Which freewheel for my 85 Gran Turismo?
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 460 Times
The original 14-32 freewheel on my 85 Gran Turismo is making a creaking noise which
transmits to the frame.I have 2 old freewheels which I think will fit but not sure which one
I should use. The first one is a Shimano 13-24 6 speed and the second one is a Suntour
13-24 7speed. The chainring on the bike is a 30-46-50.
Quoted: 5888 Post(s)
Liked 3,472 Times
It may not matter to you but you will lose low gears with those freewheels. If the original freewheel was 6, you may get some chain rub going to 7. That can be dealt with but it is a potential issue. Personally, I’d try to service the original freewheel or find a larger freewheel than a 13-24 given that this is a touring bike.
Quoted: 932 Post(s)
Liked 1,319 Times
Changing from a touring freewheel to a racing freewheel on a touring bike makes no sense unless there are zero hills where you live. Send your creaking freewheel to @pastorbobnln for servicing.
Likes For polymorphself:
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 700 Times
The fun is looking at the gear calculators to see which freewheels give the nicest gear spacing and the most appropriate gears. Then comes seeing how it all fits. Perhaps a 6 will work, but some axle spacers may need moved so as to prevent the chain from hitting the dropout. Then the rear wheel will need redished and then the rd needs adjusted. And then there is also chain length.
I find the whole process quite rewarding as it gets the gearing suited to your individual situation. The factory gearing often has a bunch of redundant gears, although looking at those posts of vintage magazine reviews it seems Univega is better than most with their gearing. You are opening up a whole can of worms for yourself.
Likes For sd5782:
Freewheel Medic
Quoted: 1455 Post(s)
Liked 2,197 Times
IMO, that's an unusual noise for a freewheel and I wonder if something else is causing the noise you hear.
Side note: Using my powers of deduction, I guess the OP's freewheel is a Perfect or a ProCompe.
Bob
Bob
Quoted: 4722 Post(s)
Liked 3,039 Times
+1, I'd go with a more modern, Hyperglide compatible freewheel for the significant shifting improvement. They'll shift, though noisily, even going uphill with a load, which can be valuable on a grand touring bicycle.
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
What Make Of Gran Turismo Bike?
It probably would have helped in the OP would have mentioned the brand of "85 Gran Turismo bike".... Just to put things into perspective for the rest of the members.
A lot of builders made models named Gran Turismo. For the sake of clarity, the OP's 85 Gran Turismo is a Univega brand bike.
https://www.bikeforums.net/classic-v...n-turismo.html
My first thought was a French made Gitane "Gran Turismo" from the early 70's (spelled "Tourisme").
Medci made a Gran Turismo in 1985:
https://www.cxmagazine.com/gravel-bi...100-matt-allen
https://www.worthpoint.com/worthoped...ycle-129695974
Wilier, Bottecchia and Ducati along with a lot of others over the years did too....
"Get Off My Lawn!"
OH! That's Gran Torino....
verktyg
"Get Off My Lawn!"
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Quoted: 677 Post(s)
Liked 460 Times
Can you be more specific about the "creaking noise?" When does it occur? Also, what is your current freewheel and can you post pictures?
feros ferio
Quoted: 1393 Post(s)
Liked 1,331 Times
The 50-46 combination in front works best as a half-step, with 13-15-18-21-24-28
Quoted: 583 Post(s)
Liked 700 Times
I also looked at the gear charts and a 14-28 six speed makes nice half steps too. Now to find one and then to make it fit. Also as posted, the 14-32 five speed makes a nice half step.
verktyg
Liked 1,238 Times
1/2 Step With Granny
50-46-30T
13--32T Six Speed Narrow
With the advent of the Shimano 48-38-28T MTB triples I stopped, in the words of Frank Berto, "gear freaking". With a 7 or 8 speed cassette, I just stay on one chainring, frequently the middle and only switch to the larger or smaller as needed. Pedal by feel!
verktyg
Chas. ;-)
Chas. ;-)
Quoted: 1613 Post(s)
Liked 2,598 Times
"Get Off My Lawn!"
verktyg
"Get Off My Lawn!"
verktyg
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
N.B. be prepared to replace the chain at the same time, as worn chains often have a difficult time meshing with new sprockets.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
Really, op should search for an Atom or Maillard replacement.
