How to add padding to drop bars?
Old 03-04-20, 08:32 PM
jischr
I’ve been losing muscle mass in my right hand for a while. This is the first year it seems I will need more padding on my drop bars to alleviate pressure on the bones. For those in a similar position, did you double wrap with CX tape, or add silicone pads to the bars, or find gloves with more padding built in? Anyone use anti-vibration work gloves? One thought I had was to slice open/install thin mtb grips and then tape over them. Open to any suggestions.
Thanks
jischr is offline
Old 03-04-20, 08:52 PM
Wileyrat
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 335 Post(s)
Liked 220 Times in 133 Posts
While I'm not losing muscle mass in my hands, I have CTS, and it sounds similar. Personally, I like the tape I use, so I've gone with thicker padding in my gloves.
This is going to be a bit more controversial, but imho one of the best things I did was go to CF bars. They eliminated most of the road buzz out that was irritating my hands.
Ymmv.
Wileyrat is offline
Old 03-04-20, 09:10 PM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
I double wrap. Once I used old inner tubes for the inner wrap, but that was relatively hard and unforgiving.
I have large hands so I like the increased diameter double wrapping provides. If I didn't have large hands I might try the gel pads and a single wrap.
tyrion is offline
Old 03-04-20, 09:21 PM
DeadGrandpa
DeadGrandpa's Avatar
Bikes: Too many, yet not enough.
Quoted: 491 Post(s)
Liked 308 Times in 199 Posts
I have similar symptoms. First, I ordered Grab On Grips, which are closed cell foam cylinders that slide on your naked handlebars with a little dish detergent as lubes. Then I wrapped the result with gel padded bar tape. If you don't want the larger diameter bar, I recommend just the Grab On Grips.
Another strategy is to elevate the handlebar with a stem whose angle of rise can be adjusted. Less weight will be on your hands as you will be sitting more upright. You may have to give up the aero position.
DeadGrandpa is offline
Old 03-04-20, 09:37 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10944 Post(s)
Liked 7,469 Times in 4,179 Posts
What thickness bar tape have you been using? If its basic stuff, then maybe 3mm bar tape is all you need since that's double the thickness of most under $20 tapes.
Or gel pads with 3mm tape over for more thickness and damping.
There is 4mm thick tape too...
mstateglfr is offline
Old 03-04-20, 09:48 PM
katsup
katsup's Avatar
Bikes: 1995 ParkPre Pro 825 2021 Soma Fog Cutter v2 and 2021 Cotic SolarisMax
Quoted: 607 Post(s)
Liked 560 Times in 318 Posts
I use a vertically sliced inner tube (MTB tube), then 2.75-3mm bar tape on top of that.
katsup is offline
Likes For katsup:
Old 03-05-20, 02:17 AM
Miele Man
Quoted: 1324 Post(s)
Liked 927 Times in 640 Posts
I'm adding extra padding to a dropbar on one of my converted MTBs.
I'm using contact cement and pipe insulation. I have short fingers so adding extra padding all the way around the handlebar is not good for me.
I have cloth tape on my handlebar. I'm contact cementing pipe insulation to the top and back of the handlebar. Then I'll use a razor knife to taper the pipe insulation. Once that's done I'll add a new layer of cloth tape over the pipe insulation. This way I'll have the extra padding where I need it but without an overall thickening of the handlebar.
Cheers
Miele Man is offline
Likes For Miele Man:
Old 03-05-20, 06:08 AM
alpharalpha
alpharalpha's Avatar
Quoted: 44 Post(s)
I was just thinking similar after ride yesterday; might front suspension help? Otherwise perhaps a bike with more upright configuration so not putting weight/pressure on handlebars.
alpharalpha is offline
Old 03-05-20, 07:56 AM
BobbyG
BobbyG's Avatar
Quoted: 1362 Post(s)
Liked 1,669 Times in 825 Posts
Since my 40s I've been padding my bars with 1/2" foam pipe insulation. Six feet for under $4. It usually lasts for a few months, before losing its cushion. I wrap the ends with some black duct tape. The foam is not slick like you'd imagine, and my grip feels secure.
I'm sure, someone more artful than I could make it look good.
