Torpado Paint Brush On Paint Job...
Old 01-01-21, 05:55 AM
oneclick
Quoted: 296 Post(s)
Liked 295 Times in 186 Posts
Originally Posted by randyjawa View Post
The missed spot, I can and will fix. The pooey stinko lug workmanship, not so much...
For flaws like that seat lug you can use a safe-back jeweller's file. The real cut-steel ones do a better job than the diamond-dust ones - they cut faster and leave a smoother finish (modulo skill, of course).
oneclick is offline
Old 01-04-21, 11:50 AM
randyjawa
randyjawa's Avatar
Quoted: 990 Post(s)
Liked 666 Times in 420 Posts
Ah, starting to look like something...
Remember, these old road bicycles were not statements in workmanship excellence, every time...
I do not like to use any chemicals or solvents to strip a frame/fork set. I do use paint thinner during the painting process. And a wee bit of lacquer thinner to clean off soon to be painted chrome plated surfaces. So, without chemical stripping assistance, I filed a small soft blade screwdriver and use it to pick and scrape away at the little places...
Once satisfied that the piece is good to go, I brush on the paint, this time using a much smaller brush. This is the first time I have used liquid latex as a masking medium. Works great with rattle can spray...
But, when brushed on can pick up the latex, if not careful. None the less, I painted right up to the liquid mask edge, trying to not go over or rub the latex too much. Not true eye candy, just yet, but getting closer to art time...
randyjawa is online now
Old 01-04-21, 05:43 PM
oneclick
Quoted: 296 Post(s)
Make friends with your dentist - I did, and would up with a box full of used picks. They are great for cleaning dirt out of bb and rear hub threads, and inner corners of dust-caps, and up inside the top knuckle of rear mechs that don't easily come apart, and the pin holes on freewheel lockrings, and the drain holes in fork blades and stays, and, and, and. With a loupe and a bit of careful prep with a grind stone (and some practice) you can re-touch the engraving on aluminium bits,
And they are *really* useful for picking the remains of that seized bolt you just drilled through out of the threads of the hole it was seized in.
oneclick is offline
Old 01-04-21, 07:10 PM
randyjawa
randyjawa's Avatar
Quoted: 990 Post(s)
I don't have the dentist tool but I do have a line scratching tool for metal use, straight and 90 degree bends. I do not, however, us that tool on chrome plated surfaces - too hard and will scratch the chrome. I use the soft metal screwdriver to do the fine cleaning. Seems to offer decent results (this one is rattle can lacquer and latex masked...
Old 01-05-21, 05:54 AM
Prowler
Quoted: 300 Post(s)
Liked 252 Times in 148 Posts
Randy, two thoughts.
The gray n red approach looks great but, it seems the red needs to be somewhere on the rest of the frame too. Maybe red lug lining on the seat lug or BB shell. My Crescent has a single line pin stripe down each seat stay. Hmmmm.
For scrapers I've found that steel banding straps (like used to strap heavy things to pallets) make good tools. I have a few pieces cut about 4" long. Squared off ends, angled ends and rounded ends. The material seems high carbon and you can control how sharp the edge is with how you file it. I have salvaged banding 3/4" and 1 1/4" wide. Handy for many things. Filed correctly and used low angle they will not damage chrome. You can bend an end a bit if needed but they break easily if bent to 90deg.
Prowler is offline
Old 01-05-21, 07:21 AM
randyjawa
randyjawa's Avatar
Quoted: 990 Post(s)
You must be reading my mind. How does a red band, or two, on the top and bottom of the seat tube panel. Fork socks will be edged with red also. You can see the panel edging tape in the box of paint stuff...
Her is what the taped result looks like. Two narrow red strips run down each side of each fender. The same tape edges the fork and stays socks. The double black tape edges the seat tube panel. Very easy to do...
To that, add this bar tape and there should be enough red to do the trick...
Old 01-07-21, 05:59 PM
randyjawa
randyjawa's Avatar
Quoted: 990 Post(s)
Today, I finished sanding the pitted chrome original fender set. There is no way the chrome will look good, leaving the option to paint wide open. Not sure what color to go with right now - grey or red or a combination. Anyway, a hard to find original Torpado fender set in great shape except for the poor chrome...
The frame and fork were color sanded today, smoothing the less than perfect surface offered by the first two coats. This coat, the final I hope, will be applied thin and with extra care...
When sanding, go slow and use fine paper (wet and dry, wet is best). As you proceed, you will see shiny spots surrounded by the matt grey sanded finish. These are low spots and need to be blended into the surface. The better the surface, at this point, the nicer the finish will be once done...
The liquid latex did a decent job of masking the fancy lugs. You can see some of the latex, that I peeled/rubbed off with my finger and finger nail. That is, pretty much, all you need to get not too bad results. Still have a bit more edging to do. Out comes the finger nail again. And, once done, if any touch up is needed, it is very easy to apply.
So, with luck, tomorrow will see the frame/fork painted and drying in preparation for art. I will slap the first coat of grey on the fenders. They will get at least two coats, color sanding between them. Then, I will have to decide on one color or two tone fenders for the old Torpado.
