Dropout axle insertion limiting screws
I’m getting to know my 1985 Trek 770 frame. I notice that those little screws are screwed in pretty far limiting the rear axle from being inserted deep into the dropouts. The chainstay length is already really short and I think I could gain maybe 3/8” in crank to rear axle distance by turning out the screws. I’ll probably need to add links to the chain and maybe it would mess up the derailleur operation.
It looks like from the witness marks that the axle was once further into the dropouts than it is now.
Is there a proper adjustment for these screws other than to center the rim in the frame?
Thanks.
Thanks.
Pretty much all they do is help you center the wheel when you put it back in. You could even remove them if you wanted to move your axle further back.
Quoted: 4560 Post(s)
Liked 2,802 Times
Wheel placement in horizontal dropouts can influence shifting and the cog size that can be accommodated. Depends on the bike and rear derailleur and shifter system. My '89 Centurion Ironman with Suntour GPX group is picky about rear wheel position in the dropout.
Quoted: 1438 Post(s)
Liked 1,092 Times
I am not certain that it would necessarily "mess up" the derailleur but it would certainly require re-doing the indexing adjustment.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Thanks.
Thanks.
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
If you have friction shifting, none of that shifting chatter makes any difference. I would be surprised if the chain needs to be adjusted either. I've read about these things here, for nearly 10 years, and have never had to adjust chain length for this reason. Dumb luck perhaps.
Here’s what I’m thinking...with the triple the chain alignment would better although the short distance I’d gain may be insignificant in that regard. The most important fix would be more room for a larger tire. I brought home a Bontrager 28c tonight to see how it fits in the frame. I’ll back out those screws when I try the larger tire and see how it goes.
Thanks for all the responses.
