98' Lemond Zurich Rebuild
Bikes: 2017 Surly Cross Check, 1998 Lemond Zurich (frame only)
Quoted: 5 Post(s)
Hello,
Was recently handed down an old Lemond Zurich frame from a friend. I've never built up a bike before, but I will have some help from someone who has done it a lot but I need to acquire all the components first. I have two main questions:
1) this was a 2x9 speed when it was first manufactured. Most newer road bikes I've seen are 10-11, and the components meet those specs. Is it possible and advisable to put 2x10 on this bike? In general, do I have some latitude in slightly diverging from the stock build specs on this frame?
2) can anyone definitively say that 700c x 28mm tires have enough clearance for this frame?
Any additional advice from folks that have experience with these frames are welcomed. The price was right (free) and it's a beautiful frame, but building up a bike wasn't something I anticipated doing.
Thanks in advance.
Thanks in advance.
Sunshine
Quoted: 10971 Post(s)
Liked 7,498 Times
It is modern enough that any curent/recent mechanical road drivetrain will work. 8, 9, 10, 11sp- all fine.
Pick the one you want and just make sure all components are compatible.
As for tires, use a hex wrench to check the space between the frame and tires at the chainstays, seat tube, brake bridge, and fork crown. You need to keep at least a few mm of space all around the tire to account for road debris, wheel wobble, etc.
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
You've got a very nice frame. Be good to it.
While, on a practical basis, there isn't a whole lot of difference between a 9 and 10 speed bike, like nearly none, as mstateglfr mentions, 8-11 will work, but keep an eye on component compatibility. You mention a frame..did you receive any components with the frame? You'll find that building a bike up can cost a few bucks. If you have, for example, a set of shifters that came with the frame..that may determine how you want to proceed.
With respect to 28mm tires..I have two Lemond road bikes, an '01 and an '02, and they both can run "28mm" tires (Panaracer GravelKing Slicks). The '02 is a titanium frame and 28s just nicely fit. The other frame, steel, fits 28s just fine. GK slicks are known to run a bit small (I've measured 26.7mm on H Plus Son Archetype rims). Tires in general can run slightly different sizes on different wheels.
jamesdak has a couple pre-2000 Lemonds, I think, and may know better on tires sizes for a '98.
Quoted: 427 Post(s)
Liked 700 Times
I ride a '06 LeMond Reno. The Zurich is spec'd with 25's, as is my Reno. I have Michelin Pro 4 tires- 25's-on it which leaves 3/8" clearance to the seat tube. Now, those tires actually measured out to 28, so if your geometry is similar, could use 28's-if the tires you use are true to size. BTW-that is a very nice frame! Have fun building iit up.
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,439 Times
As stated above, you have a very nice frame set. I have a 2001 Lemond Tourmalet and a 2002 Poprad, I love riding both of them. The Tourmalet, I believe has about the same geometry as the Zurich, but I am not sure about any difference in the forks. My Tourmalet with the stock unicrown, steel fork fits 28mm, all brands I have tried, with no problem. I switched from threaded to threadless set up with a carbon fiber fork, it still fits the 28 mm I have tried on it, but the clearance is barely enough, maybe not enough for some. The Poprad is a CX bike, ergo, very different geometry and clearance. I actually ride the Poprad more due to being able to fit up to true 33mm tires. Knowing how much space you have to work with is definitely a help in deciding on tires, but brands very substantially in width. Also, with some forks, it is the fork crown or brake caliper that is the limiting factor, not the fork legs. The wheels are another factor in actual tire width. Unfortunately, without input from someone that has tried the specific tire, wheel, bike set up, it is a bit of guessing and trial and error.
Building a bike for the first time is a challenge, especially if you are as mechanically challenged as I am. It can be more costly than one anticipates, in particularly if one is set on specific items. It can also be frustrating at times. However, for me. when I finish a bike and all is operating as it should, the bike looks good and close to what I had pictured; it is high in satisfaction, feeling of accomplishment, and the real reward is a fine riding bike that you put together.
Quoted: 569 Post(s)
Liked 589 Times
Congratulations, I own a '98 Zurich with the classic red with white panels on the terrific Reynolds 853 frame and it came with 25mm but I now ride 28mm. You have a 130mm dropout spacing so as said any 8 to 11 speed groupset/wheels will nicely fit. I found the stock 2x9 Shimano Ultegra 6500 groupset flawless but parts always get harder to find with older groupsets.
