What We All Knew...
#51
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4336 Post(s)
Liked 2,977 Times
At issue here is the F. That F is the sum of several forces:
1. Wind resistance
2. Rolling resistance
3. Drive train resistance
4. Force required to change potential energy (elevation difference)
Unless you're climbing, your weight has next to no effect on 1, 2, or 3.
And if you are climbing, you'd have to specify some specific conditions to come up with a "mph/lb" number the way Sam cited, and that would certainly be non-linear over any meaningful range.
#52
Quoted: 3011 Post(s)
Liked 3,788 Times
1. Wind resistance
1. Wind resistance
#53
It's MY mountain
Liked 2,977 Times
The real reason people get faster on flat ground when they lose weight is because they are biologically more efficient - less blubber to sustain with their metabolism and their power output goes up. OK, I don't have science to prove that statement, just anecdote.
And the reason they get faster climbing hills when they lose weight is because it takes less power to overcome gravity.
#54
Liked 3,788 Times
Weight certainly affects your acceleration... how quickly you can change speed at a constant power. When you're at constant speed a=0, so (mav)1 = (mav)2 is a trivial relationship.
If a=0, then where are my 88 watts going? p=mav, if a=0, p=0.
#55
It's MY mountain
Liked 2,977 Times
Top end speed of a semi is the same, whether it's loaded or not. But it takes a longer time for the loaded truck to get up to that speed, and takes longer to stop.
#56
Liked 3,788 Times
I think I got it. Thanks.
#57
It's MY mountain
Liked 2,977 Times
#58
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,047 Times
#59
Getting the incremental improvements that matter most over the last 45 years for road racing machines seems back to front in this thread.
By that I mean:
1) A good quality steel race frame from the '70's fitted out with all modern components.
B) A modern CF race frame fitted out (not so easy to do) with a 70's period NR group w/ DT friction controls, non-aero brake levers, 52/42 5 cog 14-21 gearing, Toeclips/straps, 36H AL tubular wheels, Brooks Pro Saddle and a mechanical stopwatch & holder.
I'd race version 1 vs B myself.
Oddly enough there is an entire thread in C&V "Retro roadies- old frames with STI's or Ergos" with 1,903,083 posts indicating that this is a well trodden path.
Not so oddly for B there is Nada.
-Bandera
By that I mean:
-Bandera
#60
Liked 3,788 Times
#61
Le savonnier
Bikes: I can count 'em on one hand
Quoted: 729 Post(s)
Liked 602 Times
I probably have what would be considered an unreasonable hatred of Ultegra, especially the brifters. I base this on:
1) I think it's butt-ugly.
2) Every bike I've ever purchased with Ultegra on it has been dysfunctional; again, especially the brifters.
#62
How much of a boost can the psychological effect of riding a brand new modern race bike bring to the table? Can that be measured? I mean, it could make some people feel better, push harder, train harder and play harder. How many people here purchased super expensive exotic Italian steel bike because so and so was super fast and won a race on it back in the day? It seems odd that we make fun of the young crowd now for buying bikes that today`s idols of the sport ride? Whatever gets them on a bike and riding is a great bike. I have given up on making fun of carbon bikes. They might not look as pretty as my steel to me, but my Cannondale sure is fun to ride.
My bikes: 1970`s Roberts - 1981 Miyata 912 - 1980`s Ocshner (Chrome) - 1987 Schwinn Circuit - 1987 Schwinn Prologue - 1992 Schwinn Crosspoint - 1999 Schwinn Circuit - 2014 Cannondale Super Six EVO
#65
You know what else I find to be odd? The push to bigger tires on the old steel bikes? So many people here do not ride the old steel racing bikes anymore because they will not fit 32`s or bigger? But boy the old steel racers are superior or just as good as today`s bikes? The other odd thing is that I have heard over and over how some steel racing bikes are superior to other steel bikes because they are two to three pounds lighter.? But carbon bikes that are five to six pounds lighter than steel bikes have no advantage? We should start a C&V contradictions thread?
#66
It's MY mountain
Liked 2,977 Times
#67
52psi
Quoted: 790 Post(s)
Liked 801 Times
This image will never leave me.
#68
The demographic around here seems to be 60+. How fast are we going that an aero frame is going to make any difference? When JRA means 40kph and sprints are always above 60kph fair enough to presume all present are on carbon. If over 60 and doing those speeds training and sleeping is going to take so many hours nothing will be left over for fooling with C&V bikes.
I ride old bikes because I like them. Can remember JRA at 40kph when steel was the only choice and those memories will last. Memories won't make me fast and neither will carbon.
And all my bikes will fit 32mm tires. Because they are old bikes. If your concept of an old bike is something 10 or 20 years old you don't get to play with wide tires. Which are just normal tires.
#69
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
By that I mean:
By that I mean:
It's also sort of strange to me (just my opinion), that so many people are fine with cookie-cutter bikes and parts. I mean, don't you want your bike to be your bike?
Sounds like the makings of a good GCN video: "What is faster? New frame with old parts, or old frame with new parts?" As stated, though, it would probably be a PITA to setup a new frame with vintage stuff.
#70
Bikes: Surly Cross, Franklin tandem, Culprit Jr., BMX racer
Quoted: 35 Post(s)
Liked 45 Times
Oddly enough USAC racing is age cadre and experience based in field selection.
If/when I emerge from retirement to pin on a number it will be my peers not their grandchildren or rank newbies that I'll line up with.
As ever it will be the fit, fast and race smart who populate the steps of the podium using the equipment that they prefer within UCI guidelines.
If one feels up for giving a demonstration of their C&V period machine and kit please make sure that your tires are firmly glued and have at it.
-Bandera
-Bandera
#72