The fender fasteners are very unusual (the first I have gotten my hands on, I think). They will all be cleaned up, along with their matching one piece support struts, and installed sans paint...
Some require more cleaning than others...
Likes For randyjawa:
Old 01-09-21, 02:32 AM
randyjawa
randyjawa's Avatar
Quoted: 990 Post(s)
By now, if I did not know what was happening, I just might say to heck with it. But I learned a long time ago that the quality of one's brush paint work improves with each coat of color applied. Simply put, with each coat applied, your painting skill improves.
The first coat or two does not look great. So, after each coat, color sand. Color sand means, after the paint is dry (say a couple of days in a warm room), use #400 grit wet/dry paper to sand the new painted surfaces. In seconds, as the shine dulls, you will begin to see low spots. Any irregularities in the paint finish will lower the quality of the finish. So, do your best to sand the new paint smooth. You might sand through in places but that is not a big deal. Just apply another coat, let it dry and have a look. Repeat until you are happy with the final result...
As found...
Two coats...
Final coat applied (with greater care)...
Even the fenders get a coat of grey...
Another day and time for art - yahoo..!
Old 01-09-21, 01:12 PM
randyjawa
randyjawa's Avatar
Quoted: 990 Post(s)
Now, wait for a few days while I clean the components in preparation for assembly. For now, the Torpado frame is looking pretty good. I do have two small spots to touch up but the repair is a snap. The fenders will need another coat, probably tomorrow. Anyway, still some tidying up of the lug work but the effort is beginning to pay off...
Most of the luquid masking material was removed with my thumb nail. I still have some cleaning and edging (not sure what else to call it) to do, but all in all, not a bad home based brushed on paint job. And done in the mud room, at the back of the house, with minimal mess. There was, however, an odor associated with the effort...
I pan to buy some new tape. This stuff looks pretty good but my confidence in the adhesive backing is low (the tape is old - new when I bought it, but old now)...
Old 01-09-21, 03:50 PM
noobinsf
noobinsf's Avatar
Quoted: 715 Post(s)
Liked 474 Times in 323 Posts
Wow, that’s looking really nice!
noobinsf is offline
Old 01-09-21, 06:49 PM
zandoval
zandoval's Avatar
Bikes: Univega, PR-10, Ted Williams,UO-8, Puch, PHLE, UO-18 Mixte
Quoted: 30 Post(s)
Liked 5 Times in 5 Posts
Of course you did an excellent prep. Any notes on your drying methods and dry time?
I have hung my frames after painting in a Texas attic after they dry to the touch. I know the paint is fully dry when its hard, tight, and has little smell. I have been very satisfied with Rust-Oleum paint. Especially Rust-Oleum Automotive Engine Enamel.
zandoval is offline
Old 01-10-21, 01:05 PM
unworthy1
Stop reading my posts!
unworthy1's Avatar
Quoted: 704 Post(s)
Liked 276 Times in 226 Posts
I have done a few "brush" paint jobs on frames and have to really resist the urge to start "rubbing out" before the paint has cured. I followed somebody's advice and made a simple "hot box" of a aluminum-foil lined bicycle box with an incandescent bulb inside and leave it be for about a week. A week might be overkill but that's what worked for me in the "high ambient humidity" of SF Bay Area.
Rubbing out is where all the work and where the pay-off is, even if your brush-work is poor, but smooth brush-work makes for easier/quicker/better rub-out.
And I've always wondered (cause there HAVE been some hints) do you Canadians who can obtain both find ANY difference between Tremclad and Rustoleum? Some have said that Tremclad is better; others that there is NO difference besides brand/label and the volumes (milliliters vs fluid ounces) in the cans: same parent company=same products.
unworthy1 is offline
Old 01-10-21, 06:49 PM
embankmentlb
embankmentlb's Avatar
Bikes: 3Rensho-Aerodynamics, Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 63 Post(s)
Liked 87 Times in 45 Posts
I really applaud the efforts of the original poster.
Excellent job!
How well does the brushed on paint hold up over time?
embankmentlb is offline
Old 01-10-21, 06:52 PM
randyjawa
randyjawa's Avatar
Quoted: 990 Post(s)
When fresh out of high school, I worked for Tremco Mfg in Toronto, Ontario, Canada. I was a maintenance guy at the time but watched the various Tremclad colors being prepared. I have used Tremclad on this (rattle can)...
Tremclad on this (brush)...
Rustoleum on this (paint brush)...
Russtoleum on this(rattle can)...
Crylon on this (rattle can)...
Lacquer (rattle can) on this...
And, of course, my present project, Smoke Grey Rustoleum and a decent brush...
Old 01-18-21, 02:48 PM
randyjawa
randyjawa's Avatar
Quoted: 990 Post(s)
Once sure it all fits, art follows...
Old 01-18-21, 06:33 PM
Hobbiano
Quoted: 224 Post(s)
Liked 104 Times in 78 Posts
It looks great! Did you wet sand it? Did you thin the paint or apply it straight from the can?
