Lightest bike is disc brakes
Quoted: 18883 Post(s)
Liked 10,646 Times
https://bikerumor.com/2020/10/08/585...k-catching-it/
It's 75% of the cost of a base model Honda Civic. Frameset is less than 600 grams. 13 pounds off the shelf, probably 11 if you threw lots of money at it.
So now there's a weight penalty for using rim brakes.
Not if we're allowing comparisons to previous model years. The lightest production road bikes from the lightweight push half a decade ago were under 11 pounds, like the Fuji SL 1.1 or Trek Emonda SLR 10.
Getting below 14 pounds is hardly all that interesting for a top-end carbon lightweight-oriented climbing bike. Not in and of itself, anyway. I could head down into Seattle tomorrow and order a sub-14lb off-the-peg road bike from R&E with a steel frame, if I were so inclined.
And if we're allowing custom builds, this 6lb road bike had rim brakes.
Likes For HTupolev:
Quoted: 338 Post(s)
Liked 408 Times
Depends on build, but since a hydraulic disc groupset is heavier by about 300-ish grams and disc brake wheels are also a tad heavier, you can get a rim brake bike weighting the same for many thousands less...
So, no. I ride discs but have no illusions which is lighter and (marginally) faster. Better brakes are worth a very small penalty for me.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
I guess they spent all their money on the bike and didn't have any left to buy a spirit level to adjust the seat.
Likes For znomit:
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Level seats are old school and uncomfortable (and a result of archaic UCI regulations that have thankfully changed). If you want to get low and fast, a tilted seat is likely to be way more comfortable and sustainable for most people.
Likes For rubiksoval:
Likes For Ferrouscious:
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Likes For Kimmo:
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,849 Times
I've seen that numerous places, but whenever my saddle is even a hair off of level with the nose down, I feel like I'm sliding toward the bars and spend the whole ride pushing back on the seat. Is there some adjustment or such that I'm missing? Is it the shape of the saddle?
Likes For genejockey:
Quoted: 20801 Post(s)
Liked 9,448 Times
Likes For WhyFi:
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
I honestly doubt most recreational or even most enthusiast cyclists can hold a 'low and fast' position for long enough to make a downward tilting saddle beneficial. So the rest of the time riding, they are adjusting over and over again as they slide.
This seems like a race setup decision so cool for that situation.
Likes For mstateglfr:
Bikes: bikes
Liked 1,429 Times
Once I moved my seat substantially forward to open up my hip angle and allow for a lower front end, I simply couldn't have the bike seat level and found I'm totally planted in the seat. In that position, though, hands are on the hoods, elbows are about 90 degrees, and I'm pretty far forward. There's not much room to move forward at that point.
Bikes: bikes
Liked 1,429 Times
What is "nah"? Nah, I ride my bike bolt upright and don't need to have a lower front end and a saddle position to allow that? Or nah, I never noticed how many performance-oriented people are now tilting their saddle down? Or nah, I'm just going to say nah because I'm going to pretend that the way I do it is the de facto way that everyone else is doing it (aside from the photo that prompted the comment in the first place)?
Likes For HTupolev:
Liked 11,849 Times
Maybe you ride much further back? I used to feel similarly and had to make constant adjustments when I was much further behind the bottom bracket.
Quoted: 871 Post(s)
Liked 726 Times
Some of the Aethos lineup comes with the Power saddle, which my Retul fitter/LBS owner told me is usually more comfortable tilted down, based on Retul data. I've found that to be the case personally as well. Usually a level Power saddle would be accompanied by little if any bar drop.
Likes For surak:
bike whisperer
Liked 716 Times
Lol, ten years ago I posted my ride in Hot or Not, and copped all this flak for a three degree tilt.
Yeah, that's right. So ahead of the curve over here I'm on a tangent.
Likes For Kimmo:
Use whatever saddle angle works for you. My SMP stratos is set nose down 2-3 degrees, with a 10cm saddle to bar drop. There is certainly no rule that saddles should be level.
Likes For DaveSSS:
Quoted: 1743 Post(s)
Liked 1,279 Times
Now I'm bummed. My CAAD 12 weighs 17.5 lbs and cost me $1350. For only another $12,000 or so, I could have a bike that's 3 lb lighter. What was I thinking?
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
What a loser. You should immediately spend $4000 to get that bike down to 17 lbs. And make sure you tell the wife. She will fully understand and see the logic.
Likes For vespasianus:
Note 13 lbs is about 5,9 kg or 5900 grams. The fame is only 11% of the total weight. Not saving the last 200-300 grams off of the frame would save a LOT of money to put into other components or in the pocket.
Likes For bruce19:
bike whisperer
Liked 716 Times
Talk about diminishing returns...
Quoted: 406 Post(s)
Liked 389 Times
Quoted: 6934 Post(s)
Liked 10,938 Times
But for $14k, I would prefer custom lugged steel with a flashy paint job, weight be damned. If I had a 13 pound bike, I wouldn't have an excuse for being so slow.
