Of Sprockets And Rohloff Disc Brakes
Bikes: Best described as "What is that?!"
Quoted: 72 Post(s)
Liked 10 Times
I noticed Rohloff uses a four-bolt disc brake. Do you know of anyone who makes sprockets compatible with a four-bolt pattern?
EDITED TO ADD: I just checked the price of those things. Yeek! Never mind, that's at least a paycheque or two.
Yes, several do .. I got some from BTI, a distributor to bike shops, made by Avid.. years ago..
they're thinner than those from, like; Magura...
the disc (reading the manual) is on a 65mm bolt circle ,
So, the 64 mm bolt circle 4 bolt MTB chainrings can be used.
I've seen pictures of the speedhub as a mid drive in a long travel full suspension downhill bike.
final drive to left side of rear hub..
