Ripped off Presta Tip with Hand Pump - bad technique/pump/tire?
Quoted: 3455 Post(s)
Liked 1,454 Times
Then there was something seriously wrong with the pump (pump leather in need of oiling or replacement most likely). I agree that you need to know the technique for using a Silca, but it's not difficult to get to 100 psi (though now that I've gone to wider tires I don't need to do that any more).
I'm curious as to why you think the Morph is superior to a Silca or Zefal. It's definitely not faster.
The Zefal is a smaller diameter tube, therefore it takes less force to push the pump plunger to pump each stroke to pump up a tire. But still you are pushing one hand towards the other hand to pump it, that is not an efficient use of muscle power.
And I prefer the Zefal chuck.
And ...
I did not discard my Zefals, still use two of them on two bikes. They work well enough for a road emergency, so I am not going to replace them when they still work. But if I was buying new, I would buy a mini-floor pump.
And, I am not in a hurry so if it takes a minute or two more to use a mini-floor pump that is easier to use, I will use the pump that is easier to use.
Quoted: 929 Post(s)
Liked 1,289 Times
I used the Silca back in the 80s and trying to get 120 psi into my tubular tire with the Silca pump, the diameter of the tube was too big, thus I needed a lot of force to push the pump plunger. I did not have the arm strength to get enough force on it.... But still you are pushing one hand towards the other hand to pump it, that is not an efficient use of muscle power.
I never damaged a valve using my zefal long pumps, but I have put a blister on my hand or finger having to hold the back of it to not move while pumping--dont recall the exact details, but all I know is that when I got a mini floor style one, the morph G, it was just so much easier as teh force is going down into the ground and your foot holds it still, and you dont have to fight with the end on the valve to avoid a mishap.
bottom line is that if you are someone who doesnt pay attention, or dont use common sense for not having the pumping action move the valve back and forth or whatever excessively, "regular" pumps CAN be problematic, while the mini floor types are just plain easier to use, and in my experience from having pumped tires to 100psi for decades using a zefal frame pump or similar, faster and easier on my arms too.
Liked 1,454 Times
Ah, I see. This sounds like a technique issue. There is a very specific technique to use with a Silca, and it involves placing the bike against a solid object so that you are not just "pushing one hand towards the other" but rather pushing towards a braced object, .....
The Lezyne Micro Floor Drive HV strapped to the seat tube in the photo worked great, did not need to search for something to brace the bike against.
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,204 Times
Ah, I see. This sounds like a technique issue. There is a very specific technique to use with a Silca, and it involves placing the bike against a solid object so that you are not just "pushing one hand towards the other" but rather pushing towards a braced object, and also, the pushing arm gets locked against your body so you are using your entire body weight, not your arm strength to push those last important inches of the pump stroke. It does not take significant strength to get over 100 psi using this method. I've seen folks flail around with Silcas and Zefals who've never been shown the proper technique so I understand why you might have issues. However, when someone is shown the proper way to use one of these pumps it's like a lightbulb going on...i.e. "oh wow, it's easy now!" The Morph gets points here since there is no technique to learn.
Been there. Done that. Ripped off the stem as a result. Got dents in my knees from bracing that stupid Zefal against my knee to try and avoid the problem.
Yes, the Morph type pumps get points for not needing any special technique to use them. That's the beauty of them. They are also already "braced"...against the ground...so you don't have to hold the bike, brace the stem so that you don't rip it off and pump. You can even lay the bike on the ground and pump it up.
Zefals, Silcas and other pumps were okay in their day...up to a point...but we have better pumps now*.
*My least favorite pump was a Zefal Mountain Double Shot. Most useless pump on the planet! The claim that you could pump up a tire to 160psi is wildly overstated. I could barely get 40 psi in it. If you want the pump, you can probably find it in South Park where I flung it off into the trees after it failed me for the 1000th time! You might have to dig for it, however. That was at least 20 years ago...maybe 30.
Stuart Black
Stuart Black
