Hub Ball bearings
Hub Ball bearings
Old 01-20-21, 04:17 AM
Seb1987
Quoted: 16 Post(s)
Hub Ball bearings
Today I opened up my hubs to inspect, clean and grease them for the 1st time in 4 years. I believe I may need to get new ball bearings but are all hub ball bearings the same size?
Seb1987 is offline
Old 01-20-21, 04:30 AM
Geepig
Geepig's Avatar
Bikes: Romet Jubilat x 5
Quoted: 111 Post(s)
Liked 94 Times in 75 Posts
Great! Yes and no.
It really depends on what kind of equipment you have, but generally the balls are larger at the rear and some of the largest I have found were supporting the rear sprocket of a kiddie bike. As I tend to work at the cheaper/older end of the bike spectrum I notice that the cones tend to suffer more damage than the balls, it often looks like damp settles on one side of the cone and begins to corrode them out in that area if left in one position for several years. The balls generally do not show the same level of damage, but I suggest examining the bearing surfaces carefully, maybe with a magnifying glass, to look for pitting. If they look good, then there is no harm in replacing the balls.
The best thing of all is cleaning, regreasing and adjusting.
Geepig is offline
Old 01-20-21, 04:43 AM
FTB
Luke
Quoted: 21 Post(s)
Liked 10 Times in 7 Posts
Good idea replacing the ball bearings , can make a big difference especially in conjunction with the fresh grease, but I guess you knew that.
Two things to keep in mind
  1. Bearing size
  2. Bearing grade/tolerance specifications
Ball bearings come in different sizes so you need to mkae sure you purchase the correct ones for your hub. If you have a shimano hub, you can search up the tech docs for your hub here using the product discipline and search function (road hubs > 'road' etc) and often find out the ball bearing size just to be 100% sure otherwise you can often search online. This is different for front and rear hubs even in the same series. https://si.shimano.com/#/en/search/Component
Bearing grades - the lower the number, the better the ball tolerances are, so grade 3 is best and grade 100 is worse etc.
FTB is offline
Old 01-20-21, 08:03 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 744 Post(s)
Liked 506 Times in 300 Posts
Buy a digital caliper and measure what you have. These devices are inexpensive and answer a lot of questions. Typically bearing balls are 3/16" front and 1/4" rear, but some hubs don't follow this convention.
Why do you think that you need to replace them? If, after cleaning bearing balls, cones, and cups, you see nice smooth bearing tracks with no chipping or galling, just regrease and adjust.
Moe Zhoost is offline
Old 01-20-21, 08:14 AM
HillRider
Quoted: 1595 Post(s)
Liked 427 Times in 332 Posts
Also, don't overbuy bearing grade. Grade 25 balls are the most commonly used and are far more than good enough but low enough in price to splurge on. Paying a huge premium for Grade 10 or for ceramic balls is a waste of money for no benefit.
HillRider is offline
Likes For HillRider:
Old 01-20-21, 08:35 AM
dedhed
SE Wis
dedhed's Avatar
Quoted: 1483 Post(s)
Liked 980 Times in 663 Posts
At $11/hundred or so there is no reason not to stock & replace most bearing balls if you plan to work on bikes.
https://www.bocabearings.com/product...-(100-pcs)-411
dedhed is offline
Likes For dedhed:
Old 01-20-21, 09:37 AM
pdlamb
Quoted: 1439 Post(s)
Liked 561 Times in 374 Posts
I'm on both sides.
If you've got fresh bearings ready to go (or you need a break, run down to the LBS to get some), put in new bearings.
If the old bearings are clean and shiny, re-use them.
The only time you need to put yourself out to get new bearings is when the old ones are cracked, pitted, or (heaven forbid) rusty. Then you need to get new bearings if you don't have any. Take a couple with you when you go the your LBS, or measure them carefully if you need to mail-order.
pdlamb is offline
Old 01-20-21, 12:24 PM
davidad
Quoted: 489 Post(s)
Liked 100 Times in 88 Posts
If the bearings have their original finish they a good to reuse.
davidad is offline
Old 01-20-21, 12:50 PM
cbrstar
BMX Connoisseur
cbrstar's Avatar
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 297 Post(s)
Liked 39 Times in 27 Posts
There's actually quite a few sizes. Go down to your LBS and they will have a special ruler to measure them and they probably have what you need in stock.
cbrstar is offline
Old 01-20-21, 12:55 PM
Russ Roth
Quoted: 510 Post(s)
Liked 357 Times in 278 Posts
Not really true though the quality of the hubs can have an impact as well. Dura Ace and Record come with higher grade bearings because they spin better and can last longer. Although I think ceramic often costs stupid amounts of money spending a little extra on hubs will help them spin a little better.
