For the love of English 3 speeds...
Old 03-11-17, 05:17 AM
  #12601
BigChief
BigChief's Avatar
Quoted: 1299 Post(s)
Liked 103 Times in 85 Posts
Originally Posted by clubman
Nice touch with the quadrant shifter, really sells the roadster vibe. Is it sub 30 lbs for the win?
Yes, very sharp. Nicely done. I like the combination of roadster handlebars and a suspension saddle. Very comfy looking.
Inflate Hard
BigChief is offline
Old 03-11-17, 09:58 AM
  #12602
agmetal
agmetal's Avatar
Bikes: Bianchi Volpe, ANT 3-speed roadster, New Albion Privateer singlespeed, Raleigh One Way singlespeed, Raleigh Professional "retro roadie" rebuild, 198? Fuji(?) franken-5-speed, 1937 Raleigh Tourist, 1952 Raleigh Sports, 1966 Raleigh Sports step-through
Quoted: 248 Post(s)
Liked 26 Times in 18 Posts
Thanks! From what I understand, it's actually a take-off...it looks practically brand new! I haven't weighed the bike, but it's definitely lighter than my '37 Tourist.
This build was heavily influenced by my 1937 Raleigh Tourist, which has a quadrant shifter and a (modern) B66. The ANT has a VO Model 8...I really would have preferred black, but they were sold out of it by the time I decided to order it. At least as far as initial impressions go, I think the VO saddle might actually be more comfortable for me than the Brooks....this may have a lot to do with the lacing. I've only ridden it for a total of about a mile so far, though, because the weather's been a little too gross for a new build. I've been riding my studded tire bike primarily, still (the franken-5-speed in an earlier recent post of mine).
Here they are right next to each other (well, kinda...haven't yet had the opportunity to have them physically next to each other with the ANT this complete):
agmetal is offline
Old 03-11-17, 11:55 AM
  #12603
Loose Chain
Loose Chain's Avatar
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times in 56 Posts
With Spring upon us, I pulled out the E3S and after a few miles on the old critter have decided it would be much nicer if I had a longer stem.
Is there a period correct or even not period correct stem that I can purchase off the shelf (interwebs) somewhere to use in my bike, just a simple swap out?
This bike is a 21 inch frame, I have two equally nice, bare frames in 23 inch but they have a shorter or equal top tube length to the 21, go figure. So, I prefer my 21, it is stiffer, lighter and rides better. I just need a longer stem, regardless of either frame size.
Woe upon me, what can I do?
J
Loose Chain is offline
Old 03-11-17, 12:13 PM
  #12604
agmetal
agmetal's Avatar
Quoted: 248 Post(s)
J
You might be able to track down one of the lugged Sprite stems that are an inch or two longer than the typical Sports stem
agmetal is offline
Old 03-11-17, 12:14 PM
  #12605
clubman
Phyllo-buster
clubman's Avatar
Quoted: 2295 Post(s)
Liked 2,041 Times in 1,250 Posts
J
You could show us a picture and give preferred stem measurements? GB stems always look good.
clubman is offline
Old 03-11-17, 12:32 PM
  #12606
Loose Chain
Quoted: 278 Post(s)
I can later, out for errands now. It is a Plain Jane Raleigh E3S with an approximate 3.5 cm original stem.
What would work best for me is something around double that, that I can purchase off the shelf. I do not wish to start another endless project of searching and bidding on Ebait junk. So what I am trying to find is an off the shelf solution to double the stem length and use the existing North Road bars. And preferably it would look appropriate on the bicycle in character.
Old 03-11-17, 01:26 PM
  #12607
BigChief
BigChief's Avatar
Any 22.2mm stem will fit the fork, but most stems are for 1" bars and the old Raleighs had 15/16" bars so you would need a 1/32" shim. I use softer metal like lead, copper or even brass for the shim. Works fine, never slips. Here is the extra length stem I'm using for my 21" Rudge.
https://www.amazon.com/Sunlite-Steel.../dp/B000AO9OYE
Here is my 21" Sprite with the Sprite stem maxed out. I can get about an inch and a half more than a regular Sports stem.
Inflate Hard
BigChief is offline
Old 03-11-17, 01:27 PM
  #12608
dweenk
dweenk's Avatar
Quoted: 887 Post(s)
Liked 335 Times in 225 Posts
Like Clubman said, a GB stem would look OK. For total functionality a modern stem would probably be the answer, as long as you didn't care it looked "modern".
dweenk is offline
Old 03-11-17, 02:43 PM
  #12609
noglider
noglider's Avatar
Quoted: 7333 Post(s)
Liked 2,430 Times in 1,419 Posts
@agmetal, that's really nice. Where will you be riding it?
noglider is offline
Old 03-11-17, 03:46 PM
  #12610
agmetal
agmetal's Avatar
Quoted: 248 Post(s)
Pretty much everywhere, haha! I expect it'll see a lot of commuting use once I feel comfortable enough with the weather to be regularly riding without studded tires
agmetal is offline
Old 03-11-17, 04:29 PM
  #12611
Vintage Raleigh
Vintage Raleigh's Avatar
Bikes: 1974 Copper Raleigh International, 1975 Olive Green Raleigh Grand Prix, 1974 Raleigh Europa Custom
Quoted: 104 Post(s)
Originally Posted by plumberroy
My Raleigh sport with new tires and brooks saddle
Nice bike but those tyres will never be whiter!
