26x1.75 tires ok on rims marked 1.5?
Old 08-13-19, 11:01 AM
markcle
Can I put 26x1.75 tires on rims marked 1.5? The tires on it now are 26x1.5 but my local hardware store only has 26x1.75's , no bike shops in town- rural area. Thanks.
markcle is offline
Old 08-13-19, 11:03 AM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
It should be OK if there is sufficient frame and component (brakes, front derailleur, fenders, etc.) clearance for the larger tires. Check all around to be sure, on two of my bikes the front derailleur is the tight spot for the rear tire.
dsbrantjr is offline
Old 08-13-19, 11:25 AM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
Tires should be wider than the rims, generally speaking. 1.75" tires should be fine on 1.5" rims, as long as the tire fits within the bike frame/fork.
tyrion is offline
Old 08-13-19, 11:31 AM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Almost no chance the OP's rims are actually 1.5" wide. They're just marked with a suggested tire size.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 08-13-19, 11:41 AM
tyrion
tyrion's Avatar
Good point.
(But a 1.75" tire will still probably be fine, if it fits in the bike.)
tyrion is offline
Likes For tyrion:
Old 08-13-19, 11:44 AM
markcle
Thanks everyone for replies, will buy the 1.75's.
markcle is offline
Old 08-13-19, 04:58 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,271 Times in 877 Posts
I've seen a rim marked 1.75 that was narrower then my 1.5's.
I can't imaging using a tire from 1.25 to 2.1" and feeling "uncomfortable" with a 1.5 marked rim.
Bill Kapaun is offline
Old 08-21-19, 11:46 AM
3S1M
Bikes: Schwinn Del Mar, Schwinn Sanctuary, Schwinn Hurricane, Murray Actra, Eastern Shovelhead
Quoted: 140 Post(s)
Liked 139 Times in 90 Posts
I have a Schwinn Hurricane that the rims are marked Weinmann made in the USA and are marked 1.5" but the tires that were on it, which I believe are the original tires are 2.00. I just put 1.95" tires on them and they work great. I'll get a pic up when I'm allowed to. (new member here).
What type of bike do you have markcle? Just curious. Let us know how it goes. I found having the little plastic tool was a big help when I put new tires on mine yesterday. I didn't need it for one of the bikes I had but those were 2.3 tire size and I think that gave a bit more room. But the 1.95's I put on a different bike were tighter going on.
3S1M is offline
spock345
Classic & Vintage
8
05-26-16 07:45 PM
lfilipe
Bicycle Mechanics
6
09-08-13 06:03 PM
tspain
Bicycle Mechanics
16
05-28-12 04:46 AM
TripleAce
Road Cycling
25
05-27-12 11:06 PM
Kalinda
Classic & Vintage
21
12-04-10 09:15 PM
