Torque settings
Torque settings
Old 08-24-15, 10:04 AM
Sonmi451
Torque settings
How am I supposed to decipher which torque settings to use? A few I could figure out but most of these I have no idea what part it is.
https://static.specialized.com/media/...0000036975.pdf
Sonmi451 is offline
Old 08-24-15, 10:08 AM
tjkoko
Bikes: Rockhopper, Azor Oma cruiser
Go here:
https://www.google.com/search?q=bicy...utf-8&oe=utf-8
tjkoko is offline
Old 08-24-15, 10:16 AM
Sonmi451
Originally Posted by tjkoko
Yeah man I did that. I've researched this for a while. I did find a site that had generic settings for manufacturers but not sure if I should trust that. I specifically posted the specialized pdf since that's what my bike is, but it's not really helpful.
Sonmi451 is offline
Old 08-24-15, 01:06 PM
Delmarva
Delmarva's Avatar
Quoted: 10 Post(s)
Liked 5 Times in 4 Posts
Not sure what the question is. Are you unable to identify the parts you want to use a torque wrench on from that list? Or are you not sure what a torque setting is?
Delmarva is offline
Old 08-24-15, 02:33 PM
Sonmi451
The former. Although I don't know the torque setting until I know what the part is.
Sonmi451 is offline
Old 08-24-15, 02:59 PM
Delmarva
Delmarva's Avatar
Quoted: 10 Post(s)
The list is set up by function. Which parts do you want to torque?
Delmarva is offline
Old 08-24-15, 04:23 PM
Sonmi451
Corrected link to 2015 manual:
https://service.specialized.com/colla...0000044211.pdf
Okay, so there are torque settings on each part, I understand these are MAX torque settings right? But you're supposed to look at the Torque settings for each manufacturer by frame or something? For example, my seat post & handle bars are Specialized, so I would refer to the chart I posted, but my crank is an FSA Tempo, so I would have to look at the FSA site for their specifications right?
So I'm confused because my seat post clamp is Specialized and it says 6.2 Nm but all the seat posts on that pdf are at least 9 Nm, AND I can't tell which seat post I have. It doesn't have a name on it. From the product description, it says "Alloy, 2-bolt, micro adjust..."
I basically don't want to over tighten a seat clamp or something stupid and bust my carbon frame. I hope all the makes sense. Thanks for the help!
edit: I think I'm an idiot because those torque settings are referring to the top bolts on the seat post, not the seat clamp itself. I guess that's the "seat collar" which is the 27.2mm seat post which would be 6.2 Nm. Did I just figure out my own problem?
Sonmi451 is offline
Old 08-24-15, 04:41 PM
Delmarva
Delmarva's Avatar
Quoted: 10 Post(s)
If the spec sheet above is for your bike and you have not swapped out any parts then just follow the spec sheet.
Delmarva is offline
maartendc
Bicycle Mechanics
15
02-09-18 08:38 AM
kkapdolee
Road Cycling
60
12-09-15 01:05 PM
cooleric1234
Bicycle Mechanics
5
10-10-10 09:37 PM
bike2victory
Bicycle Mechanics
3
06-25-10 07:19 PM
sngsndrms
Bicycle Mechanics
59
12-11-09 06:15 AM
