
The Person Responsible for the Cervelo BB is none other than Damon Rinard. That is now the Technical Director at Cannondale. Watch the video.... nitty gritty starts at 18:00 ish and the Real dirt is at 24:00 ish
Is there a connection to the BB issues of Cannondale?
Enough Lube will fix any BB creak, the question comes down to wattage loss. I have just always assumed stuff was dry. Now I wonder if their tolerances are to large.
FWIW, the video is educational. I have no idea what a technical directors job is. However If Cannondale hires that kind of an engineer, and Keeps him. Then it makes me question everything Cannondale.
Bikes: 1969 Peugeot PX10, 1992 Della Santa, Linus Roadster 8, Biria 700C ST-8
Quoted: 791 Post(s)
Liked 503 Times
So though axle is a way to handle disc brakes because they put different stresses on the frame. I get that. And they are not as convenient for wheel changes than the traditional quick release with rim brakes. I don't get that. It seems to me that since cars and motorcycles all got disc brakes then the bicycle builders have convinced people that we all need discs. Yes, I've heard all the arguments about wet weather etc etc. I would never spend that kind of money to get brakes that I don't need with through axles I don't want. Thanks.
Quoted: 850 Post(s)
Liked 344 Times
@OP, I personally think that PF30A isn’t the worst BB spec out there because you can use a Shimano, DUB or BB386EVO crank on it, in addition to Cannondale cranks, of course. The only issue is the availability of BBs, and I believe there’s a great selection of sleeved pressfit bearings, thread-together BBs and even one-piece BBs. You can get into the discussion of poor manufacturing tolerances that Cannondale has a reputation for but that has nothing to do with the design itself.
Some people recently were talking about how the non-hi mod old gen SuperSix felt “dead” compared to other carbon frames in its price range or top end carbon frames. I personally cannot claim to know the difference, but it’s worth test riding an EVO vs Hi-Mod to see if you notice a difference in responsiveness. Make sure to use the same wheels/tires across both.
Liked 298 Times
Mavic calls it Speed Release thru-axle.
And to continue with the confusion the "All-Old" SuperSix EVO DISC had a quick release rear skewer and thru-axle front. The "All-New" SuperSix Evo DISC has the Speed Release thru-axle.
Missing Video
-mr. bill
Missing Video
-mr. bill
Actually I have the rear wheel off my Supersix once in 2 years. that was to swap the schwalbe one to a Continental gp5000
6 seconds in 2 years?
Quoted: 850 Post(s)
Liked 344 Times
bleh..... I am changing a tube, or plugging a hole, or refilling with air. So I don't really think 6 seconds difference will be a hill of beans to me.
Likes For smashndash:
Expired Member
Liked 5,382 Times
Liked 663 Times
-mr. bill
Expired Member
Liked 5,382 Times
What's a delta?
Liked 663 Times
Sigh, on the All-old Supersix Evo, if you compare the Ultegra versus Ultegra Disc, the delta is $400.00. That gets you hydraulic discs and upgraded “race” wheels. All I’m saying is if you don’t like discs, don’t buy them. If you can’t get the combination of components from a manufacturer, look for another or buy a frameset and build what you want.
Quick release axles and “Speed release thru-axles” stay with the wheel when you repair a flat. Thru-axles don’t.
No amount insisting that I put the thru-axle right here will make the thru-axle be right there.
Wheel big, easy to find, Thru-axle small, easy to lose.
It’s Murphy’s fault.
-mr. bill
-mr. bill
Liked 298 Times
-mr. bill
-mr. bill
Again you are blaming the inanimate object for your personal actions, or your lack of actions.
Are cars also bad ideas? I mean car huge, car key small, how do you survive?
Expired Member
Liked 5,382 Times
OK, so delta=price difference, got it! Learn something here everyday!
