FSA Gossamer Rings
FSA Gossamer Rings
Hello. I want to fit Gossamer Rings on my Cannondale SI crankset. Will the 46/34 ring combination work with 10 speed Dura Ace? Does anyone have any experience with this?
Quoted: 714 Post(s)
Liked 800 Times
I don't think there is any way to fit the FSA rings on your Cannondale crankset. The FSA rings have a 90/120mm bolt circle diameter and your Cannondale likely has a 110mm BCD. FSA also makes the rings in a direct mount version, but FSA direct mount and Cannondale Direct mount are not compatible.
Quoted: 714 Post(s)
Liked 800 Times
Sorry, I assumed that you were trying to fit the FSA subcompact gravel rings. You should be fine with 46/34. I have a 48/34 setup on my gravel bike and it shifts fine, a 46 should shift just as well.
Great thanks very much for the reply. I'll give it a whirl. What's the worst that can happen right.