Likes For easyupbug:
Quoted: 5 Post(s)
This is where my novice experience shows. Are putting more recent 10 speed group sets (e.g. Tiagra 4700) risky for this frame? I'd love to find the original group set, but as you indicated that may be challenging. Is there anything in particular I should pay attention to when looking at newer components? The majority of the responses on this thread have been unanimous on ensuring that all the components fit with another, but are there any considerations for newer grouppos on this frame?
Quoted: 5 Post(s)
Quoted: 759 Post(s)
Liked 810 Times
It looks like the '98 model was Ultegra throughout. 9 speed Ultegra stuff (6500 series) is still easy to find on ebay. Shifters, front and rear derailleurs, hubs... I haven't looked for a crank lately so no idea there. Cassettes and chains are no issue. Rim brake wheelsets are available (try Velomine or Bicycle Wheel Warehouse. Velomine has high demand and sells out of various wheelsets quite often. Their inventory changes over time so you need to keep an eye on it). No idea on the cost of 10sp vs 9sp..haven't looked at 10sp stuff. Nothing these days is overly cheap. There's a seller (ezbikestore) on ebay for complete Jagwire cable sets at less than $25.
https://www.vintage-trek.com/Trek-Fis...1998lemond.pdf
If you're buying a built wheelset, make sure you appreciate the difference in sound (noise) a rear hub makes. Shimano is quiet, many others are quite noisy. Pick your preference.
Quoted: 569 Post(s)
Liked 589 Times
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
Thanks!
A Zurich was my first true road racing bike purchase, and I was riding it for my first race win. Wonderful frame. I wish I still had mine.
Quoted: 1563 Post(s)
Liked 1,737 Times
Thanks!
Quoted: 4236 Post(s)
Liked 2,949 Times
The only risk is that you mentioned Tiagra 10 speed. There's nothing particularly wrong with Tiagra 10 speed, but it has a complication. Just about any other Shimano group (you want to keep all of your drivetrain parts - shifters, derailleurs, cassette, mainly, crankset and brakes don't matter as much - from the same manufacturer), you can mix and match parts as long as they're for the same speed (can be any mix of Dura Ace, Ultegra, 105, whatever as long as they're all 10 speed or 11 or 9 speed - 8 speed Dura Ace or below is a different ball of wax), but Tiagra 10 speed isn't that way. It doesn't play nicely with any other 10 speed parts, so you have to get all Tiagra if you decide to go Tiagra 10 speed. Not that there's anything wrong with that, but, if you're sourcing used, it's a lot easier if you can be a bit more flexible.
Quoted: 5 Post(s)
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,439 Times
Scottmph , PM'ed you regarding a 6500 group set, but I think you may not be able to PM yet. Post here if you have interest but cannot PM yet.
Quoted: 5 Post(s)
Quoted: 5 Post(s)
Quoted: 5 Post(s)
Quoted: 5 Post(s)
depending on how much you want new ones, you may want to find someone who can design new ones for you. I have an older Surly and someone at my bike shop designed new decals for the bike. Might have just been lucky to have someone local to do that, but may be a better option than combing through eBay.
Quoted: 5 Post(s)
Quoted: 2432 Post(s)
Liked 641 Times
I had a '98 Zurich and I loved it. The bad thing about the Lemond's and Trek's of that era is the paint is paper thin and peels off if you sneeze on it. Almost impossible to find one of those bikes today that looks good, they all need repainting.
Good luck and post pics! There's a "Show your LeMond" thread over in the Road Cycling forum that has lots of great bikes posted, but can always use more.
I'm currently working on a '99 Tourmalet build. I have pretty much all the parts, just need the time to put it together. I scored a near-complete, like new Campy Record 9-speed groupset off craigslist for a good price. That can be a good way to get parts if you live somewhere with a lot of road bikers, though you need to be savvy enough to assess the condition of parts yourself or you could get taken advantage of. I think now is a great time to buy higher end 9- and 10-speed stuff, since it's neither the "new hotness" nor is it old enough to be "real vintage," so I've definitely seen some Ultegra, Chorus, and even Dura-Ace go for nice prices. If you want Record of that era, I still think the price is as good as it's ever going to be, but... you definitely pay a price for being a snob. I should know, since I just paid it.
Quoted: 759 Post(s)
Liked 810 Times
Trek is certainly capable of sourcing and applying good paint. They did cure this issue..just not sure when it started and when they fixed it.
