I put my wife's tire on backwards...
Quoted: 2026 Post(s)
Liked 1,096 Times
I'd tread lightly about it.
No, and everything should be fine.
I have a SSFG with a flip/flop hub and I haven't had any problems running the directional rear tire either way. Of course, I don't have the power in my legs or go fast enough to damage anything.
I believe Michelin when they say tread on a bike tire is just to make the customer comfortable (not taking dirt and knobs into consideration) and I suspect the same of directional arrows.
Constant tinkerer
You could just "fix" it when she isn't looking. If it's a road tire, it won't matter either way as any tread is useless on pavement.
Liked 1,096 Times
If the Wife asks, use the rocket scientist answer:
Newton's Third Law of Motion: For every action there is an equal and opposite reaction...bike moves forward, the tire's threads roll backward.
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1128 Post(s)
Liked 257 Times
I put my wife's tire on upside down and she never noticed.
Quoted: 1572 Post(s)
Liked 644 Times
Now that you've told us all that you did it, I'm going to say that you should replace it immediately.
Otherwise, if she were to crash and die, you'll be accused of planning her demise by sabotaging her bike.
The Recumbent Quant
It get's expensive have the laptop fixed over and over again.
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
I suspect its actually a plot by the OP because - the wife is actually a faster cyclist than he is!
Completely ok. In fact, that is a common mounting position called the "reverse cowgirl", and is often done to improve traction, especially in conjunction with a rigid fork.
I took some old knobby tires off my wifes bike and they had direction arrows pointing different for front or rear installation. Just claim that the arrow on her tire is supposed to either point to the center of the bike or away from it (whichever applies). Then state that department store bikes have arrows pointing both directions but upper level tires assume the installer knows what they are doing.
Super Moderator
Quoted: 1174 Post(s)
Liked 935 Times
My mind started wandering.
cyclepath
Bikes: 2005 Trek Pilot 5.0, 2001 Specialized Sirrus Pro, Kona Lava Dome, Raleigh hardtail converted to commuter, 87 Takara steel road bike, 2008 Trek Soho
It depends on whether it was the front or back? I don't believe you've said, have you?
"Without music, life would be a mistake."
-- Friedrich Nietzsche
Bikes: Spec Roubaix, three Fisher Montare, two Pugs
Quoted: 39 Post(s)
Here it is... It will either make a difference to her quality of ride or it won't. if the tire is directional and the directionality is meaningful, change it. Otherwise it makes no difference. Either way tell her. If you can't tell her this...get a divorce.
Quoted: 1869 Post(s)
Liked 666 Times
Ok, so I would secretly remove, reverse, replace, or perform a "bead adjustment," yeah, that's it, a bead adjustment, cuz I read on BF that the beads are important ...
Honey, I just made your bike a lot safer!