BobbyG is offline
Likes For BobbyG:
Old 03-05-20, 08:20 AM
rumrunn6
rumrunn6's Avatar
Quoted: 5222 Post(s)
Liked 3,574 Times in 2,338 Posts
Originally Posted by BobbyG
now I want pizza, thanks
rumrunn6 is offline
Likes For rumrunn6:
Old 03-05-20, 09:20 AM
tagaproject6
tagaproject6's Avatar
Quoted: 551 Post(s)
Liked 277 Times in 145 Posts
Since my 40s I've been padding my bars with 1/2" foam pipe insulation. Six feet for under $4. It usually laste for a few months, before losing it's cushion. I wrap the ends with some black duct tape. The foam is not slick like you'd imagine, and my frip feels secure.
That watch must be incredibly shock resistant! What is it?
tagaproject6 is offline
Old 03-05-20, 12:59 PM
BobbyG
BobbyG's Avatar
Just an old cheap $20 watch from Target...there's a rubber pad under it. The watches last 5-6 years on the bike. My newest bike has a computer that constantly shows the time, so I don;t need it on there. By the way, that's an analogue thermometer below it.
BobbyG is offline
Old 03-05-20, 01:27 PM
John_V
John_V's Avatar
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times in 85 Posts
I would try changing your gloves first. Try the Specialized BG Gel gloves. They are very well padded and in the right places. I have arthritis in my thumbs and with these gloves, I've had hardly any incidents of my hands. If they don't make a difference, then double wrap or use gel pads.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
John_V is offline
Old 03-05-20, 02:16 PM
jlaw
Bikes: 2015 Spec. AWOL Elite,2022 Spec. Diverge, 1984 Trek 620 1985 Trek 620, 1979 Trek 710
Quoted: 394 Post(s)
Liked 194 Times in 110 Posts
+1 on the suggestion to use foam pipe insulation (from Home Depot,etc.). I've used it as a temporary cover for bare bars while fine-tuning brake lever location - very plush. Also good for larger hands. It looks goofy, but you can be creative to disguise it if nec.
Slightly less goofy-looking and more 'finished' is the foam Grab-On Grips product - and very 1970's! https://grabongrips.com/bicycle-grips
Or, I have used Planet Bike gel pads under regular bar tape with good results https://www.planetbike.com/store/century-gel-pads.html
jlaw is offline
Old 03-05-20, 06:55 PM
Kabuki12
Quoted: 870 Post(s)
Liked 2,264 Times in 1,268 Posts
Whatever tape you choose , still get nice cycling gloves with padding. I ride vintage road bikes so my bikes have cotton bar tape. I did find padded cotton bar tape at the Eroica California event a couple of years ago and I like it a lot. It didn’t come in any packaging so I don’t know the brand, but it is nice and easy to wrap.
Kabuki12 is offline
Old 03-05-20, 08:02 PM
skidder
Pennylane Splitter
Bikes: Yes
Quoted: 1776 Post(s)
Liked 1,433 Times in 983 Posts
This ^^^^^ I put strips on the top part of the bars, above the hoods and toward the stem. My tour bike has two layers. I use a little wood glue to fasten it in place - its just sticky enough to hold the rubber in place while I put the bar tape on, and makes it easy to remove/replace later on.
skidder is offline
Likes For skidder:
Old 03-05-20, 08:22 PM
Mountain Mitch
Mountain Mitch's Avatar
Bikes: Specialized Roubaix Exp ert Road and Specialized Stump Jumper FS Mountain; De Vinci Caribou touring, Intense Tracer T275c, Cramerotti, Specialized Allez, Condor
Quoted: 164 Post(s)
Liked 92 Times in 56 Posts
I use a 6 inch piece of 3mm bar tape laid along the upper surface of the hand position in the drops. Then I tape as normal. I agree that good gloves also will help. I haven’t tried CF bars but can see they might be a nice touch.
Mountain Mitch is offline
Old 03-05-20, 10:55 PM
Slightspeed
Slightspeed's Avatar
Quoted: 741 Post(s)
Liked 818 Times in 421 Posts
I like the feel of Brooks leather bar wrap, but it has no cush, so I wrapped it over some cheap foam tape that works for me. A good pair of gloves will also help a lot, as will wider tires at slightly reduced pressure. I've also used Specialized silicone gel pads under foam tape, and it works well too.
