Pictures of your loaded rigs?
#3077
Bikes: MGX MTB, Fuji Supreme, Miyata 90 and a Trek 700 in the works
Quoted: 16 Post(s)
On the Surly Ogre the fenders look too close to the wheels if it will encounter mud.
#3078
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Sweet!
My dog likes to ride on anything that moves, need to get him a trailer soon.
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
#3079
Wrench Savant
#3080
Bikes: Old steel GT's, for touring and commuting
Quoted: 39 Post(s)
Snap shots from the shake-down ride. I picked up a Surly Ogre with the intention of doing some single-track oriented touring (lots of options for that around here). The problem that presented itself was the cable routing for the front derailleur interfered with the fenders. I chose to solve this with a Rohloff hub (wouldn't you?). The front hub is an SP PL-8 SON look-alike. The rims are bomb-proof Kris Holm XC Unicycle rims (37mm wide). The bars are Jones H. The lights are the new Bosch & Mueller Luxos U. I don't need it much in the summer other than for carging USB devices, but I am really looking forward to running the Rohloff through the winter to see how it does. Lights will be required then.
Second Cycles introduced last year their series of re-branded, recycled/re-manufactured frames, the "Bicycle." They have been selling well. I do not care for Surly graphics, so I replaced them with a decal set from them. Love the way it rides around town, hope to get it out in the back country in the next month.
Very nice! Is that the large Zimbale bag I spy there? Good choice! I love mine. Great looking set up. How do you like the Jones bars? Thanks for the nice cockpit shot, it is always good to see how folks have set theirs up.
#3081
Quoted: 39 Post(s)
Hi MZ no problems on free hub failures but like anything I guess they have there limits and without a doubt your warranty is out the window with this set-up. All manufactures have there specs for safe work loads or torque and the numbers they give are to ensure that there not getting recalls from failures. Most safe work load numbers are well under spec and in most cases I bet you could double or triple that number before failure happens there just covering there butts.
Having said that I take responsibility for my own actions and if things fail so be it just suck it up and purchase again learning from your mistakes rather than become a whining customer. Again I can only make comment on two brands of hubs that this 41T has been on and that is "Industry Nine" hubs and "Hope Technology" hubs. (links below)
https://www.industrynine.net/
https://www.hopetech.com/
Added to that I run a 20T granny so hauling that rig up mountains without hub or free hub failure stretching the safe work load and torque well beyond manufacture specs I'm happy to make mention of those companies because in my eyes they have passed the test. I'm currently running Industry Nine hubs and spoke system as they have done the bulk of my long distance loaded touring.
Ok gotcha on the lingo I just noticed I made a typo hence why I thought you winked at my silly mistake. As your well aware we live upside down here and that might explain our English being a mystery to you Yanks. Understand though you northerners take a dump and it flows down hill and guess where we are situated geographically on that flow chart.......It's no excuse but it might help explain our English.
Hope that helps further answer some of your questions.
Cheers Mate
Cheers Mate
Happy trails!
#3082
Wrench Savant
#3083
That is a great pic with your dog and bike! I really like the red bar tape to match up with your bags. Happy Riding!!
#3084
What a nice set-up you have. I just got myself an Ogre for future off road touring that I want to do. A couple of questions: What is your front rack set up there? Also I got the ergon grips like you have, what is the bar end mirror that you have? I have not decided on fenders or not with mine. Been reading the problems and solutions for fenders with Ogre on forums. Your solution of Roloff is exquisite!!
#3085
Wrench Savant
The front rack(s) are a cheap bag support of Ebay (Abaxo, I think) and a Jandd low-rider rack. I had nothing to match the rear rack, so I did not try to go buy something fancy (Surly or Jandd Expedition). The mirror is a simple bar-end plug mirror I got at REI a long time ago. I assume they are still available. Ergon grips with A Rohloff is expensive because you cannot buy a set of Ergon's for only one grip shifter. You can by one for two grip shifters, and one for none; then only use half of each package. You would think they would come out with a special "Rohloff Edition". Even at a 50% premium, it would be cheaper than buying to sets.
Fenders on an Ogre require some dedication. I am running Planet Bike's because they are about the only ones made for 29'ers. There are several problems. First, you have to run at least one set of Surly Monkey Nuts for the rear fender to work at all. Even with one set installed, the front derailleur cable will likely rub on the fender. Metal cable; plastic fender, we all know how this will end. You can run a second set of Monkey Nuts (for another $25) and push the rear axle all they way to the end of the dropouts, or you can dump the front derailleur and run a 1x?? setup. Even if you solve that problem (as I did), the fenders, with really long stays, are too flexible and rub on the tires when you hit bumps. I fixed this by attaching zip ties between the fender stays and the racks 1/4 to 1/2 way along the stays to stabilize the system. You probably cannot see it in the pictures. I still get some rubbing when the going get insanely rough, but it does help a lot, and I am not sure how much better you could make without some sort of steel fenders which do not exist.
#3086
Bikes: '89 Miele Azsora, '09 Motobecane 700HT
My bike ready for my first mini-tour.
A group of us are leaving from San Marcos, TX to Wimberley, TX (20 mi) where we'll visit Jacob's Well and the local pubs. After camping the night there, we're headed for Bastrop, TX (70 mi) and the following day we're biking back to San Marcos (50 mi). A few people are starting their trip from San Antonio, TX and will be meeting us at Purgatory Creek in San Marcos (50 mi). My overall trip will be 150 mi +/- and their trip will be 250 mi +/i. I'm really looking forward to it! Gear in store for me after this trip will likely be clipless pedals/shoes and front panniers/racks.
#3087
Somehow with this set up I was able to do a 500 mile tour from San Fran to LA in about 6 days. I was able to rig a 10W solar panel on the handle bars for smart phone charging as well
#3088
Flatted
Bikes: 2011 Dawes Deadeye(mod) 2011 Specialized Comp Compact M2 Apex, 2017 Kona Sutra
I have been watching this thread for sometime now and I have got my bike finally built up. Its a 80's Lugged steel frame Soma Cosmopolitan converted to 700C with Panaracer RiBMo 700x32c, new fork and longer reach calipers. It has a blackburn front low rider rack and a bell rack out back for the Nashbar waterproof panniers. I replaced the stem with an adjustable one and new handlebars and brake levers. Drivetrain consists of a Shimano Alivio rear derailleur, Sora front triple a Sugino Triple crank and Shimano Ultegra 8 speed bar end shifters. I carry an On Guard D lock a small tool kit with spare tire and CO2 inflator plus a Topeak Turbo Morph G frame pump as a back up. Right now I use it for commuting back and forth to work, I have a Magicshine 900 lumen headlight with a Planet Bike Superflash for the rear, Planet Bike Hardcore fenders with Cascadia mud guards and a ESGE double kickstand. I like this set up and hope to do a few tours on it.
#3089
Beautiful set-up and re-purpose of some 80's Steel! I like it JW!
#3090
Flatted
^ Thank you, it was a lot of trial and error with this bike but it has been a fun journey finding and building this bike. I forgot to mention the wheels, they are Vuelta Corsa HDs nice strong wheels IMO.
#3091
Bikes: Surly LHT Custom Build
Surly LHT Entered into service May 2012
Here is my build from winter 2011-2012 , Maiden tour was :
Anacortes WA to Norfolk Va to Key West.
#3092
Quoted: 5 Post(s)
Nice bike and set-up I had to laugh I use crocs as well for around camp or just want to take a break and get out of my riding shoes good to see someone else who uses them.
#3094
[QUOTE=RickD;14837822]My loaded disk trucker, from last weeks trip from Key largo to Key West and back[/QUOTE
I know this question is a little late but did you travel US 1 your whole trip, if so how was it, I would like to do this trip starting from where I live in Inverness Fl.
#3096
Quoted: 70 Post(s)
Liked 15 Times
JC it must be nice travelling with your pet I'm a loner myself and have often though about a dog while riding as company. What sort of food do you lug around for him/her or is your location easy to purchase on a daily bases? Do you purchase food or use bush tucker to keep him/her fed?
Cheers
Cheers
Everybody's dog is going to be a bit different, you would have to figure out what works best for you.
Aaron
#3097
Quoted: 5 Post(s)
My dog eats a blend of dry foods that I put hot water over prior to serving. When he travels in the car with me I portion his food into sandwich sized baggies, one for each meal, ahead of time. My pup is about 45# a 5# bag of his food lasts about 10 days on average. He also has treats, but they don't take up much room. His food is available from a couple of places and could always be ordered in if necessary. One of my dog's favorite treats is fresh vegetable slices, cucumbers, squash, carrots, etc. Those come from dinner staples and are picked up along the way at farmer's markets.
Aaron
Aaron
#3099
Quoted: 5 Post(s)
Nice bike and touring rig ES care to share what you used to make your own rear panniers and any images of method you used to attach them?
#3100
Quoted: 70 Post(s)
Liked 15 Times
Thanks for the feed back and method you use with travelling with pets. I live in a dry country so water for me is carrying 20 litres when I know that supplies will be a long stretch so water for a pet would be a bulky item as well. If I'm using 20 litres will that mean a dog would require the same? Carrying 40 litres of water is huge and while it's not a issue to carry for me it's all added weight plus the dogs weight as well along with food starts to add up. The more I look into this maybe a pet isn't such a good idea because of such remote locations I travel.
I have no clue how much water my dog consumes on a daily basis. We live on the East Coast USA and right now we have more than enough water. FWIW I have seen people touring with a wide range of animals; cats, dogs, ferrets, birds and one guy was apparently relocating via bicycle and had an 8' boa constrictor.
Aaron
