Tubus bike racks, rust?
Hello all,
I am in the market for a bike rack for my gravel bike, and came across the Tubus brand as one of the most (apparently) renowned brands.
I am about to pull the trigger on a Tubus Grand Tour rack, but the only thing that gives me pause is the fact that it is made of steel. That, combined with the fact that many reviews mention the paint rubbing off where the panniers sit on the rack, rust seems to be an issue. Check out the photo on this review: https://tomsbiketrip.com/tubus-logo-...r-rack-review/ With the rack marred with rust. I would shudder to think that a rack costing around $150 would rust and wear so poorly?
These racks are SUPER expensive, compared to the competition, so I am dumbfounded as to why they are made out of steel? Why not aluminium (corrosion resistant) like most other racks seem to be.
Is this a non-issue, am I overthinking it? I might have to go instead with the Ortlieb Rack Three https://www.ortlieb.com/en_us/rack-three which is aluminium. If the paint rubs off, at least it will just be bare aluminium, not rust.
Thanks!
Thanks!
Tubus racks are great racks, I got a front and rear for a bike to be used for long trips, and am glad I did---but now we come to the "but"
but, I have also used good quality aluminum racks for decades and decades, and commute nearly daily using these reasonably priced, but well built enough racks, and yes the paint rubs off a bit, but they work perfectly fine.
in both my opinion and experience, a good quality alu rack is perfectly good--especially if you aren't loading the heck out of it, which on your gravel bike, is probably not the case.
but for your specific question, yes tubus racks can have paint scuffed off and surface rust happen--but I put tape on the contact points to minimize this, and have touched up tiny spots with regular old black metal paint I have around for doing my house porch railings.
do you need a steel Tubus rack, most likely not.
just know that good alu racks work fine, at easily half the cost or less.
oh, the aluminum "Racktime" racks are well made, we used one for a while and it is a good solid rack, but there are many well established similar alu rack brands out there. Don't go for a cheapie imo.
Quoted: 2604 Post(s)
Liked 1,933 Times
My panniers rubbing an aluminum rack wore about a third of the way through a strut in some 5-6 years' of commuting.
Since I'm saving two tanks of gas every month commuting by bike, I spent the money and replaced that rack with a Tubus rack. That was eight or ten years ago. My rack now has a bit of surface rust. At the rate it's deteriorating, I figure my grandson can inherit the rack when I retire, and use it should he decide to bicycle commute. He might want to replace it before he does a cross-country trip after he retires. Or he might decide to carry less than 50 pounds on the rear rack on that trip...
The advice of "use electrical or duct tape" on it, is like WTF. I shouldn't have to do that.
I have commuted using a simple triangular $25 aluminium rack for years, also with heavy panniers. Yes, the paint rubbed off. But since it was aluminium, it just showed the bare aluminium underneath, and no rust ever formed. The aluminium itself never wore through or weakened, with daily pannier use for 4+ years.
I have read Tubus and Racktime are actually the same company. Which to me makes it even weirder why Tubus doesn't make aluminium racks...
I think I'll stick to aluminium. Thanks for your honest feedback.
But a rusted rack is just unsightly, and not something I want to deal with. Plenty of quality brands like Ortlieb and Bontrager make aluminium racks, so I don't necessarily see this as a choice between "cheap junk" and Tubus.
I have a aluminum rack that is worn quite a bit, but it is about 25 years old and has been used a lot.
I have another alu rack, probably cost $30 , has been used for ten years, hardly any wear marks, just putting some electric tape on contact points helps a great deal.
re steel vs alu, its about repairability I guess, if there wasnt an advantage, they wouldnt make them.
but in the end, you have options, lots of them, and you've made a decision, so all's good.
Liked 1,933 Times
I get your point on spending more for a quality product, I am the same way. I don't mind paying more if it lasts longer.
If you're more concerned with appearance than load carrying capability -- which is a valid personal choice, albeit not mine -- you might take a look at the stainless Tubus racks. Those are priced high enough to trigger my personal "too much!" flag, but I'll still stop and drool when I see one. They look so classy!
Quoted: 3462 Post(s)
Liked 1,468 Times
I use a bit of black nail polish to touch up my Tubus if it gets a wear spot on it. If you buy silver, I do not know if there is a nail polish color for that.
Nail polish is great, has a tiny little brush in the lid, durable, and only takes a few minutes to touch up wear spots. But do that outside in case of drips.
I also bought some clear plastic tubing at the hardware store, slit it lengthwise, put that over the tubing where the chaffing is worst, that is held on with electric tape and small zip ties (zip ties were added after photo). I think it had an ID of 3/8 inch, wall thickness of 1/16 inch.
I am happy with fairly inexpensive aluminum models, but steel is fine. Steel bike frames look fine, How many nice $$$ lugged steel frames have you seen that were unsightly rust buckets? I personally won't spring for Tubus, but they hold up fine. The finish is durable and where it rubs off it probably continues to get rubbed so it likely stays shiny. A little wax on any surface rust would make it enough of a non issue for me if I even bothered with that. Some folks are fussier though. Personally I'd never bother putting on tape or whatever.
If you want the strongest most durable, they are probably it. Me, I figure good enough is good enough so I have blackburn, axiom, and even nashbar stuff.
Liked 1,468 Times
I have a question for others here, I have bought several Tubus racks, it is my recollection that they came with some thick tape to apply to wear spots but I never used it. Is my recollection correct, do they come with some thick tape to apply?