Vintage Raleigh is offline
Old 03-11-17, 05:05 PM
  #12612
plumberroy
plumberroy's Avatar
Bikes: Surly long haul trucker, Surly steamroller,Huffy Catalina, Univega Alpina 501. Gravity deadeye monster, Raliegh sport , Electra loft 1
Quoted: 607 Post(s)
Liked 298 Times in 181 Posts
They ain't that white now I have ridden it a couple times
plumberroy is offline
Old 03-11-17, 05:55 PM
  #12613
Vintage Raleigh
Quoted: 104 Post(s)
Again nice bike, a three speed has been on my list for a while.
I wish I had a photo of the International before the grey plague rim dust iced my gumwalls.
Old 03-11-17, 07:08 PM
  #12614
rhm
multimodal commuter
rhm's Avatar
Quoted: 1908 Post(s)
Liked 574 Times in 339 Posts
I have a minor dilemma, wonder what you guys well say.
Several years ago I picked up an unloved Armstrong roadster, loop frame, rod brakes, 28"wheels, mostly complete but no rear wheel. I estimate the date mid 1930's but what do I know.
Given the choice between a pair of 28" rims (40/32) or just the rear one, for the same price, I took both. I have now built the rear wheel on a hub dated (194)0, and it is good.
The old front rim is a little rusty, all the chrome worn off the braking surface, doesn't match the rear one at all. But it's original.
I may have another 32h hub; not sure. I probably have spokes, or could get them easy.
So, what should I do, rebuild the front wheel with a shiny new rim to match the rear? Build a whole new front wheel? Or keep the original just because it's original?
Don't even ask me why I'm doing this. I didn't want this bike, just feel a responsibility to get it usable again because it's cool and old.
rhm is offline
Old 03-11-17, 07:57 PM
  #12615
NormanF
Quoted: 147 Post(s)
Liked 8 Times in 8 Posts
635 mm rims are now available in alloy. Will take a ton of weight off old steel roadsters.
Good tires are also available in the size. Should be able to get the bike in riding condition.
Good luck and keep us updated on your project.
NormanF is offline
Old 03-11-17, 08:51 PM
  #12616
rhm
multimodal commuter
rhm's Avatar
Oh, I have rims, tires, and tubes. I'm not trying to upgrade or lighten. This is a 1930's rod brake roadster, it's not a good candidate for modernization.
rhm is offline
Old 03-12-17, 07:12 AM
  #12617
Charles Wahl
Disraeli Gears
Charles Wahl's Avatar
Quoted: 504 Post(s)
Liked 369 Times in 214 Posts
Could you get the rusty front rim (de)/re-chromed? Not terribly environmental, but preserves in use an authentic original part. If the braking surface is not polished up when re-chroming, then it will have a dull chrome finish, better for braking efficiency.
Charles Wahl is offline
Old 03-12-17, 07:20 AM
  #12618
3speedslow
3speedslow's Avatar
Bikes: A few
Quoted: 1941 Post(s)
Liked 1,067 Times in 635 Posts
If everything else is original, re use the front wheel. Clean it up as best, spoke it and check for roundness then send it on its way.
3speedslow is offline
Old 03-12-17, 07:50 AM
  #12619
nlerner
Quoted: 3801 Post(s)
Liked 6,616 Times in 2,594 Posts
Clearly, you need to find a complete bike with relatively decent 635mm rims, "borrow" the front wheel and put the rest in a corner of your basement for a few years.
nlerner is online now
Old 03-12-17, 09:27 AM
  #12620
rhm
multimodal commuter
rhm's Avatar
I tried that, but got distracted before I got the wheel off the donor bike, which must be in some forgotten corner down there, perhaps one of the ones where the light bulb is burned out, and now there's little hope of finding it again. Maybe I should just try again....
Seriously, interesting to note that the existing front rim is marked "Palmer" and the badly deteriorated tire is marked "Palmer [cord] Viking." Both are marked "Made in England". I guess this is the original tire. It has a beefy Bayliss-Wiley hub, just what you'd expect.
rhm is offline
Old 03-12-17, 10:46 AM
  #12621
agmetal
agmetal's Avatar
Quoted: 248 Post(s)
From what I've seen, the aluminum Westwood rims that are out there are only available in 36h drilling
agmetal is offline
Old 03-12-17, 11:51 AM
  #12622
BigChief
BigChief's Avatar
Yellow Jersey has new 32 and 40H chromed steel Westwoods for $30.
Inflate Hard
BigChief is offline
Old 03-12-17, 11:55 AM
  #12623
agmetal
agmetal's Avatar
Quoted: 248 Post(s)
Yeah, I've seen those...but what was being discussed was using aluminum for weight savings. I did consider getting a pair of those a while ago, but ended up finding a pair locally. I haven't really used them yet, though...I laced up the front with a DynoHub that I plan to eventually set up with my '37 Tourist, but I struggled with the wheel build more than any other wheel build I've ever done. The rear I might eventually use to build up a new wheel around the original hub on the same bike.
agmetal is offline
Old 03-13-17, 11:17 AM
  #12624
IEthatsME
IEthatsME's Avatar
Quoted: 25 Post(s)
Here's a 1948 Rudge Sports I just acquired. You can see more photos of it here...
https://www.bikeforums.net/classic-vi...ge-sports.html
File Type: jpg
File Type: jpg
IEthatsME is offline
Old 03-17-17, 10:27 PM
  #12625
Dante41
Quoted: 10 Post(s)
Liked 6 Times in 2 Posts
My tax return came in, and I felt like treating myself for passing my third mate's license. Bought this Raleigh Tourist off eBay, and sent it in to be overhauled. It needed it badly, but now it's almost completely brand spanking new. Rides like an absolute dream, and it shifts and pedals so smoothly.
It's apparently a 1975 or 1976 model; the SA hub is dated December 1974. Dunno where to look on a Tourist for the S/N.
Dante41 is offline
