Converting to tubeless question
Quoted: 192 Post(s)
Liked 11 Times
I have UST tubeless wheels and tires and will be converting from tubes to tubeless. Internal rim width is 19mm and seeing conflicting info as to whether I should use 21 or 25mm rim tape? Also...should there be one layer of rim tape or 2?
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
If it is a UST rim, isn't the rim bed free of holes? A feature of UST is that it is supposed to be able to seal without tape. If this is not the case, depending on the tape used, one turn with about 4-6" overlap should suffice. To account for the channel in the center of the rim bed, your tape needs to be 2-3mm wider than the internal width, in order to ensure the tape is wide enough to touch both sides of the rim while also conforming the contours of the center channel.
Advocatus Diaboli
Quoted: 4760 Post(s)
Liked 1,539 Times
Quoted: 532 Post(s)
Liked 621 Times
The tape serves two purposes, as was explained to me a few years ago. Assuming the rim bed is drilled (as nearly all are), it needs to cover the spoke holes and, secondarily, promote a good seal between the tire and rim. To do that second part it needs to go right up to the edge of the rim bed. You may actually see some folks here talk about "building up" the rim bed to get a better seal.
That said, I have a set of rims that are not UST, but also do not have a drilled rim bed, and they are not taped, and they hold air just fine.
Likes For Badger6:
Thread Killer
Quoted: 3195 Post(s)
Liked 1,731 Times
Just curiosity, but why does tape need to be that wide and/or be done at different widths for different rims? That is, why can't tape just be the same width for any TL rim width, presuming spoke hole diameters are pretty uniform, plus some extra as a safety margin. For argument's sake, why can't a 15-18mm width tape be used for any TL rim?
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
Advocatus Diaboli
Liked 1,539 Times
Quoted: 942 Post(s)
Liked 527 Times
Which UST rims do you have? I have Ksyrium Pro UST's and tape is not needed. If you do need tape 4mm wider than ID and doing a double wrap is what I do.
Quoted: 532 Post(s)
Liked 621 Times
Advocatus Diaboli
Liked 1,539 Times
Cool. Would there then be reason to think if you had ordered the same wheels instead drilled with holes, you'd need to use tape wider than the center channel? I wonder if LB adjusts the hook/shelf distance or something when going undrilled, though that seems unlikely.
Quoted: 532 Post(s)
Liked 621 Times
Quoted: 192 Post(s)
Liked 11 Times
Cosmic Pro Carbon SL from a year or two ago. They arrive today and I know are setup with tubes, so assuming (maybe incorrectly) that they won't have rim tape..or that I should probably replace.
Jedi Master
Related question. I have an old set of shamal 2-way-fits that I have always run with tubes. What would it take all-in to convert these to tubeless? Tires, valves, sealant, is that it?
Liked 9,456 Times
That'd be all that you need, but I'd also recommend a sealant syringe (10-12 bucks on Amazon), which will allow you to add/remove sealant through the valve, which makes set-up and maintenance much easier and cleaner. Unfortunately, some valves don't have the ID to pass the syringe tube, so you might need to do a little research on that point before buying valves. I use the aluminum Muc-Off valves, which will pass the tube, if you don't want to be bothered with the leg-work of other options.
Advocatus Diaboli
Liked 1,539 Times
Quoted: 1838 Post(s)
Liked 1,711 Times
I also have an older set of Campagnolo Shamal 2Way fit wheels that I have always run tubeless. They already had the valves installed when I bought them brand new. The Hutchinson Fusion 5 tires I am using will hold air without sealant and I often don't bother using any. Right now, I have sealant in one tire and none in the other. I can't even remember which one has the sealant and which one doesn't
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Jedi Master
Liked 9,456 Times
In terms of tires, there's a lot of good ones out there. No need to rehash it here, but take a look through this current thread for some ideas - https://www.bikeforums.net/road-cycl...ess-tires.html
I'd recommend Orange Seal (regular, not Endurance or anything else) for sealant, but others have had good experiences with different sealants - just stay away from Stan's for road bike use.
Likes For Snotrub:
Jedi Master
Liked 9,456 Times
Sorry, that's not exactly in my wheelhouse, so I don't have any first-hand experience. I'm tubeless because I want fast and supple and was tired of changing tubes on the side of the road every few weeks. I think that Pirelli has some decent offerings along those lines, though.
Likes For WhyFi:
Quoted: 532 Post(s)
Liked 621 Times
Fat n slow
Quoted: 3260 Post(s)
Liked 2,086 Times
Likes For phrantic09:
Jedi Master
OK. Relax the price/durability preference. What tire would you recommend for someone who rides long distance and is looking to convert one of many wheelsets to tubeless to give it a try for the first time? I normally use cheap tires for training miles, but I can treat myself for this experiment.
