Campagnolo Hub Axle Diameters
十人十色
Can anyone tell me if Grand Sport and Nuovo Tipo hub axles are the same diameter? I know they are different lengths.
Quoted: 4722 Post(s)
Liked 3,038 Times
If I recall correctly, all Campagnolo axles are 10mm x 26TPI, with the exception of the solid axle Nuovo Tipo, which is 9.5mm x 26TPI.
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
十人十色
Actually, I'm not sure they are. I assume they would be as the GS rear hub measures 87mm across, and was made at a time when rear drop outs were 110mm apart whereas the NT hub is 89.6mm across and was made when drop outs were 120mm apart.
I have a front NT hub and the axle measures 8.8mm across and I have what I think is a front GS axle (sold to me as such) which measures 9mm acoss. The known rear NT axle I have is 9.9mm across.
十人十色
Old fart
Liked 3,400 Times
Rear axles
Front axles
十人十色
Old fart
Liked 3,400 Times
What vintage Gran Sport? Through the 70s and 80s, Gran Sport hubs were Tipo hubs. My edition of Sutherland's (4th) doesn't have information on the 1950s Gran Sport hubs, and the Campy catalogs of that period don't specify it.
十人十色
Early 50s. Old logo with more detail on the wings.
Quoted: 112 Post(s)
Liked 8 Times
The diameter must be measured at the thicker threaded part because on my 70's Record rear axle seems to be only 9mm at the smooth center part.
I want to get a longer axle at bikepro.com but their listing it at 9mm. Something is wrong as they list the front at 9mm also. We all know the front axle is smaller. I may phone them and ask because they do not have email contact!
At the page below, the Campi Record rear axle is:
9MM x 1 x 130MM
Is the 1 meaning 1 thread per mm ?
BikePro.com / Buyer's Guide / SRP Hub Accessories - Bicycle Parts at discount prices / the Buyer's Guide / Bicycle Parts at their finest! / Professional Bicycle Source / Bike Pro
9MM x 1 x 130MM
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 78 Post(s)
Liked 30 Times
9MM x 1 x 130MM
9MM x 1 x 130MM
You can get the axles you want here.
Wheels Manufacturing Hub Axles
Just cut to length, not difficult at all. I use these all the time.
Old fart
Liked 3,400 Times
Quoted: 3464 Post(s)
Liked 2,831 Times
My two pairs of Gran Sport hubs, steel center sections and accept quick releases are exchangeable with later Record parts. I would have to take one apart to reference the front hub ball bearing diameter.
Quoted: 1608 Post(s)
Liked 2,216 Times
Quoted: 78 Post(s)
Liked 30 Times
Liked 2,216 Times
LOL still a very spendy part for what it is. I guess you cann't get a soft cone at DQ for 5 cents anymore either! York Peppermint Patties are over a $1! Just 5 years ago I refused to even consider buying one for $.50!
Quoted: 78 Post(s)
Liked 30 Times
Liked 1,296 Times
Also, how much steep climbing using a very small chainring, all will affect the service interval before an axle failure occurs.
At 225lb with an 8-speed freewheel, this setup would be relatively fragile regardless of the frame's axle spacing.
The frame's inside spacing will affect the potential strength of the wheel/rim, but not the axle (assuming here that the axle spacers are set for minimum axle overhang using whatever freewheel has been chosen).
Quoted: 78 Post(s)
Liked 30 Times
Wheels manufacturing axles do not have a slot, making them much stronger than original.