Hobbiano is offline
Old 01-19-21, 03:08 AM
randyjawa
randyjawa's Avatar
Quoted: 990 Post(s)
I do and did color sand the work between coats but did not wet sand the last coat. I could do so but do not intend to do so. I am quite happy with my less than perfect results. Keep in mind, as I mentioned earlier, vintage road bikes were, particularly the entry level steeds, were not mechanical art. In fact they were hastily made, painted and assembled. This is the sort of cosmetic quality one can, often times, expect from a lower tiered vintage road bike...
So, the last coat goes on as carefully as I can apply it. If good enough, then I am done. If not, sand and apply another coat.
I did not thin the paint. Rustoleum recommends against it and, to be honest, there was no need to thin the paint. It goes on well and flows to a smooth shiny surface...
I still have some clean up to do and possibly a wee spot of touch up. I have, pretty much, done my last bicycle paint job. Eyes are dim and hands shake too much for fine work. But ya never know. I still have Torpado's top dog, from the same era to restore, and I am gonna give it a shot next Spring - early sixties Torpado Professional...
Old 01-19-21, 08:50 PM
Hobbiano
Quoted: 224 Post(s)
Thanks for the explanation. Looks like it really flowed out well. It seems like a more pleasurable process than rattle can. For many utilitarian bikes, that would be the perfect paint job. I had a '59 Willys jeep station wagon back in the seventies, that I brush painted with grey DeRusto (Rustoleum). It was kind of a low gloss so it looked ok for an old jeep and the brush marks didn't show up too bad.
Hobbiano is offline
Old 01-20-21, 02:50 AM
randyjawa
randyjawa's Avatar
Quoted: 990 Post(s)
I am not sure about that but I do know one thing. I am not a fan of painting a bicycle or anything else, for that matter. I like mechanical work mostly.
I built a website, years ago, called MY "TEN SPEEDS" (no longer own it). The purpose of that website was to entertain me, as I built it, and to help others work on their vintage bicycles, without making some of the huge errors that I made when I got started. Painting with a brush was intended to help anyone paint a bike anywhere, with minimal cost and mess. So...
I cannot paint a bike frame, with a rattle can, in the living room or kitchen or bedroom (wife has issues with me doing so). But a brushed on paint job can be done in the living room or kitchen or bedroom with minimal mess, other than odor. To that add that the more effort I put into pursuing excellent results, the better the results get. But, at the end of the day, the Tropado is going to be my Lakeshore Drive junk bike, so perfect paint/art is not an issue with me. Working perfectly (in the mechanical sense) is always a goal, however, that said, I am deviating with this build.
Steel rims will remain along with the lovely old and wonderfully antiquated "wing nuts", even though both are impractical and difficult to use (my hands are shot and I have a tough time getting the wing nuts tight).
Old 01-22-21, 02:59 PM
randyjawa
randyjawa's Avatar
Quoted: 990 Post(s)
I sweated bullets applying the art. Twenty four hours drying time and then off comes the protective layer. Fingers crossed...
Old 01-22-21, 04:29 PM
markk900
markk900's Avatar
Quoted: 229 Post(s)
Liked 102 Times in 65 Posts
Looks really good Randy
markk900 is offline
Old 01-23-21, 04:49 PM
randyjawa
randyjawa's Avatar
Quoted: 990 Post(s)
Assembly begins. Not really fussy on the saddle but keeping this one as close to original as I can is the primary goal, next to having fun. Please excuse my poor quality pictures...
Still a bit of tidying up the paint and chrome but things seem to be working them out
It will look better after the final clean and wax job. For now, I will resist that until April, at the earliest. My gum wall tires (700c x 28 will be here at the end of March). Might also keep my eye open for a decent original head set...
Anyway, hope someone found how to paint an old Torpado with a brush interesting and entertaining.
Old 01-23-21, 07:31 PM
Hobbiano
Quoted: 224 Post(s)
That looks great! Care to share information on what kind of brush you use? Any other tips?
Hobbiano is offline
Old 01-26-21, 11:17 AM
randyjawa
randyjawa's Avatar
Quoted: 990 Post(s)
Years ago, I bought a 1" Performance Select at Home Depot, a Canadian big box hardware/lumber store. Thought that I had lost is so bought another one and then found the old one (figures). Basically, you are looking for a good quality brush for use with oil base paint. I do my best to clean my brush but, prior to each use and once the brush is dry, I comb the bristles. Take a bit of time doing this, feeling the bristles from time to time, until all seems supple...
Anyway, though my age is negatively impacting my skill level, these days, a brushed on paint job can look pretty darn good from the street...
Old 01-26-21, 01:00 PM
cb400bill
Inoxidable Moderator
cb400bill's Avatar
Bikes: Fuji SL 2.1 Carbon, Cannondale Synapse Alloy, Trek 710 531 Steel
Quoted: 2207 Post(s)
Liked 2,197 Times in 1,372 Posts
Looking great Randy. Really nice job.
Be nice
cb400bill is offline
