Dismount Difficulty Due to Flexibility Decline
senior member
I'm a senior in my 70's that has enjoyed road biking ( with a road bike ) for many years - wasn't sure if this question should be in the Adaptive Cycling sub forum - I'm roughly 6"2" with long legs relative to my torso and so my seat is set pretty high ( used the method in LeMond's book to set the height ) - in my younger years I would dismount by holding the bars , left leg on ground , and then swinging the right leg backwards and over the saddle - that maneuver has become impossible - so now I either find a curb or lay the bike down between my legs and then try to get a separation between legs an bike , requires some good balance .
My wife has suggested that ,while holding each seat stay , I go on tip toes and push the bike and saddle forward so now all I have to do is lift my right leg over the rear wheel to freedom - was wondering if any other senior riders have experienced this dilemma and what their solution was or if anyone just has a thought on how to solve this problem - I've even thought about wearing a small backpack with a couple blocks of wood on straps to give me that extra few inches to get the leg back and over the saddle
Thanks in advance for your time and thoughts .
Expired Member
Quoted: 3658 Post(s)
Liked 5,404 Times
Ride a 'bent!! Seriously, try dropping the front of the bike to the side and swing your leg over the bars.
Quoted: 6186 Post(s)
Liked 4,803 Times
I hope I don't get stove up that much. But if I do, that'll be one of the reasons I move to a recumbent bike or trike as suggested by others.
But have you tried just leaning the bike over as you let your one foot go to the ground then the saddle won't be quite as high as when vertical. And though I've not found a use for them, perhaps a dropper post might help you. Like a lot of stuff that's moved from mountain bikes, bmx and other genres, these are coming to road bikes too.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4376 Post(s)
Liked 3,013 Times
Quoted: 1364 Post(s)
Liked 1,677 Times
I've thought about getting a mixte, you know with a low top bar like what was called a ladies bike. You can throw some drop bars on it.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Sounds like you're not at this point yet but last year i got my wife a "low entry" bike since she couldn't ride otherwise.
Quoted: 8271 Post(s)
Liked 9,022 Times
I don't have a problem on the road but lowering the dropper on the mountain bike makes mounting and dismounting a lot easier on steep or uneven ground.
Likes For rando_couche:
Expired Member
Liked 5,404 Times
Likes For shelbyfv:
senior member
senior member
senior member
Liked 9,022 Times
A dropper seatpost. You push a lever on the handle bar and the seat will lower. They can be had in different lengths. The one I have drops 125mm, almost 5 inches. If you love your bike and want to keep it this could be a solution, if a dropper seatpost will fit.
A 'bent is a recumbent bike.
Quoted: 523 Post(s)
Liked 228 Times
"Bent" = recumbent bike or trike. Been riding one for 21 years now. Not because of limited mobility but because I came down with cyclist palsy (carpal tunnel syndrome) that only got fixed two years ago thanks to our wonderful (tongue-in-cheek) medical system that forces us to avoid treatment until it becomes absolutely necessary. I can still get out of the seat 9" off the ground on my Catrike 700 but there are two wheeled versions like my Linear long wheelbase with underseat steering that is super easy to get on and off.
Liked 4,803 Times
Durn blinky . You might need to come out into the daylight more. Dropper post I might can let slide on as I only fully understood what they were a year ago. But bent's? That's been a term for recumbents for quite some time. And I do think it was used as a term for them in the previous 20th Century. <grin>
(just a friendly yank on your chain. Please don't get offended)
Likes For Iride01:
Quoted: 2952 Post(s)
Liked 3,106 Times
Likes For caloso:
Quoted: 1943 Post(s)
Liked 2,164 Times
John
Likes For 70sSanO:
Liked 3,106 Times
senior member
Beautiful , thanks Caloso , I've used that "step down" technique before but just never thought of it - but I want to say that video was really good - thanks for your time and a great response !!!
Likes For blinky:
Quoted: 2601 Post(s)
Liked 1,925 Times
Good reminder to do my stretching after each ride.
senior member
Thanks Big John , something I never knew existed , and another great option !!
Likes For blinky:
Liked 9,022 Times
I've seen them in 27.2 diameter, which is common in road bikes, for less than $100.
Likes For big john:
I don't know why you have to pass your leg over the saddle. I haven't done that in 40 years. I simply step over the top bar of the bike, like I would if I were stepping across a wire fence. If I want to cheat a little, I lean the bike away from me, or towards me, and bring the frame up vertical as I get myself straddling the top bar. Both feet on the ground, then I step into the pedals. Dismounting is just lifting the one foot over the top bar again while the other foot is flat on the ground. I'm 68. Not very flexible. It's not difficult; it's so simple that I don't think about it.
senior member
Likes For blinky:
Liked 3,013 Times
