Crack in Bottom Bracket shell
Old 01-16-21, 10:35 AM
dvizz
Bikes: Wilier GTR SL, Specialized Sirrus Elite , Cannondale Scalpel
Quoted: 7 Post(s)
When pedaling with torque there is a subtle clanking sound coming from the bottom bracket. My diagnosis on the cause is a crack in the bottom bracket shell discovered after removal of the cups being retained with Loctite 609 to the press fit bottom bracket. Previously press fit installation and removal due to creaking of the bottom bracket over the past 3 years, the punching out removal caused the separation that is shown in the photo. I am considering an epoxy or super glue to prevent the movement of one side of the shell under the stress of pedaling. Any one have any thoughts.
dvizz is offline
Old 01-16-21, 10:52 AM
Iride01
Hits [ENTER] b4 thinking
Iride01's Avatar
Bikes: '20 Tarmac Disc Comp '91 Schwinn Paramount '78 Raleigh Competition GS
Quoted: 2198 Post(s)
Liked 936 Times in 702 Posts
Call or write the manufacturer of the bike and see if they have any thoughts or suggestions. Some manufacturers don't get involved directly with customers and you'll have to go through an authorized dealer. But it's possible they may already have dealt with this. And for sure they need to know how their stuff is holding up.
Iride01 is offline
Likes For Iride01:
Old 01-16-21, 11:17 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 2711 Post(s)
Liked 891 Times in 647 Posts
I highly doubt a bonding solution will work on the Al BB sleeve/insert (or what looks to be an insert, if the frame/shell were all one piece the crack would likely be visible from the outside). The insert has very little surface area on the crack's faces. Then there's the challenge of cleaning the crack's faces so any bonding agent will adhere to the insert and not the grime/corrosion that's likely there now.
I completely agree with first seeking a warranty or brand supplied fix. Only if after this "fails" would I consider going to a carbon repair expert. But much of this depends on what type of long term happiness you want with this bike. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 01-16-21, 11:37 AM
rydabent
Quoted: 2191 Post(s)
Liked 552 Times in 331 Posts
Are you the first owner and do you have proof of purchase. If so did your bike have a life time frame warranty? If so the Mfg owes you a new frame.
rydabent is offline
Old 01-16-21, 12:44 PM
Iride01
Iride01's Avatar
Not every failure of a frame or component is a warrantable item. Don't be filling the OP with foolish expectations.
Iride01 is offline
Old 01-16-21, 03:29 PM
dabac
Quoted: 989 Post(s)
Liked 175 Times in 133 Posts
I canít imagine any repair short of replacing the bb sleeve to do any good there. On the plus side, that seems fairly doable.
dabac is offline
Likes For dabac:
Old 01-16-21, 06:42 PM
dvizz
Quoted: 7 Post(s)
I bought the bike new on eBay and contacted bike manufacture with info and photos to no avail.. Warranties are only honored if the bike or frame is purchased from a authorized dealer. I haven't looked into finding a carbon repair shop to see if the shell could be replaced but that may be a viable option.
dvizz is offline
Old 01-16-21, 08:59 PM
Andrew R Stewart
This needs to be in bolded font! We sometimes find the true cost of a deal is not known, at first... Manufacturers can get a bad rep from those who believe that the full after the sale options are independent of how the sale happened. Andy
AndrewRStewart
Likes For Andrew R Stewart:
Old 01-16-21, 09:44 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 471 Post(s)
Liked 504 Times in 294 Posts
Obvious that you don't understand how warranties work and what is actually covered vs what isn't.
cxwrench is offline
Old 01-16-21, 09:50 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 3408 Post(s)
Liked 663 Times in 452 Posts
Sometimes. For example, Trek honors it's warranty for subsequent purchasers of their bikes for 3 yrs anyway. So it could be sold 3 or 4 times used, but if a copy of the original invoice travels with each sale, in theory Trek honors its warranty. This is admirable IMO (and helps used sellers pricing by potentially there still being a manufacturer warranty in place).
