Double kickstands--any good?
I'm thinking of a Velo Orange or Pletscher double kickstand for our tandem--mostly to make parking in our garage easier. Any experience on the stability of these? Also, I've seen so many crushed chainstays on bikes from kickstand installation, and I definitely do NOT want to do that to this bike. Assume they can be tightened sufficiently without causing damage but again, any experience with this?
Quoted: 13 Post(s)
We have the Pletscher. It works very well. Easy to deploy - lift rear of bike (that takes some muscle with a tandem) and use foot to swing it down. The bike is quite stable, even with balanced panniers on. Recommended.
Bikes: 1998 Co-Motion Co-Pilot, 2015 Calfee Tetra
Quoted: 177 Post(s)
Liked 6 Times
We have double-legged kickstands on our single E-Bikes (weight is not really an issue). Don't know the brand. They work great.
Quoted: 2494 Post(s)
Liked 738 Times
That is a Pletscher (Esge) double leg holding up the rear of our Trek T900. We use double leg stands on all our tandems except the recumbent and that is a temporary situation. Recommended.
Quoted: 80 Post(s)
Liked 39 Times
We have 2 tandems, a Trek T900 with a single leg kickstand and a DaVinci Grand Junction with a double kickstand. I very much prefer the double kickstand. It is more stable. You can spin the rear tire to check for glass or other hazards, and lift the front and spin the front tire. You can remove the rear tire to change a flat since the rear tire is off the ground. If you have loaded cargo on the rear, it takes a bit of oomph to lift the rear to put the double kickstand down and to lift it up, but that is worth it for the benefits of the double kickstand.
Bikes: Schwinn, Nishiki, Santana, Trek, Rodriguez
Quoted: 189 Post(s)
Liked 106 Times
Alternatively, consider a "Click-Stand" and something to hold the front wheel straight like "Steer-stopper".
Love my double-leg kickstands! Unless you are trying to be ultra-light, they are well worth their weight (less than a full water bottle, likely).
Bikes: 1980's Spectrum 10 sp Campagnolo Centaur, 1990 Eddy Merckx 10 sp Campagnolo Centaur, Bushnell Tandem, Co-Motion Speedster Tandem
Quoted: 185 Post(s)
Liked 102 Times
We are planning an extended tour in 2021 and will be using a trailer to keep weight off the rear wheel, most likely the Burley Nomad. Does anyone know if these kick stands would interfere with the dropout attachment for the trailer?
Liked 738 Times
They don't. All the double leg stands I know of mount at the Stoker bottom bracket. The trailers all mount at the rear dropout(s). [FWIW] We are not big fans of using dual-track trailers with (single track) bicycles. Yes, they usually have a higher ultimate weight capacity but, respectfully, you are doing it wrong if you are exceeding the weight limit of a Bob Yak on even an extended tour. The tandem pictured above has a BOB ready Q/R, and we shop every week pulling the Yak. Getting ready for Thanksgiving for the last 5 or more years means exceeding the rated weight limit (70lb.) by at least 40lb. The trailer has stood up to this abuse just fine but the Pletscher stand has a bit of a limp. There are other double leg stands (cheaper too) that are better able to deal with 120lb. trailer loads. None are as elegant as the Pletscher though. Even the lowly Trek wheels are still as straight as new after all this abuse. Handbuilt wheels are absolutely able to handle the extra weight imposed by a single-track trailer[/FWIW]
Quoted: 185 Post(s)
Liked 102 Times
Thanks Leisesturm, I didn't know if the raised kick stand would interfere with the trailer hitch at the rear dropout, not knowing how far back ends would extend.
Quoted: 2604 Post(s)
Liked 1,928 Times
@Leisesturm, I have to ask, 110 pounds getting ready for Thanksgiving? Are you hauling donated canned goods from the grocery store to a food pantry or something?