OP: Get the park spoke ruler for future such repairs, it has holes for all the sizes of bearings bikes use, which ever hole it barely manages to drop through is the size. When it doubt bring one of each to the LBS and they'll do just that or a good mechanic will just know by sight in all likelihood. Nothing wrong with changing them every few years, even if everything looks good bearings can deform from the pressures on them over time and new bearings will keep everything running smooth.
Russ Roth is offline
Old 01-20-21, 01:42 PM
dedhed
SE Wis
dedhed's Avatar
Really better yet is to get a cheap digital caliper as it is useful in all things bike related. Measuring seatpost diameters, stems, frame spacing, and even bearing diameters for about the same price.
dedhed is offline
Likes For dedhed:
Old 01-20-21, 01:56 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1251 Post(s)
Liked 439 Times in 343 Posts
It's easy to measure bearings with a simple 12" ruler.
Line the bearings up along the ruler.
1/4" = 4 per inch or 8 per 2".....
3/16" = 8 per 1.5" or 12 per 2.25" or 16 per 3"......
Why does something that simple require special measuring tools when just a bit of thought......
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 01-20-21, 02:02 PM
Russ Roth
Quoted: 510 Post(s)
1. those puppies just like to roll away on me with the slightest breeze.
2. honestly this method never occurred to me. I can just tell by visual now but used the ruler in the past.
Likes For Russ Roth:
Old 01-20-21, 02:22 PM
HillRider
Anything better than Grade 25 barrs is an absolute waste of money. Cheap hubs may use Grade 100 or Grade 200 balls but the upper level cup-and-cone hubs are served very well with Grade 25. I have a Dura Ace rear hub with over 75,000 miles still in daily use It has never seen anything but Grade 25 balls, redone at 7000 mile intervals, and both the original cones and races are still in excellent shape and smooth as glass. I remember people claiming that Campy Record hubs used "matched sets of Grade 5 balls" which was more hype than any benefit.
+1 on that Park ruler and it's useful for more than sizing bearing balls. It has spoke length measuring slots, the somewhat obsolete sizing holes for crank cotters and is a good rigid 12+" ruler for measuring chain "stretch". It's cheap for all that it does.
Old 01-20-21, 03:01 PM
pdlamb
Seconded.
pdlamb is offline
Old 01-21-21, 02:58 AM
Geepig
Geepig's Avatar
Quoted: 111 Post(s)
A small empty box with an inch marked from one corner, and those balls are not going anywhere.
Geepig is offline
Old 01-21-21, 03:47 AM
grizzly59
Quoted: 184 Post(s)
Liked 113 Times in 82 Posts
If you are going to reuse balls, I would put them back in the same side of the hub they came out of.
grizzly59 is offline
Old 01-22-21, 12:50 AM
bitpuddle
Bikes: Cinelli Nemo Tig / Battaglin Power Plus / Giant TCR SL
Quoted: 18 Post(s)
Liked 12 Times in 9 Posts
What hubs are these? Do the bearings appear pitted/worn?
I’d just clean the hub and bearings and add fresh grease, unless something seems worn (there is play or they feel rough).
bitpuddle is offline
Old 01-22-21, 05:17 PM
davidad
Quoted: 489 Post(s)
It doesn't mater. The tolerances for the balls is too small to make a difference.
davidad is offline
Likes For davidad:
Old 01-29-21, 07:42 AM
Seb1987
Quoted: 16 Post(s)
Originally Posted by pdlamb View Post
I'm on both sides.
I'll go to my LBS then with one of the ball bearings cause just one of them looked like it has a tiny tiny bit og rust on it.
Seb1987 is offline
