Why are there cable guides on my non-diskbrake forks?
These forks have what seem to be cable guides brazed on to the back of my forks, yet no disk brake mount.
Or are they actually for something else?
It won't let me post the picture because I have under 10 posts...
Thanks!
Thanks!
Quoted: 6193 Post(s)
Liked 4,809 Times
Originally Posted by felipe.m View Post
(can't post the link here yet)
Then it's no longer a URL, the spam filters won't balk and the spam police won't come to your door.
We'll figure out how to make it a workable URL again.
https://www.bikeforums.net/21908346-post6.html
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Could be for dynamo wiring, could also be that they were designed for hub brakes, other than disc brakes, like drum brakes or roller brakes.
What kind of bike (brand & model) is it?
Quoted: 581 Post(s)
Liked 921 Times
In my experience, the Asian contract manufacturers who build the vast majority of our bikes are meticulous about giving you exactly what you ask for. If you give dimensions for an 'English' threaded bottom bracket on a frame but don't specify the threading, don't assume they will cut threads - you are more likely to get a frame that needs 1.37" bearing press fit in place.
I would guess that there was an original design of a fork for disc brake usage and a product manager somewhere said 'make me 500 of the same design but without the disc mount', and the manufacturer removed the caliper mount and noting else.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Right, so that is definitely not on the normal side for a disc brake cable. My best guess is indeed for a dynamo wire. Just zip tie that sucker in place. The tabs however are very much for brake cables since they are fairly big.
I bought the forks for fairly cheap from a bike shop, unpainted and stand alone. So maybe they were some weird mistake.
Quoted: 2026 Post(s)
Liked 1,096 Times
Agree that those tabs are on the wrong fork leg for disc brake cables or hoses so they have to be for dynamo wiring or just a manufacturing error.
Quoted: 140 Post(s)
Liked 162 Times
If the Magura hydraulic rim brake shown in the pic is original equipment on the bike, maybe it was a bike originally sold in Germany for commuting/trekking. I think most of those brakes were/are in use in Germany, Dynamo wiring guides on the fork would make a little more sense in Germany, dynamo lighting is very common there and might even be legally required. Leading companies in dynamo hubs/lights are German companies, FWIW (Schmidt, Supernova, etc). I will say those guides on the fork leg are overkill as a dynamo wire guide, though.
Quoted: 1944 Post(s)
Liked 2,164 Times
I think the forks were originally designed for Walnart so when the fork is installed backwards the bike will still stop.
John
John
Likes For 70sSanO:
Quoted: 427 Post(s)
Liked 699 Times
Think I may have seen something similar on BF prev. Are these about a spokes length apart. If I recall, they are to hold spare spokes. The top and bottom get zip ties thru them. Spokes go into the top with the "J end" so they don't slip down, and the bottom one holds the threaded end of the spoke.
Liked 1,096 Times
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Zip-tying spokes to a fork leg seems like an accident waiting to happen.
Quoted: 427 Post(s)
Liked 699 Times
Wouldn't argue with that! Know I wouldn't do it! Tried to find the original post, but no luck.
Likes For freeranger:
There are a lot of dynamos in Germany too, like you say, so it seems like a viable reason.
Quoted: 94 Post(s)
Liked 151 Times
I don't think I have ever seen brakes quite like that before. Can you describe them (brand, type, hydraulic/mechanical, do you like the way they work, etc.) and show other photos?
They still make them today, largely unchanged: https://www.magura.com/en/components...ilpage/?p=2597
I haven't had a chance to use them loads yet, but they seem very good so far. Strong breaking power, nice feel on the levers etc.
Also they are v simple to change pads and bleed etc, and apparently they last for ever!