Maybe manufacturers should get a bad rap if they hide behind language that because you bought a bike used, the manufacturer is absolved of responsibility for poor quality.
Sy Reene is offline
Old 01-16-21, 11:03 PM
rydabent
But that is a frame failure, and a life time warranty should cover it. Why wouldnt the OP want to know.
rydabent is offline
Old 01-16-21, 11:06 PM
rydabent
So tell me how life time warranties work. When my frame cracked I go a whole new model frame at no cost. They even paid for the component swap.
rydabent is offline
Old 01-17-21, 07:45 AM
dabac
Quoted: 989 Post(s)
The lifetime it refers to is the lifetime of the item. When it fails, the manufacturer may simply say that the item had reached the end of its intended lifetime and thatís it. Unless you can make a good case that it failed prematurely, youíre SOL.
dabac is offline
Old 01-17-21, 09:55 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 471 Post(s)
Not every broken frame is a warranty. There are a great many things that can result in a cracked/broken frame that won't be covered.
cxwrench is offline
Old 01-17-21, 10:37 AM
Iride01
Iride01's Avatar
While I want to agree that it is, I can't. I don't have the bike in front of me, I don't have the warranty in front of me and I don't know the other pertinent information.
So to claim it is a warranty item and the mfr owes the OP a new frame is silly.
Certainly the OP needs to get a determination from some representative of the manufacturer. And as mentioned, some manufacturers don't talk directly with the customer. Whether this is licensing agreements or what I've no idea. But the OP should find out. They need to read their warranty. Probably it states how to make a claim and whom to contact.
Iride01 is offline
Old 01-17-21, 03:54 PM
rydabent
And if that crack appeared at 6 months is that a "lifetime"????
Not if the warranty says for the lifetime of the original owner. Since that sleeve is basically cast into the CF frame, it is indeed part of the frame.
I guess I dont understand all the nay sayers on this. The damn frame failed and if he bought it new with a frame warranty, he should get a new frame-----------period. Of course some sleazy mfg will try to weasel out of it, but the guy needs to keep pushing till he gets what he is due.
rydabent is offline
Old 01-17-21, 03:55 PM
rydabent
Other than a crash----------------what
In this case it is the shell INSIDE and part of the frame. Is there any damage to the frame outside the shell that would indicate a crash.?
BTW what is the brand of that bike.
rydabent is offline
Old 01-17-21, 04:00 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 471 Post(s)
Other than a crash----------------what?
Seriously? Shipping damage. Improper mechanic practices. Neglecting maintenance. There are all sorts of things that can damage a frame that aren't covered by a 'defects in materials/workmanship' warranty.
cxwrench is offline
Old 01-19-21, 11:40 AM
rydabent
You sound like a lawyer for a bike mfg that is trying to weasel out of honoring their warranty. Reputable mfg do honor their warranty like mine did. Remember built into the selling price of the bike is a certain amount of money the mfg thinks they will have to use for warranty replacements.
rydabent is offline
Old 01-19-21, 11:53 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 471 Post(s)
You have just proven that you don't really understand how nearly every warranty works. Many carbon rim manufacturers are going to a 'no fault/everything is covered' warranty but I am not aware of any that do that w/ frames. Or drivetrain components. Or any other item. I'm oh so happy that your issue was covered but that doesn't mean by any stretch of the imagination that every problem should be.
cxwrench is offline
Old 01-20-21, 05:30 AM
Geepig
Geepig's Avatar
Bikes: Romet Jubilat x 5
Quoted: 111 Post(s)
Liked 94 Times in 75 Posts
We do not know who or where the manufacture is, we do not know what caused the crack - so how can we know what the manufacturer should or should not do? I could sell you a brand new looking Romet Jubilat tomorrow, knowing that the manufacture, Romet SA, went to the wall in 2005 and won't be honouring any warranties.
Geepig is offline
