Lacing a 28 hole rim to a 36 hole hub.
Old bikes, Older guy
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 251 Post(s)
Liked 167 Times
Hello,
The co-op where I volunteer has a bunch of various sizes of 28 hole rims that they acquired when a local shop closed. Sadly, we don’t have hubs to match, but do have many good 36 hole hubs. I wonder if one could lace these up with 4 open holes on each side of the hub. Is there a risk? This would be a good project and a worthwhile use of these parts with minimal investment.
Cheers,
Van
Cheers,
Van
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
Really Old Senior Member
How many different spoke lengths do you want beyond "normal"?
Typically, 28 hole rims tend to be above bottom feeder level. Maybe you could just sell them and avoid a LOT of HASSLE.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Hello,
Cheers,
Van
Cheers,
Van
Sr Member on Sr bikes
Hello,
Cheers,
Van
Cheers,
Van
Dan
Yes, it can be done. I've built a few wheels that way. Essentially just using extra stuff I had laying around to make "a wheel" that could be used. And I did use the wheels quite a bit without any issues. Sheldon has a section on lacing wheels with rim-hub hole counts that don't match. https://www.sheldonbrown.com/special...tml#nine-seven
Dan
Dan
To many "IF"s regarding competency/wisdom of the build. Many are learning OTJ. Some haven't been learning that long.
Not to say quality work can't be done there and I'm sure much is. It's the doubt.
Quoted: 251 Post(s)
Liked 167 Times
Hi folks,
Thanks for the feedback.
Just a few points of clarification. I wasn’t trying for a commercial product, just looking for a way to support the co-op’s “Earn-a-Bike” program and some of the other training & repair programs.
The Sheldon Brown web site has some good suggestions, but they seem to focus on radially sproking or low crosses which probably wouldn’t work for our applications. The rims came from specialty shop that focused on high end road & touring bikes, plus it had an eclectic inventory of vintage bikes & parts. Most likely they are better quality. I’ll check the inventory next week and see if they can be sold on EBay?
I discovered these this week when I was looking for a 32 hole rim for a personal wheel building project and found that the shop’s wheel building program had used all of the 32 & 36 hole rims from this group.
The co-op I referenced, The Northwest Hub in Salem, OR is actually a nonprofit community service organization that provides bicycle based training and transportation to the disadvantaged as well as transitional employment and training. It is also approved for vocational/technical education. It is supported with donations, repair work and sales of rebuilt/refurbished bikes. It also sells some new entry level bikes and new replacement parts. It has a competent salaried staff who insure that everything that goes out the door is safe and functional.
It does not compete with the local full service shops. In fact, they actually support us with things like “take-off” tires and some of their stale parts inventory.
Regards,
Van
Regards,
Van
I never felt your motive was greed etc.
But you want to maximize $ in.
Do your research to see what brand/model they are.
That would have been helpful if you'd provided that first. You may have already had an "evaluation" by somebody familiar with them?
I think there is a good potential they have more worth sold as new? rims then something salvaged from an experiment that didn't sell.
Maybe a swap for rims you can use "properly"?
Bikes: 20+ from 1990's steel & magnesium!, to modern day alloy and carbon. MTB, CX & road
Quoted: 7 Post(s)
I built a set of single speed wheels a few years back using 36H front hub and 32H rear hub with some 24H rims. The front wheel laced radially missing every 3rd hole and for the rear wheel I used the 'crowsfoot' pattern missing every 4th hole. Spoke length is a little trickier to get right. Hope this shows that there are options available...
Quoted: 251 Post(s)
Liked 167 Times
Hi folks,
Well, your feedback generated some discussions as well as possible changes in direction. As Bill K stated, the rims are probably better quality. Most of the rims are 26” with some narrow aero and some box section. I didn’t check the labels, but they looked like good stuff. Four of the rims are Bontrager, labeled 28”. We didn’t research that application. The remaining few are 700c in a semi-aero design and appear to be midlevel models of familiar brands. We also found a few 32 hole 700c rims that we probably can find hubs for.
The management has no idea where these rims came from. They could have been stale inventory from the three local shops that we work with or from the two or three that have closed in the past few years. Needless to say, we don’t do a good job of tracking used parts inventory.
Our wheel master, a retired Mechanical Engineering Professor with a passion for strong, durable wheels, is checking with his at contacts area co-ops for available 28 hole hubs. The staff is still concerned about using these “low” spoke count wheels on MTBs. Most likely, we’ll put them on E-bay and use the funds to buy $8-10 alloy or Weinmann or Sun rims thrue our distributor.
Thanks again for your input.
Cheers,
Van
Cheers,
Van
Quoted: 1074 Post(s)
Liked 295 Times
Several years back I had a pair of drum brake 36H hubs that I wanted to use with a 28H and a 32H rim. Built them up in a traditional cross pattern using 5-6 different spoke lengths. Entirely doable but very time consuming. Eventually they started suffering spoke failures at the nipple, due to me not considering the consequence of high-flange hubs, high cross numbers and the extra angle added by leaving some holes empty. I tore them down, filled the most misplaced holes in the hubs with aluminium solder, re-drilled and rebuilt. Worked fine from there.
If I were to do it again, I’d probably cut some rings out of sheet metal to go onto the hub flanges. Drill the inner edge of the rings for the existing hole pattern and the outer ring for the pattern I want. Then screw the adapter ring in place, and build like any high flange hub. Or do the fill-and-drill thing from the start.
Front rim brake wheels I’d probably build radial and call it good enough.
