Replacing a SunTour rear derailleur spring
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
I've got a SunTour LePree rear derailleur (the three pulley kind) with a broken spring that I'd like to replace. The spring in question looks like this, except that the "tab" in the center is broken off.
I've got a donor derailleur that I'd like to take the spring out of to put in the LePree, but I can't figure out how to get it out. I'm also wondering if I'd be able to get it back in if I did figure it out.
Any ideas?
Any ideas?
My Bikes
My Bikes
Quoted: 786 Post(s)
Liked 520 Times
It just pulls out. That said, they are often rusted or gunked in there very tight. Soak it in penetrating oil for a bit. Then take an Exacto blade and run it around the circumference between the spring and housing. It should eventually loosen enough to get it out with some needle nose pliers. Good luck.
Quoted: 1088 Post(s)
Liked 1,205 Times
I think this thread, starting at post 18, would be helpful. I took apart a Cyclone MK-II apart a couple of years ago, which has the same type of spring, and used this thread as a reference. It's not top of mind because it was so long ago, but my takeaway was that the little tab was easy to lose, so be very careful.
https://www.bikeforums.net/classic-v...nto-place.html
Likes For noobinsf:
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
I found this thread, and the other recommended just now. 🤦Thanks, Murph...
Hard to see how the spring will pop off, but I'm guessing that little tab is there to prevent that.
And I thought things had gone pretty well yesterday...
Cheers, Eric
I seem to have lost what little mind I had left before this all started.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Any ideas?
Any ideas?
If it happens to looks like the same spring, then spray lube like crazy, use quality, narrow needle nose pliers, grab the centre tab and rotate the spring back to relax it to ease it out. Vica versa going the other way. Good luck.
Bikes: Yes
Liked 3,868 Times
OK, here are some pictures of my own.
This is the LePree derailleur.
And this is the donor derailleur (an XC).
The part holding the spring looks like it could be interchangeable between the two, if that would be easier. How do the pivot pins come out? The XC part is in rough shape (hence it being a donor component), but I might be able to clean it up enough. It seems to me like the spring is wound to tight to come out easily. I'll keep trying unless anyone has a brilliant suggestion.
My Bikes
My Bikes
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,488 Times
It's quite the enigma.
Do you ever watch those box puzzles on youtube? I don't, personally. But at the 3:20 mark below he gives this puzzle a smack and the two halves come apart. Might try that.
Quoted: 177 Post(s)
Liked 313 Times
Quoted: 177 Post(s)
Liked 313 Times
Very pleased to find this thread with precisely the same question that I had. I've got the same LePree 3-pulley RD with a broken spring Andy, did you ever succeed in swapping out the spring?
Bikes: Yes
Liked 3,868 Times
Nope. I gave up and just cleaned up the XC derailleur body. I couldn't get the spring out of any of them.
My Bikes
My Bikes
Bikes: Yes
Liked 3,868 Times
FWIW, I did find that the cages of SunTour derailleurs with this type of spring are somewhat interchangeable. The longer story behind what I was doing is, I had (1) a short cage Superbe derailleur, (2) a 3-pulley LePree derailleur with a broken spring, and (3) a 3-pulley XC derailleur that was a bit scratched up and missing some small parts (the B-screw and, I think, a washer in the mounting mechanism). I bought the XC as a parts donor.
I started by moving the 3-pulley cage from the XC to the Superbe. This mostly worked. The short cage Superbe has the pivot stop in a different place than the 3-pulley derailleurs, so I had to remove the pivot stop pin. Otherwise, it works perfectly.
Having done that, I wanted to move the spring from the XC to the LePree. Since I couldn't get that to work, I instead moved the cage from the LePree to the XC. This also worked without any problems. I don't have a picture of that yet, but it basically looks like it did with its original cage, so it doesn't really need a picture. I've got it mounted on a bike that's mid-build right now and it has some play where it bolts to the derailleur hanger, so I think I'm going to need to harvest another washer or something from the LePree.
My Bikes
My Bikes
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,801 Times
I gave the LePree to Andy awhile back as gratitude for hauling my bike from Portland to Cambria for Eroica California. He installed it sometime later on an old Raleigh, and within 2-3 miles the spring broke.
Bikes: Yes
Liked 3,868 Times
Same bike I just put the XC on. I'm hoping to make it at least 10 miles this time! The LePree was worth every penny I paid for it.
My Bikes
My Bikes
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
I have a 3 pulley XC that I think is the cat's pyjamas.
Suntour XC by Dave The Golden Boy, on Flickr
Commence to jigglin’ huh?!?!
Bikes: Yes
Liked 3,868 Times
My Bikes
My Bikes