Quoted: 80 Post(s)
Liked 39 Times
I've got the Velo Orange dual leg stand on my Sirrus. It works pretty well for light duty. Things like strong gusts and enthusiastic pups can easily knock the bike over though, especially when loaded. I like it still because it does work smoothly, is not too heavy and I'm careful when parking to have it near a wall or pole, tree, etc when loaded. https://www.youtube.com/watch?v=V4q_c31kVKQ
Quoted: 13 Post(s)
Something I forgot to mention in my earlier reply: We travel with our S & S coupled tandem. When we get to our destination and reassemble the bike, and after the trip as we are breaking it down to pack up, we can stand the bike up on the double kickstand, without wheels. This lets the kickstand act, sort of, like having the bike on a bike repair stand. Pedals, seats, stems and handlebars, cable routing, cranks, timing chain, fenders, chain installation and cleaning, derailleur adjustment, brake adjustment. All of that can be attended to while the bike is standing erect. We still have to get up and down, but it is much easier than if the bike was lying on a side or propped against a wall, or if my stoker had to hold the bike up.
Quoted: 427 Post(s)
Liked 339 Times
The Pletcher is teh way to go hands down. I have owned 3 tandems and would not have a tandem without it. Reasonable judgement when tightening the stand will ensure it is secure but does not crush the frame. Tandems sometimes use heavier tubing so this may be less of a risk with a tandem. I have never seen a frame damaged from overtightening a kickstand but I guess it is possible. For our last tandem we ordered it with a kickstand plate for most secure mounting.
Also, a piece of Velcro wrapped around wheel and downtube is a very light weight way to keep the bike stable. Use a piece around the front brake also to keep it from rolling or moving. Cheap & lightweight and fits in a pocket.
Quoted: 189 Post(s)
Liked 106 Times
True, we used to use velcro, but got a steerstopper as gift and like it in combo with click-stand.
I had Bilenky Cycles add a kickstand mounting plate to both my Santana tandem and Santana triplet (pictured earlier in this thread). Money very well spent, as it makes the twin-legged kickstand setup rock solid. If you don't have a mounting plate, just be careful how much you torque the mounting bracket and bolt down on the chainstays (as others have noted). Rivindell and likely others sells a "sandwich set" that helps spread the load on the chainstays: https://www.rivbike.com/products/ple...nt=23336090241
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 207 Times
It isn't the trailer's overall strength...
BUT, everyone needs to understand that overloading the trailer won't damage it or your bike, but it will seriously increase handling problems, specifically high-speed wobble issues. If your trailer is really heavy and you encounter a fast descent, you may encounter speed wobble/high-speed shimmy that could be disastrous. As in the bike starts wobbling out of control until you crash and crash hard!
My wife and I met another cyclist while on our honeymoon. He noticed our Yak and gave us a stern warning to not overload it. He made this mistake and crashed hard on a fast descent while touring. He then lifted up his shirt to reveal the gnarliest road rash scars that I've ever seen! That made quite an impression on us!
And I'd even be cautious nearing the Yak max load rating for small riders. A 100 lb. rider, for example, wouldn't do well hauling 70lbs. on a Yak, especially on a fast descent!
So everyone should take this into account when loading trailers on bikes. I thought it worthwhile to share in this thread, even though it's really about kickstands (sorry, didn't intend to hijack!).
Also, for those interested, EVERY bicycle will experience high speed wobble. Most bicycles never reach high enough speeds to initiate the problem, so it isn't really worth worrying about. And the high speed effect is NOT resonance, but actually called Hopf Bifurcation. I actually have no idea what this is (save for a layman's understanding of resonance frequencies), but a math professor happened to expound on the subject with Velo News' Lennard Zinn. Anyone interested in the nuts & bolts and math of the subject, can read it at the link below. Enjoy!
https://www.velonews.com/2013/11/tec...-shimmy_309601
(Scroll to last entry.)
Quoted: 189 Post(s)
Liked 106 Times
... that determines max load. It's the ratio of Yak load to rider and its effects on bicycle dynamics that determines the recommended load. I, too, have overloaded a Yak on the tandem after a Costco run without issue. And I'd concede that the max load limit could probably be pushed up a bit for a heavy tandem team.
Quoted: 318 Post(s)
Liked 149 Times
Quoted: 318 Post(s)
Liked 149 Times
The grips are stock and came on the Sirrus, not sure of their make. The pedals are Origin8 Ultim8 Trapp pedals. I use them on 3 of my bikes, luv em. I have a video review of them here https://www.youtube.com/watch?v=AHWcqGdesa4
ETA - great video, thanks again, that's very thorough. And if you're trying to make people envious of your natural surroundings it's working.
