1991(?) Diamondback Apex Fork...
Quoted: 12 Post(s)
So I am in search of your collective experience and expertise here. I just acquired what I believe is a 1991 Diamondback Apex. 18 inch frame fits me well. It is incredibly filthy and needs a total disassembly, cleaning and lube. It is however all original with one glaring exception. It has a Rock Shox suspension fork on it. It seems like a nice fork but it seems as if the front of the frame is slightly higher than stock. And I just like fully rigid bikes better. I also want to get it back to completely original. So I have already discovered that the various size frames all have different head tube/steerer tube lengths. The head tube on my frame is 4.5 inches/120 mm. So I am searching for a fork or donor frame of the correct size and am wondering are there any issues or concerns I am not aware of regarding the fork replacement? In a slightly different direction, can I transfer my components from the Apex frame to an Ascent EX frame? Will the bottom bracket/crank set, head set, front derailleur clamp all fit? Are there changes from year to year to be aware of? Any advice is greatly appreciated. Mike M.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Assuming the head tube and steerer fork are the same dimensions on the apex and ascent, it should be an easy swap.
The only issue I can think of is that some Dback mtbs in the late 80s came with a chainstay brake.
But I think the EX was an early 90s right? So that would be an even swap all over.
I've owned both the apex and ascent. The apex came with a higher groupset and higher level of tubing.
Both were tanks that were built to ram thru obstacles. The geometry change a bit year to year and even within the same year depending on model. Lower level got more relaxed geometry.
Quoted: 12 Post(s)
SamSpade and Jethin, Thanks for the response. Yes please if you might have a fork that you wish to sell I would like to know the steerer tube length or the head tube length of the frame it is in. Assuming it is the "over-size" 1 1/8 diameter that seems to be what all of these diamondback bikes had. Thanks again.
Quoted: 12 Post(s)
mstateglfr, no chain stay brake. I did not see any 91 and later DB bikes with a chain stay brake in my internet searches. Thanks for the comments.
Sunshine
Liked 7,491 Times
Wasn't sure about the year of the Ascent and that model was around in the 80s.
Looks like you struck gold on the forum with options!