Freewheel Medic
Liked 2,197 Times
You are correct it is a perfect freewheel. I also thought it odd the freewheel would make any noise. The noise isn’t loud but I could hear it when the bike is on a rack with the chain removed. You would say ohh it’s the hub bearings and that’s the first thing I thought also. Flushed and regreased the bearings still made the noise. As an afterthought I removed the freewheel voila the noise is gone. Put an old Shimano freewheel on it. Noise is still gone. Checking the original freewheel the only thing I noticed is a very slight amount of inward and outward play in the center hole. This bike has next to no miles on it and hung in a garage for over 30 years. The noise while slight is amplified as of it is coming from the frame
Seems like a strange noise. I can't believe I'm about to suggest this, but dribble a little oil in the freewheel around the outer bearing race/retaining ring. See if the noise goes away. If so, follow up with a good cleaning and new grease, which should solve the mystery noise. Perfect freewheels are very well built.
Bob
Bob
Quoted: 583 Post(s)
Liked 700 Times
And no one mentioned the outer lock ring on this freewheel. No expert here and have yet to take one apart, but on used ones I have purchased I have seen this loose on occasion. That could explain the wobble too. I’m going to tear a couple apart sometime just to learn.
Likes For sd5782:
Freewheel Medic
Liked 2,197 Times
I was reading robertj298 's response on my phone in a moving car (no I was not driving, Mrs. PB was), and I missed the "in and out" play in the freewheel body halves.
It could be as sd5782 mentions above, that the bearing race/retaining ring is loose. However, I doubt this is the case and I would suggest that it has the wrong or too many spacers between the bearing race and the top "ledge" of the inner body.
There are at least two spacers and sometimes as many as four on a Perfect. Try removing the thinnest one and retighten. If this is two tight, remove the race, apply some blue Loctite to the threads, and adjust the race for optimum bearing performance.
Personally, and this is just my 2 cents worth of advice, a Suntour Perfect is a superior freewheel to an Atom or Maillard 6 speed. This is especially true since the OP reports the bike has been barely ridden. Unless the internals are loaded with corrosion, it should continue to function well for many years to go.
Bob
Bob
Likes For pastorbobnlnh:
Quoted: 2339 Post(s)
Liked 2,831 Times
Edumacator
Quoted: 2444 Post(s)
Liked 3,138 Times
And SunTour freewheels are ordinarily bomb proof.
i wonder what RD and hub exists on it.
Likes For jdawginsc:
Quoted: 677 Post(s)
Liked 460 Times
The rear derailleur is a Suntour XC and the hub is a Suntour Cyclone with sealed bearings
Likes For robertj298:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Liked 2,831 Times
here is recentish thread https://www.bikeforums.net/classic-v...t-again-2.html
and there is always the bit ugly, not as nicely finished as they used to be (made in china difference) shimano for $14 https://www.rivbike.com/products/fre...hg37-7sp-13-28
Likes For squirtdad:
Edumacator
Liked 3,138 Times
https://velobase.com/ViewComponent.a...c3715&Enum=110
Did any other generation of Cyclone have hubs?
However, is the rear derailleur an XC, XCD, XC Pro, XC-1? They all have their quirks, though shifting in friction mode, cannot really imagine an issue. On the long-cage XC, 38 chain wrap, so you are probably cutting it close if you went 14-32.
SunTour 7 13-26 https://www.ebay.com/itm/19461711397...4AAOSwsHVhsMTw
SunTour Alpha 7 speed https://www.ebay.com/itm/18511890853...wAAOSwk3ZhcJX3
I'm wondering if you could get it to index with the second one?