It looks a little fat, but has a nice feel, and plenty of cush for me, along with Pasela 28 tires.
Slightspeed is offline
Old 03-05-20, 11:16 PM
Maelochs
Maelochs's Avatar
Quoted: 7648 Post(s)
Liked 3,464 Times in 1,830 Posts
Old inner tubes work well. I often split them and wrap pretty tightly, but when I want cushion I use them whole and don't stretch them much.
Maelochs is offline
Old 03-06-20, 01:25 AM
Mitkraft
Quoted: 62 Post(s)
Liked 14 Times in 11 Posts
I do both double layer as well as gel pads. Use the Planet Bike gel pads off Amazon and Profile Design shock gel tape. I first wrap the bar with my old tape. Then I tape the gel pads in place. Then I do a final wrap with my new tape. I do this on my gravel and road bike.
Mitkraft is offline
Old 03-08-20, 04:33 PM
canklecat
canklecat's Avatar
Quoted: 4559 Post(s)
Liked 2,802 Times in 1,800 Posts
Arundel Synth Gecko. Most comfy bar wrap I've used, short of the foam pipe insulation trick.
It's 100% silicone foam, soft, grippy and durable. No adhesive, can be rewrapped almost indefinitely. Doesn't take a set/permanent curl, and will straighten out shortly after removing. Washes easily too. It can cut fairly easily against sharp edges such as exposed bar ends and some brifter housing assemblies, so be careful wrapping around those areas.
When I was recovering from a shoulder and neck injury I double wrapped, using cheap generic black foam tape against the bar, then the Synth Gecko over it. As I regained arm strength I switched to just the Synth Gecko so it's not quite as sausage-fat looking.
Aesthetically... not the best looking stuff. No matter how it's wrapped it tends to look like articulated metal conduit or sausages. Some of the colors are neon-crazy. I bought a roll of it in hi-vis yellow at the LBS for about $15 because nobody would pay full price for it. But that discount persuaded me to buy more at full price in a color I'd prefer.
But for us cheapskates, the old inner tube trick works great. Wrap it directly around the bar, then overwrap with whatever bar wrap you like. Really dampens road vibration without adding excess thickness. It won't look as meaty as the Synth Gecko double wrapped over or under other bar wrap.
canklecat is offline
Old 03-08-20, 08:16 PM
jischr
Minor update - last week's ride was on Cinelli cork over aluminum bars. Today's ride of the same distance and a little longer time (30 mph head wind gusts) on Zipp CX tape over carbon bars did not generate the same amount of pain/soreness as last weeks ride.
Only a sample size of one but I think new bar tape is the minimum. May add gel or double wrap with the Zipp tape or try one of the options you all have mentioned above. Thanks for all your comments.
jischr is offline
Old 05-26-21, 11:50 PM
tarinalynn
Bikes: Riding the same unlabelled sketchy AF Craigslist bike bought 20 years ago for $75.00, restoring a Kuwahara Butte 1987 (87067956), Kuwahara Shasta, a hand built Brodie Custom early 90’s, and a bunch of miscellaneous Frankenstein kid bikes
Quoted: 5 Post(s)
Liked 3 Times in 3 Posts
Great idea. I often have tingles/pins and needles in my right hand regardless of whether I am cycling or not. I am going to give this a try!
tarinalynn is offline
Old 05-27-21, 02:56 AM
Lazyass
Quoted: 2432 Post(s)
Liked 638 Times in 395 Posts
Zipp Service Corse CX bar tape uses a strip of gel instead of a regular tape strip. Has really good cushion and it doesn't leave any residue on your bars when you remove it.
Lazyass is offline
Old 05-27-21, 07:58 AM
BobbyG
BobbyG's Avatar
I hope the padding helps, but tingling in the hand, especially when not cycling, sounds more like some sort of nerve impingement in the wrist, elbow, shoulder or neck.
My hand discomfort is more of a dull ache and soreness, directly at the point where my hand rests on the bars. Although with the padding and varying my hand placement, I am fine for longer rides.
Regardless of what is causing your hand discomfort/tingling, I hope the padding helps.
BobbyG is offline