ADDENDUM:
Found it:
https://www.tubus.com/en/products/ac...ctive-foil-set
But maybe it was not included with the racks? I bought my Logo EVO and Ergo (discontinued) a decade ago, if it came with it I do not recall.
ADDENDUM:
Found it:
Quoted: 599 Post(s)
Liked 284 Times
My Tubus Tara front rack did not come with any tape that I remember. I've seen a lot of Tubus racks on the road but not sure I've seen any that had rusted much at all. If it happened, a little light sand paper and a quick spray of Rustoleum in flat black would cure that every few years. I have Axiom aluminum rear panniers and been very happy with their durability though they do show areas of discoloration where the panniers attach.
Quoted: 1182 Post(s)
Liked 833 Times
I have used my Tubus racks for about 15 years. They have seen a lot of use. I have not got around to painting areas where the finish rubbed off. I just coat the rubbed areas with a coat of auto wax periodically, and that is enough to keep them shining without rust. However, touch up paining, as robow suggested, is probably the best way to go.
This is my Tubus Tara front rack. This spot started showing about 10 years ago.
Tubus racks are powder coated, not painted. If you use panniers with plastic attachment points it'll likely take a long time before they wear through the powder coat. If you want to protect the rack at all costs, you can apply some frame protection stickers or other protective tapes just the way you'd protect your driveside chainstay on your bike frame.
I believe Tubus is considered the gold standard because their weight to carrying capacity is better than the equivalent aluminum rack. The Old Man Mountain Classic Rack (aluminum) weighs 1134g and can carry up to 70lbs. The Tubus Cargo Evo (steel) weighs 780g and can carry up to 88lbs. The Blackburn EX-1 (aluminum) weighs 535g and can carry up to 45lbs.
Despite being susceptible to rust, steel racks often last longer because they have a much longer fatigue life than aluminum racks. If your rack does crack on tour, both metals can be welded together, but the aluminum weld will be much much weaker unless the rack is heat treated afterwards.
Either material is fine for making racks but I'd personally stick with steel for piece of mind.
Bikes: Specialized Tarmac Expert, 2002 TREK 520, Schwinn Mesa WINTER BIKE, Huffy Rock Creek 29er, 1970s-era Ross ten speed. All my bikes are highly modified(except the Tarmac) yet functional, and generally look beat to ****. .
Quoted: 68 Post(s)
Liked 88 Times
Steel is a very general term. Not all steel is created equal. Tubus racks are cromoly. Wipe off a little surface rust once or twice a year and touch up with paint if the scuffs bother you. Last forever.
Quoted: 137 Post(s)
Liked 81 Times
Yes steel can rust, alum8num can oxidize and rain makes mud. I had extra rails brazed onto a Tubus Cargo and it rusts a bit at the brazing a few years after I painted it so I dabbed some Ospho on it.
Oh, you can get sunburn from too much sun also.
If the use is touring it’s not exactly an environment for pristine shiny equipment.
Btw if anyone knows where I can get a Tubus Logo Classic 29” I sure woukd appreciate it. Can’t find one anywhere.
Bikes: 2000 Santana Sovereign SE; 2005 Co-Motion Speedster; Kona Kilauea with various dorky commuter accoutrements; Mercier Kilo TT fixie; Burley Fladbed trailer for groceries, bags of cement and the like.
Quoted: 95 Post(s)
Liked 85 Times
Or spend a tad more on a stainless-steel Tubus Cosmo. Here's ours after roughly 10,000 miles, including a 3,800-mile fully loaded crosscountry last summer on the tandem. Spotless.
I Know, I know, slight exaggeration....
Liked 1,933 Times
I seem to remember my Ortlieb bags (also expensive -- and worth it!) came with plastic or rubber bushings to go over skinny steel rails. As one of my bikes has an anodized fat aluminum rack that fit the bags just fine and the other has the skinny Tubus steel rack, I ignored it and have been riding with "naked" bag hooks and no problems.
Quoted: 95 Post(s)
Liked 85 Times
Ha, yes, slight! I paid roughly $180 with tax. That comes out to 1.8 cents a mile for the first 10,000 miles, and it will last many more. I'm a cheapskate--except for stuff I don't want breaking on tour, especially if I expect it to last the life of the bike.
My usage case probably isn't typical though. If I had bought one set of racks for a standard touring bike and toured with regular panniers from then on a set of tubus racks would have not been that big of an investment. Not a necessity, but not crazy over the top either.
Liked 1,468 Times
That's kind of why I recommended not buying no name brand aluminum racks, but my good quality ones have been fine--but I did drink the kool-aid and got tubus ones for my longer, tougher trips.
Re the stainless steel ones, seems to I've seen bonkers high prices in Canadian for them, like $350 for a rear one. Ouch, that's a lot for mostly an aesthetic look.
Pretty certain my two level rear was 125-150 , and the front Tara was on sale for about 75, but this was 6 years ago now I think.
Glad I got them though, for the trips I did and hopefully will do in future
Liked 1,468 Times
If you want aluminum to avoid any fear of some rust, the Racktime racks are well built. I bought the Racktime Addit for my Lynskey.
Yes, I know it is not quite horizontal, I was making some adjustments to lower the rack a bit, put some clear plastic tubing to protect the paint, etc., and was rushed to get a couple photos before the sun set. The angle was adjusted soon after the photo.
