Floor Pump and Pressure Gauge Inconsistency...What number to believe?
Quoted: 192 Post(s)
Liked 11 Times
So I have two floor pumps (Topeak Elite and Lezyne Road Drive)...both solid quality. And two pressure gauges...one a Topeak digital and I forget the brand of the other. In any event, my inconsistent readings follow an interesting pattern. Both of the floor pumps register very close to each other, while the two seperate pressure gauges are also very close to each other, yet the pressure gauges always ready about 10PSI lower than the floor pumps. ALWAYS. I've triple checked this many times by attaching the pump, gauge then pump again to confirm the pressure didn't drop somehow etc. Has anyone noticed a similar issue? Seems fairly odd to me. A few PSI is no big deal, but now I don't know which gauges to trust.
Floor pumps measure pressure at the gauge, which is affected by how much pressure there is in the pump itself. That's at least part of the discrepancy. Assuming the tire gauges you have are calibrated--I would trust those.
Quoted: 20810 Post(s)
Liked 9,456 Times
I'm not being dismissive, but does it really matter? Usually you're going to target a certain pressure and then tweak from there. As long as you're getting enough precision to do that with your pumps, I wouldn't be worried about the accuracy too much.
Klaatu..Verata..Necktie?
Quoted: 10441 Post(s)
Liked 11,914 Times
Do they have better tire gauges nowadays? The one I bought 20 years ago seemed more like an expensive tool for letting air out of tires. It was Heisenberg's Pressure Gauge - It only let you determine what the pressure in your tires HAD BEEN before air blew out while taking the gauge back off the valve.
Likes For genejockey:
Liked 11,914 Times
Mind you, not knowing what that actual number is might bother you. It would bother me.
EDIT: The OP's post reminds me of an old saying - "The man with one watch always knows the time. The man with two watches is never sure."
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
What matters more is that your pumps are consistent with each other, and that they repeatably and accurately pump your tires to your desired specification.
The pumps may be empirically wrong, but if they're consistently wrong, then they're right.
Quoted: 4806 Post(s)
Liked 3,932 Times
My gauge doesn't suffer lost air. Thumb and index finger. I'd just develop a similar gauge and calibrate it with either of your gauges and what feels right out there on the road and go from there. (And best part - it works mid ride and takes up no jersey pocket space.)
Quoted: 3242 Post(s)
Liked 2,089 Times
If the digital tells you the floor pumps are 110psi while the pump says 100 and you want 100, pump to 90. If the digital tells you 90 and the pump says 100, pump to 110. "ish.
Quoted: 192 Post(s)
Liked 11 Times
i don’t disagree with anything said. More a curiosity if there is something fundamentally different in gauge readings on floor pumps vs. standalone pressure gauges. I find it very odd that the pumps are all off by 10psi relative to the gauges. Oh well.
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
If this is true, I kinda feel the pump makers would know of this effect, and would just rotate the PSI scale that's under the needle the correct amount to still be accurate.
There are a couple problems that stand in the way of compensating for this easily. Firstly, the gauges cannot really measure pressure in a linear way. There is a range at which they're most accurate. A pump designer at Lezyne must choose (for example) for their pump to be accurate at 90psi. So at 90psi, the gauge is right on, and maybe between 75 and 105, it's pretty good. Beyond that it's going to be less and less dependable.Even if the designer accounts for the offset between internal pump pressure at 90psi (in the tire) and the inside of the pump (105psi, for example), the offset will not be reliable for the rest of the gauge range, unless there's some sophisticated mechanical or electronic elements used to create a differential offset. You can absolutely buy pressure gauges that are accurate to within 2% or better across their whole range of measurement--but these are certified components, and it's not likely that you'd find them on $40 pump.
This is why it's useful to find the pressure that works for your tires according to the pump gauge and just stick to that.
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
How do did you test? If you pump up to a pressure with a pump and then check with a pressure gauge you can lose a little air when switching. If you connect a pump you will lose more air due to its greater volume, since obviously air has to come out of the tire to pressurize the pump.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Arizona Dessert
Quoted: 5345 Post(s)
Liked 2,169 Times
If you are OCD and need 0.05% accuracy get this plus some adapters. You can also interface with your PC and track results.
https://www.testequipmentdepot.com/d...3531dlm110.htm
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,041 Times
Quoted: 608 Post(s)
Liked 352 Times
Well with a presta valve, the pressure gauge on the pump will only be measuring pressure inside the pump/hose, not the tire. The pump has to generate enough internal pressure to overcome the pressure inside the tire holding the presta valve closed. A tire with a presta valve could not inflate the pump, since it's one way, by design and a presta chuck does not open the valve like a schrader chuck does. Only a standalone pressure gauge would work here, or performing at least one pump stroke.
Quoted: 472 Post(s)
Liked 1,028 Times
We keep seeing these sort of questions. If you're really concerned about accuracy, test everything on a truck tire or tractor tire. The change in pressure as you switch gauges will be less than they can measure. Bike tires are too small. Then pick your fav gauge and stick with that for your bike.
Or just wack your tires with a heavy lug wrench like truckers do and get a feel for it.
Advocatus Diaboli
Liked 1,533 Times
Some pump heads (like mine), have a little button on the pump head to release air from the tire (in case of having overshot your target); it's not like that button is pushing in the presta valve, it's just opening the seal a bit to let air escape.
Likes For Sy Reene:
No, I don't think so.. the presta valve is open after you start pumping, as long as the pump head remains affixed. The gauge is reading the overall equalized pressure of the whole system (which is fine; psi is psi). Releasing the pump head allows the presta valve to immediately close and the escaping hiss/air is that air that was in the pump's hose.
Quoted: 550 Post(s)
Liked 325 Times
They're all accurate. The tire gauges just let some air out as a side effect.
Quoted: 1814 Post(s)
Liked 923 Times
You had it right the first time. When the pump generates more pressure than what's in the tire, the valve is forced open.
The valve is only held open by the pump head when it's fit on wrong, normally it is closes at the end of each pump stroke.
The bleed button on the pump only releases pressure from the hose when using presta- you can't lower the tire pressure with it.
Advocatus Diaboli
Liked 1,533 Times
Bikes: yes, i have one
Quoted: 1139 Post(s)
Liked 1,182 Times
Liked 923 Times
No.. at least not with my pump (Bontrager -- one of these if it matters: Bontrager SuperCharger ). As soon as I twist the head on to the valve, it gives me a PSI reading. No pumping required to get initial reading. Once attached, I can hit the release valve and deflate the tire completely if I so wished.
Yes, I see you can do it that way (& how Bontrager describes), but I never do. I have a pump with that kind of head, but any imperfection of the seal & the tire loses pressure.
The pump (head) I mostly use has presta on one side & schrader on the other with a lever between. If you push it on far enough to open the presta valve, the tire deflates before the lever can be closed. Basically the same for the many pumps I've used back to the Silca frame ones.
