Is there any tip to replace brake cables?
Using v brakes on my foldie, I undid the brake nut and the cable went into the housing, tried pushing it with a little force but to no avail, when I pulled it all out and then tried putting it back to the housing, realised I have frayed the ends and I do not have any spare cable and now I have to go to a LBS..
Quoted: 981 Post(s)
Liked 584 Times
A new cable will not have frayed ends, so you will be able to (carefully) insert it into the housing. If there is any doubt about the condition of the housing, replace that as well.
Some helpful links:
Sheldon Brown
Some helpful links:
Sheldon Brown
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
I think you've figured out the 'tip' to replacing cables...replace them, don't re-install them.
Likes For cxwrench:
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
Quoted: 1438 Post(s)
Liked 1,092 Times
Clark W. Griswold
Quoted: 4367 Post(s)
Liked 4,006 Times
Get new cables and housing and don't muck about with old used stuff. The only time I would try to reuse cables and housing is if they are brand new either unridden or very few miles but if frayed it is done. However if again things are new then I might swap that rear over to the front and cut off the frayed part but not used stuff.
Quoted: 2432 Post(s)
Liked 641 Times
A tip to prevent cables from fraying in the future: After you cut them to length and before you install the end cap, put a drop of super glue on it.
Likes For Lazyass:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
While you're in the bike shop, buy a couple of brake cables. That'll save you a trip if you mess up the next one (happens to the best of us...)
Quoted: 9 Post(s)
Liked 6 Times
If you have a soldering iron a bit of solder will do the trick, buy may need to do a clean cut first.
But always have a few spares on hand as well
I always install new cables full length and cut them only after they are completely connected and adjusted. Saves measuring, the tips are usually sealed so no fraying to deal with - and eliminates embarrassing mistakes.
Likes For MNebiker:
Liked 2,568 Times
I've tried soldering the ends, it's never worked well for me with stainless steel cables.
Likes For ThermionicScott:
Quoted: 114 Post(s)
Liked 119 Times
Regular solder works fine with non-stainless cables.
But overall, a soldered cable end is nice.
Likes For MudPie:
