3-Speed Shifter Replacement!
Bikes: Benotto, Bianchi, Peugeot, Raleigh DL-1, Raleigh TI
Would it be a bad idea to use a lever shifter instead of a trigger shifter on a 3 speed bicycle? The trigger shifter it had broke while on a trip.
Thanks!
Daniel.
Thanks!
Daniel.
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Liked 10 Times
It's not a good idea. Are you unable to find another shifter? I suggest replacing it with another trigger shifter since the indexing won't work properly otherwise. There are also some newer DT, bar-end, trigger and thumb shifters that will work if you're looking for something different.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
What do you mean, a lever shifter? If you mean a friction shifter, then yes, you can do that, but the old trigger shifter is a lot more reliable. Sturmey-Archer makes several different shifters for their old three speed hubs now, and there are also generic trigger shifters and cables.
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
Maybe you mean a quadrant shifter?
They work just fine but only vintage ones are available.
You gonna eat that?
If you're talking about using a normal friction shift lever (like those used on derailleurs) and you have a Sturmey Archer AW, I would recommend against it because there is a neutral between second and third gears. I would think it would be a pain in the but to slip into the neutral unexpectedly.
There are beautiful new ones on ebay for around 30$ shipped from the UK, I don't remember the seller but they are the way to go... they work on the old hubs and don't look obnoxiously modern, to me at least. Sturmey also makes mtb style trigger shifters that look nice. I'm not a grip-shift fan myself so I'll stop short of recommending them but they are out there if you like them (not that there's anything wrong with grip-shifters per se)
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
As a starving grad student, I commuted on a Sturmey AW3 with a Huret friction downtube shift lever for several years. I never had a problem finding 2nd, and the neutral came in handy at stops for pedal positioning, since this hub had a coaster brake. First is all the way down, second is just barely above first, and third is all the way up. It's easy and reliable.
Retro Grouch
Bikes: Yes
There are a bunch of Strumey Archer 3 speed shifters including twist, thumb and classic trigger. The re-production originals run about $12.00 https://www.niagaracycle.com/advanced...ifter&x=11&y=9
+1 they are super cheap and look just right for the old 3 speeds. they come with cable, housing, cable anchor/adjuster, and an adjuster barrel too. careful when assembling though all the metal they use is a little cheap.
Get off my lawn!
Quoted: 93 Post(s)
Liked 98 Times
Is a good substitute for this
I think I'd rather pay a bit more for a period correct shifter or one that comes close.
Bikes: 2015 Windsor Oxford; 2012 Trek T900; 2008 Iron Horse Commuter; 1999 Specialized Stumpjumper M2 Pro; 1999 Kona Lava Dome; 1992 Trek 520 Tour; 1980 Fuji Grand Tour SE; 1973 Raleigh LTD-3; 1956 Robin Hood; 198x Worksman Industrial Trike
Quoted: 5 Post(s)
I do not think the shifter mentioned here from Niagra comes with cables. It is just the shifter.
Quoted: 443 Post(s)
Liked 27 Times
I agree with Velognome.
I've had good luck buying used vintage trigger shifters. The only defective one I ever bought was NOS in a sealed package.
Liked 10 Times
Yeah it is a re-production trigger shifter, I'm still gonna try to use a friction shifter on my 3 speed. I read a different forum here where Sheldon brown says its possible, I guess the challenging part is feeling out 2nd and neutral but I'll give it a shot!
Thanks guys for sharing your knowledge and concerns!
To the OP, if you have a local bike co-op, you may consider looking there for a replacement trigger. I've bought a few from mine for 50 cents a piece.
Get off my lawn!
Quoted: 93 Post(s)
Liked 98 Times
Didn't even notice that when I grabbed the picture Third party aftermarket or not...it's still much better looking that the plastic encased version...unless that was OEM on your bike..but still
i agree too, the modern replacement is not as good looking. but it works pretty good and looks better than a friction shifter lever i think.
incazzare.
I like the newish bar-end ones. Depends on the bike, of course.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Get off my lawn!
Quoted: 93 Post(s)
Liked 98 Times
+1 I use a bar-end to shift a s3x hub...very satisfying indeed
Chip seal rocks
Sort of along these lines:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
These off brands aren't common but equal to the task. There was a version of this also called a Speedy.
The Herailleur Synchro apparently functions as either IGH or derailleur shifter but I haven't tested it. It appears to be identical to above.
Howard's setup is what I had in mind, but I wanted to place it on the top tube. But that setup looks clean!
