Recommend me a light set and helmet for commuting
Bikes: Pure Fix Romeo
Looking for a new light set and helmet for my daily commute. Sometimes I commute as late as 12pm. So prefer a bright light that won't break the bank. Same as the helmet. But prefer something very durable.
Thank you!
Thank you!
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
Just about any CREE XML T6 emitter up front will work and a Cygolight Hotshot in the rear. As far as the helmet, look for ventilation and a clip on visor.
helmet, fit is king ... even moreso than a bike frame ... i ended up getting it professionally fitted (100€) but it's cheap insurance for your noggin.
i ended up going with an ABUS S-Force Peak MTB helmet because it fit my oblong head the best
https://www.wheelies.co.uk/p22321/Abu...TB-Helmet.aspx
Bikes: 2017 Kona TI, 2016 Bike Friday Haul-A-Day, 2015 Bike Friday New World Tourist (for sale), 2011 Mezzo D9, 2004 Marin Mount Vision Pro - for now :)
Quoted: 103 Post(s)
Liked 5 Times
Not sure if this is part of your question, but I much prefer a light on my helmet. Much more control of where I want to see - I can "flash" a car approaching from the side to get their attention, and I can lower my head/light when approaching other cyclists on the MUP so as not to blind them. Also, works great when you have to work on the bike in the dark. Mine has a flasher/red in the rear as well.
Bikes: Old steel GT's, for touring and commuting
Quoted: 39 Post(s)
In addition to the helmet lights (Planet Blaze .5W helmet mount light & Planet Bike rear helmet flasher) and the handlebar one (1.7w flash-light in a bicycle flashlight holder), I run a rearward facing Mars 4.0
That's what I recommend.
In addition, I run a 1 watt Fenderbot on my rear fender and am experimenting with a fairly powerful (3w) flashlight in a mid-fork mount to better illuminate pot holes. At times I commute regularly both ways in full dark.
You can get the Cree XM-L U2 headlight from Keygos.com. It comes with both the handlebar mount and a head mount that can be attached to a helmet with the supplied gear. I know because I tried it yesterday on the helmet. I found it way too bright for a helmet light as you'll blind anybody you face. Maybe I'll try it someday outside, but it really isn't necessary in NYC. I feel conspicuous enough with it mounted on the bars.
For the taillight I just use a PB SuperFlash.
Bikes: Canyon Roadlite AL
Liked 11 Times
Truth. My Cygolight is simply in another dimension from anything I've ever seen or used before. Remember the first time you ever saw HID headlights? Like that.
I have a nice CCM hard shell helmet. It is heavy but it looks like it will stop the first couple of bullets that hit it. The type with the thin plastic shell always annoyed me. It would crack at the first bump into anything. This one is about 4 years old ans still looks good.
