Seat tube sleeve
Seat tube sleeve
I putting the finishing touches on a new build and it will have a sleeve for the ST. The ST itself is 1.125.
For a sleeve, will a 1.25 OD tube with a .049 wall work well or should I use a 1.25 OD with a .058 wall?
Thanks in advance.
Brandon
Thanks in advance.
Brandon
Quoted: 18349 Post(s)
Liked 4,502 Times
1.25 = 31.75mm
.049 * 2 = .098 = 2.49mm
.058 * 2 = .116 = 2.95mm
So, your sizes are:
31.75mm
29.26mm
28.8mm
So, looking at common seatpost sizes:
31.6 & 31.8 are available (no sleeve)
You can probably source 29.2 and 28.8 seatposts, or thereabouts, but they are less common.
Let's see:
(31.75 - 27.2) / 2 = 2.275mm ==> 0.0896 tubing.
So, you might do better with either no sleeve, or some pretty thick 0.089 tubing (27.2 seatpost).
So, your sizes are:
31.75mm
29.26mm
28.8mm
Let's see:
Thanks guys. I think I should have clarified that the sleeve will be for the outside of my ST. I'll have a 27.2 post.
framebuilder
You need a 1 1/4" tube with a wall thickness of 0.058". If it is .049" there will be too much space between the inside of the bigger tube and the outside of the smaller tube for proper brazing clearance.
Thanks Doug. That's what I had figured. I have some here so that's good. Likely have it turned down just a tad for my liking.
framebuilder
Randomhead
Liked 3,686 Times
yes, turning it down is almost required, it's far too clunky otherwise.
